![]() Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
Posts: 530 Location: Wales |
Thu, 10 Jun 2021 05:52:21 +0000
quote
In the Rusteration process 1980 model basically as the bare frame come with matt clearcoat added [/img]
![]() Sun, 17 Apr 2022 22:20:08 +0000
Posts: 220 Location: Tempe, Arizona |
![]() '71 Rally 180,'81 P200, 1979 Vespa 90(125), 2023 Ducati Scrambler Pro Stealth
![]() 2021 GTS 300 Supersport, Triumph Tiger 800
Posts: 434 Location: Oxford, UK |
Mon, 18 Apr 2022 06:47:43 +0000
quote
Now for sale or at least will be when vinyl graphics removed.
Positive
![]() Mon, 18 Apr 2022 13:03:01 +0000
Posts: 2087 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
quote
Coddy wrote: Now for sale or at least will be when vinyl graphics removed. |
Tue, 19 Apr 2022 09:38:33 +0000
quote
Touring300 wrote: Unless you can find a scooter loving Wasps supporter ![]() |
Fri, 27 May 2022 10:56:13 +0000
quote
My P200 "Madalina"
Travelled aprox 40.000 km in 33 countries of Europe and Africa between 2014 and 2016 ![]() ![]() ![]()
Positive
Posts: 4110 Location: Staten Island, NY |
Sun, 29 May 2022 02:32:39 +0000
quote
VespistaX wrote: P125 from 1979 Custom Rat I want to do something like this so I'm curious to see more images of how it's plumbed and which tank you used. |
Sun, 29 May 2022 07:35:12 +0000
quote
swiss1939 wrote: Love the extended range tank. What is it from? Did you just plumb it from bottom of tank through the nose of the seat frame and tap a hole into the side of the existing tank? So you fill it once from the accessory tank? I want to do something like this so I'm curious to see more images of how it's plumbed and which tank you used. |
Sun, 29 May 2022 22:48:01 +0000
quote
VespistaX wrote: It is a GN125 Tank. That is simply connected to the hose of the original tank with a V-Connector. When the first tank is near empty I open the additional one. You only need to be careful when it is all full and leave it open it will get the original to flow over. that way I had a huge range for long distance rides. |
Mon, 30 May 2022 11:19:20 +0000
quote
It is all connected under the gas tank INSIDE the frame and then runs into the carb. Sorry I do not have pictures of it.
Mon, 30 May 2022 11:56:08 +0000
quote
So you had to take the main tank out every time you needed to switch tanks?
That seems like a lot of work on the road. |
Mon, 30 May 2022 12:11:04 +0000
quote
No As you will see on THIS PIC the Motorbike tank comes with a Switch under the tank that you open and close. from there the fuel line goes into the frame onto that V-Connector. So after the main tank under the seat is emptied you just switch on the Motorbike tank and it fills the other one. no pump not dismantling. BUT you need to always remember to close it again otherwise youz get the fuel running out of the main tank over the bike.
Positive
Mon, 30 May 2022 12:36:22 +0000
quote
VespistaX wrote: No As you will see on THIS PIC the Motorbike tank comes with a Switch under the tank that you open and close. from there the fuel line goes into the frame onto that V-Connector. So after the main tank under the seat is emptied you just switch on the Motorbike tank and it fills the other one. no pump not dismantling. BUT you need to always remember to close it again otherwise youz get the fuel running out of the main tank over the bike. |
Mon, 30 May 2022 12:40:46 +0000
quote
swiss1939 wrote: Gotcha.. so you replaced the sight glass with a switch for the fuel lines. Premix only. Or is that the switch right on the tank outlet before the fuel line comes out? Hard to tell in that photo. Either way, love the solution. I want to try that some day. |
![]() Vespa GTS 300 2021 -------- Vespa PX 200 1990 ---------Vespa Rally 200 1975 ------
Posts: 21 Location: Örnsköldsvik, Sweden |
![]() 2022 Liberty 150S-"Meg"
Posts: 1114 Location: Texas |
![]() '13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Posts: 929 Location: Ukraine. Kyiv. |
Fri, 21 Apr 2023 21:04:54 +0000
quote
This look of my 1981 P150X is no more exist - wheels was sold and scooter stripped down for respraying.
Positive
![]() Thu, 11 May 2023 15:39:14 +0000
'88 Vespa P2
Posts: 65 Location: Bathgate.. Scotland |
![]() '88 Vespa P2
![]() Sun, 09 Jul 2023 14:25:56 +0000
quote
Time to dust ol Bloopie off and start making her into my "touring" machine. Giant box on the back and crash bars are on the list for now. Haven't decided what else yet.
Positive
Tue, 17 Oct 2023 18:54:18 +0000
quote
roland87 wrote: This look of my 1981 P150X is no more exist - wheels was sold and scooter stripped down for respraying. ![]() ![]() ![]()
Positive
![]() 1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Posts: 1870 Location: Grand Rapids, MI |
Wed, 18 Oct 2023 11:13:32 +0000
quote
roland87 wrote: How it look now. ![]() ![]() That is beautilicious. If that wasn't a word, it is now. |
Wed, 18 Oct 2023 13:52:01 +0000
quote
seamus26 wrote: Oooooooooohhhhhh .... ![]() That is beautilicious. If that wasn't a word, it is now. |
