Fri May 13, 2022 10:31 am
1971 Vespa 150 sprint
Fri May 13, 2022 10:31 am linkquote
Hi all. I have a 150 sprint veloce. Im putting a pinasco 177cc kit on it. A pinasco race crank and flytech flywheel. What's people's recommendations on a decent exhaust to use? stainless steel if possible. Thanks in advance.
Sat May 14, 2022 5:24 pm
Sat May 14, 2022 5:24 pm linkquote
I have a 71 sprint Veloce. I tried the following on my Sprint Veloce:
1) Stock (Also the smallest in size along the Malossi)
2) Sito plus (very large and bulky with poor clearance but decent performance. Noisy)
3) Polini box (10-15% larger in size than the Malossi or stock).
4) Malossi box (the smallest in size, very compact). Noisy deep
5) SR3(SIP road 3), same size as the Polini. Not too well design because the elbow hits the ground
6) Lefty Boomstick. it clears very well under the left cowl
For power the absolute best was the SR3. I tested it over and over and over with two GPS, a tachometer and a acceleration instrument device(Dragy).
The SR3 is just well above the rest in power/torque. The second best was the Polini closely followed by the Malossi. Although the top speed did not change much the acceleration improvement was significant.
Sat May 14, 2022 11:42 pm
Sat May 14, 2022 11:42 pm linkquote
I'm happy to see your in use exhaust comparison, and it also makes me sad to see the Vespas tipped over on the ground.
Sun May 15, 2022 2:19 am
Sun May 15, 2022 2:19 am linkquote
They're just tired. Who is the guy behind the curtain ?
Sun May 15, 2022 3:15 am
Sun May 15, 2022 3:15 am linkquote
Which pinasco kit? What crank stroke? What carb/inlet type? What type of riding you want to do?
Sun May 15, 2022 3:20 am
Sun May 15, 2022 3:20 am linkquote
How did the jetting differ between these exhausts? An exhaust with more pull will require an up jet. That exhaust with no upjet will be under its best.
Sun May 15, 2022 5:26 am
VNB vsc o9c VMA vbc VSX
Sun May 15, 2022 5:26 am linkquote
He's pretty excited to be there whoever he is.
Mon May 16, 2022 5:27 am
Mon May 16, 2022 5:27 am linkquote
Not me either, i am to busy making my own big box exhaust
[ Time: 0.0338s ][ Queries: 7 (0.0131s) ][ Debug on ][ 211 ][ Thing One ]
