Kit for part of the 6k maintenance.
https://www.scooterwest.com/piaggio-500-variator-holding-tool-toolp500v.html
https://www.af1racing.com/Buzzetti-Variator-Locking-Tool-For-400-500cc For some reason the scooterwest "kit" is way more expensive than just buying the parts individually. |
Mitch already has you covered. Do be careful how you jam the rear wheel. Have seen a couple instances of the brake caliper mounting points breaking off. I can almost do mine with the just the rear brake and parking brake grabbing tight. If you have an air impact wrench the nut will come of easily, but you still need to torque it down properly when you're done.
I would note use his technic to remove the bolt. This is how I broke something on my scooter back in the time:
https://modernvespa.com/forum/topic154997 Disaster...I broke few parts on my MP3 500 |
I found the best way to break the rear axle nut loose is to have the scoot sitting on its wheels with a helper sitting on the seat.
The combined weight of the scoot and helper should be more than enough to break that nut loose without having to force or break anything. IF you don't have a torque wrench handy, mark the nut and spindle (prior to removal) with a sharpie so you can get the nut back to roughly the same spot as it was before. However, this method is not a replacement for the torque wrench and should only be used as a temporary measure. |
Wow, great detail and support, Thanks. This is my 1st 6k overhaul and I am still under warranty. I was thinking that I should have a dealership do it while under warranty. Any thoughts?
This is also my first Piaggio or CVT. It seems like a high maintenance cost to have to do this type of repair every 6,000 mi. I haven't had my bike a year yet. Does that mean I have to spend $500 a year to keep my bike running? |
Well, European vehicles come with European prices. Piaggio is not alone in this. BMW is the same. Heard the same about KTM, Triumph, etc.
In the US, Piaggio is not a major player and they treat the US as a outlet market for bikes they can no longer sell in their home market. They are a niche player making parts and availability more difficult resulting in higher prices. I suggest you use easyparts.nl if you plan to wrench yourself, which is the only way to make these bikes easier on the wallet. Either way, these bikes do require very regular maintenance. There is simply no escaping that other than running it until something blows up. If you wanted outright reliability and lowest running costs then you should have bought a Honda. The belt is a critical service item you cannot ignore. Either do it yourself or have a knowledgeable shop perform it. |
![]() Tue May 31, 2022 2:17 pm
Posts: 22101 Location: Harriman, Tennessee, Tn |
maseratij wrote: Wow, great detail and support, Thanks. This is my 1st 6k overhaul and I am still under warranty. I was thinking that I should have a dealership do it while under warranty. Any thoughts? This is also my first Piaggio or CVT. It seems like a high maintenance cost to have to do this type of repair every 6,000 mi. I haven't had my bike a year yet. Does that mean I have to spend $500 a year to keep my bike running? |
![]() Tue May 31, 2022 4:45 pm
Posts: 7016 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
![]() Tue May 31, 2022 4:48 pm
@madison sully there is some irony in the username more about speed than luxury btw. I understand the costs of maintenance, thank you to the members who reminded me that things break and require preventative maintenance. My observation was only in that I lurked here for a year or two before I purchased an MP3 and never came across a conversation regarding Total Cost of Ownership.
If I wanted two wheels there were more options! That said the technology and the power make the MP3 something very unique on the road. Paying to play! |
CVT maintenance is similar to chain & sprockets
I'd rather clean up rubber dust contained by a cover, than chain lube slinging off everywhere, no matter how carefully it's applied Nothing quite like cleaning a fine patina of chain lube & brake dust off a spoked rim |
Garthhh wrote: On a rigid bicycle, spokes are slightly more comfortable Spokes mostly means inner tubes another joyous blast from the past ![]() On the motorcycle front, I have long been a proponent of cardan driveshafts, and belts also rank high... but chains have come a very long way (unless you ride them on snowy and salty or muddy streets, I guess). |
