Sat, 04 Jun 2022 14:08:06 +0000
2007 MP3 250
Joined: Wed, 26 Feb 2020 02:51:15 +0000 Posts: 24 Location: SW Ontario Canada
2007 MP3 250
quote
HI
This matter has cropped up on the forum in the past, but my personsonal reason for need of a Side stand was never really , being failure of the Tiltlock control! I am now in my 90's and have owned two MP3's In both I have had a failure of the Tiltlock, leaving me wondering if I could possibly get off and use the centre stand without dropping the Vehicle. Due to age and health my strength is not what it once was, and I bought an MP3 to save the need to balance the weight. I have another scooter that has both side and centre stands, making things much easier.
Yes, I know the tiltlock is usually reliable, but for my peace of mind..........
If anyone knows of an aftermarket sidestand that would do the trick, I would appreciate hearing form them.
Peter.
Sat, 04 Jun 2022 19:34:52 +0000
Joined: Sun, 11 Oct 2009 13:35:31 +0000 Posts: 4471 Location: Netherlands Olst
quote
its possible the first 125cc didn't have a tilt lock so it came with a jiffy and a center stand
Sun, 05 Jun 2022 01:19:42 +0000
2007 MP3 250
2007 MP3 250
quote
Thanks for the prompt response. I will do some research into the 125 and see how it is set up. Failing that I may have to consider fabrication .
Wed, 08 Jun 2022 00:36:10 +0000
Joined: Tue, 02 Apr 2013 12:44:02 +0000 Posts: 954 Location: tampa
Wed, 08 Jun 2022 18:43:46 +0000
2007 MP3 250
2007 MP3 250
quote
Yes, it looks good...does it make use of the centre stand frame mount? I will take another look if and when I have the ##@*$ Tiltlock working!
Thanks for your input
Cheers
Peter.
Thu, 09 Jun 2022 06:11:44 +0000
quote
it was not mounted using centerstand mount. it was welded to side frame rail. I dont have the lower side fairings. that would likely need trimmed to fit. it was 100% custom. but not that hard as far as custom goes. It was really worth the effort. bike was cumbersome using the center stand.
