Thu, 10 Jun 2021 05:52:21 +0000
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
Thu, 10 Jun 2021 05:52:21 +0000 quote
In the Rusteration process 1980 model basically as the bare frame come with matt clearcoat added [/img]
Sun, 17 Apr 2022 22:20:08 +0000
'71 Rally 180,'81 P200, Lambretta GP200, 1980 Vespa 90(125), 2023 Ducati Scrambler Pro Stealth
Sun, 17 Apr 2022 22:20:08 +0000 quote
My workhorse
Mon, 18 Apr 2022 06:47:43 +0000
Mon, 18 Apr 2022 06:47:43 +0000 quote
Now for sale or at least will be when vinyl graphics removed.
Mon, 18 Apr 2022 13:03:01 +0000
Mon, 18 Apr 2022 13:03:01 +0000 quote
Unless you can find a scooter loving Wasps supporter
Tue, 19 Apr 2022 09:38:33 +0000
Tue, 19 Apr 2022 09:38:33 +0000 quote
If only
Fri, 27 May 2022 10:56:13 +0000
Fri, 27 May 2022 10:56:13 +0000 quote
My P200 "Madalina"
Travelled aprox 40.000 km in 33 countries of Europe and Africa between 2014 and 2016
Sat, 28 May 2022 21:10:37 +0000
Sat, 28 May 2022 21:10:37 +0000 quote
P125 from 1979 Custom Rat
Sun, 29 May 2022 02:32:39 +0000
Sun, 29 May 2022 02:32:39 +0000 quote
Love the extended range tank. What is it from? Did you just plumb it from bottom of tank through the nose of the seat frame and tap a hole into the side of the existing tank? So you fill it once from the accessory tank?
I want to do something like this so I'm curious to see more images of how it's plumbed and which tank you used.
Sun, 29 May 2022 07:35:12 +0000
Sun, 29 May 2022 07:35:12 +0000 quote
It is a GN125 Tank. That is simply connected to the hose of the original tank with a V-Connector. When the first tank is near empty I open the additional one. You only need to be careful when it is all full and leave it open it will get the original to flow over. that way I had a huge range for long distance rides.
Sun, 29 May 2022 22:48:01 +0000
Sun, 29 May 2022 22:48:01 +0000 quote
Connected to hose of original one on the outside of the frame where the original hose exits the frame before going into carb? Got any photos of it?
Mon, 30 May 2022 11:19:20 +0000
Mon, 30 May 2022 11:19:20 +0000 quote
It is all connected under the gas tank INSIDE the frame and then runs into the carb. Sorry I do not have pictures of it.
Mon, 30 May 2022 11:56:08 +0000
Mon, 30 May 2022 11:56:08 +0000 quote
So you had to take the main tank out every time you needed to switch tanks?
That seems like a lot of work on the road.
Mon, 30 May 2022 12:11:04 +0000
Mon, 30 May 2022 12:11:04 +0000 quote
No As you will see on THIS PIC the Motorbike tank comes with a Switch under the tank that you open and close. from there the fuel line goes into the frame onto that V-Connector. So after the main tank under the seat is emptied you just switch on the Motorbike tank and it fills the other one. no pump not dismantling. BUT you need to always remember to close it again otherwise youz get the fuel running out of the main tank over the bike.
Mon, 30 May 2022 12:36:22 +0000
Mon, 30 May 2022 12:36:22 +0000 quote
Gotcha.. so you replaced the sight glass with a switch for the fuel lines. Premix only. Or is that the switch right on the tank outlet before the fuel line comes out? Hard to tell in that photo. Either way, love the solution. I want to try that some day.
Mon, 30 May 2022 12:40:46 +0000
Mon, 30 May 2022 12:40:46 +0000 quote
The switch is DIRECTLY under the tank and the line enters where the oil glass would be.
⬆️    About 19w elapsed between posts    ⬇️
Tue, 11 Oct 2022 18:26:29 +0000
Vespa GTS 300 2021 -------- Vespa PX 200 1990 ---------Vespa Rally 200 1975 ------
Tue, 11 Oct 2022 18:26:29 +0000 quote
PX200 1990
Tue, 11 Oct 2022 19:58:21 +0000
2022 Liberty 150S-"Meg"
Tue, 11 Oct 2022 19:58:21 +0000 quote
My 2012 Stella 150 4T, "Penny", out running errands.
⬆️    About 27w elapsed between posts    ⬇️
Fri, 21 Apr 2023 12:11:10 +0000
Fri, 21 Apr 2023 12:11:10 +0000 quote
Ready for summer
Fri, 21 Apr 2023 21:04:54 +0000
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Fri, 21 Apr 2023 21:04:54 +0000 quote
This look of my 1981 P150X is no more exist - wheels was sold and scooter stripped down for respraying.
Thu, 11 May 2023 15:39:14 +0000
'88 Vespa P2
'88 Vespa P2
Thu, 11 May 2023 15:39:14 +0000 quote
'88 P2, 35 this year !
Sun, 09 Jul 2023 14:25:56 +0000
Sun, 09 Jul 2023 14:25:56 +0000 quote
Time to dust ol Bloopie off and start making her into my "touring" machine. Giant box on the back and crash bars are on the list for now. Haven't decided what else yet.
[ Time: 1.0273s ][ Queries: 6 (1.0035s) ][ Debug on ][ 286 ][ Thing Two ]
