Hi guys,
My KS is lower, my guess is it slipped 1 tooth, hard to say. Its on top, return spring is fine.
Any suggestion for a quality replacement? Vespa 125 GTR 1977, tuned BGM 177
TIA
Posts: 277 Location: Madeira Island |
quote
Hi guys,
My KS is lower, my guess is it slipped 1 tooth, hard to say. Its on top, return spring is fine. Any suggestion for a quality replacement? Vespa 125 GTR 1977, tuned BGM 177 TIA |
Posts: 1797 Location: Philadelphia |
quote
FridayMatinee wrote: What engine is it for? |
Posts: 4109 Location: Veria, Greece |
quote
Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese…
quote
SaFiS wrote: Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese… I tried a close-up shot, it skipped one tooth, right? |
quote
SIP brand kickstarter levers seems ok.
I know they act as a fuse and are made to break, should I order half a dozen? |
Posts: 5059 Location: Oceanside, CA |
quote
If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts.
quote
MJRally wrote: If you ever ruin a brand new kickstart lever fairly quickly, your kickstart quadrant is the culprit. I had a bad quadrant ruin 2 kickstart levers. Everything was torqued to spec, all new etc etc. At $50 a pop, I wasnt happy two were ruined that quick. Showed my vendor the damage and they gave me some credit towards new parts. |
Posts: 1845 Location: San Francisco, CA |
quote
SaFiS wrote: Is it the short one or the longer one found on Rallys?? If it's the short one, get one for a Rally 200. It's longer so gives a bigger leverage. I would avoid FA they're made of cheese… The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. Looks close.
Looks much different.
quote
hjo wrote: Oh no! I was just going to buy one of those. The FA Italia ones are the ones I see that are the same shape as the original. Looks like the GTR and Rally are the same. FAs are OKish but tend to wear fast... |
quote
It is shorter!
It's a shame. The original ones had that Piaggio shield badge. But mine is totally scraped away and worn at the end. |
quote
I ended up going to the SIP "standard", the one which resembles the original shape
There were apparently 3 options compatible with the GTR/Sprint: the "Standard", the "VBB Style" and the "Rally Style", which, AFAIK these last two would only be adequate for a PX engine on an old frame (as the "exercise" bellow shows they would stand too low). Safis, I guess you were referring to the Rally 200 version (the real one), ok, that would look fine, but I have strong legs and went for the version more alike the original Thanks |
quote
Yo guys, picture above is so obvious now ...
Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
quote
Just remove the bolt. It holds it in place.
The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. |
quote
hjo wrote: Just remove the bolt. It holds it in place. The lever will come off easy. Maybe check the torque setting putting it back on. 16 to 19 foot pounds. More and it will break, less and it can slip. Take photos of the quadrant. It's probably fine, but there could be an issue that's visible. Maybe pulling out the spark plug and rotating the kick start lever by hand I can remove the bold without taking off the flywheel cover? the same for installing the new one... I'll take photos from the quadrant shaft for reference, I hope its fine |
quote
PSMA wrote: Yo guys, picture above is so obvious now ... Just discovering things on the go Any tips that help changing the kick start lever easy? It looks as I need to remove the flywheel cover? Also, if the actual lever is stuck on shaft, is it safe to tap it out from behind? Thanks! |
1975 Rally 215, 1960 Lambretta 195 s2
Posts: 469 Location: San Francisco Bay Area |
quote
Hi, opinions on the quadrant shaft condition please?
Doesn't look bad to me. Yet to receive the new kick start lever, meanwhile removed the old one, completely destroyed |
quote
FridayMatinee wrote: Flywheel cover does need to come off. The bolt won't come out otherwise. |
