Sat Jun 04, 2022 8:55 pm
Granturismo + gts300
Sat Jun 04, 2022 8:55 pm linkquote
Hi guys, I just bought a GTV vespa 125 no keys at an impound auction.
I am not familiar on what one needs to get a set of new, used kees. I found this (photo below ) on classifieds where I live, the seller wants 100 euros… would this work and do I need any thing else?
I also found some generic immobilizer removers and this set:
https://www.ebay.com/itm/354087136537?hash=item52713ced19:g:ptAAAOSwZ8hiljXp
Would this work?
Thank you.
Sun Jun 05, 2022 3:16 am
Sun Jun 05, 2022 3:16 am linkquote
T hi is is thenoriginal CDI on this vespa that I don't have keys for.
Sat Jun 11, 2022 10:33 pm
Sat Jun 11, 2022 10:33 pm linkquote
Update:
Drilled the lock, 12mm drill bit, 31mm deep and it came out no problem… steering unlocked.
Purchased the identical ECU with programmed keys, in the mail… will update once I get it going.
Sat Jun 18, 2022 9:36 pm
Sat Jun 18, 2022 9:36 pm linkquote
Got the new ecu key barrel and keys from ebay, the vespa started right up.
Sun Jun 19, 2022 1:00 am
Sun Jun 19, 2022 1:00 am linkquote
Well done, you solved your problem without the help of any group members
Sun Jun 19, 2022 5:55 am
Sun Jun 19, 2022 5:55 am linkquote
Yeah, ai am quite surprised that there were no responses, it is like a tabu subject.
Not all of us are crooks and needed help, no help, so I risked it and it worked out.…
The crooks will do what they'll so with or without anyones help.
I posted this to help any that are honestly having the same issue as I did and need help.
The one thing that the seller of the ECU/keys is that the most important thing choosing an ebay ECU is the top, right corner code, otherwise it would jot work (in my case ac23i)
Tue Jun 21, 2022 4:39 am
Vespa
Vespa
Tue Jun 21, 2022 4:39 am linkquote
Slt j'ai le mm problème sauf que moi c'est un lx 125 injection a papillon codé le truc c'est que je m'ai plus de cdi sur la moto comment retrouver la référence du cdi
Tue Jun 21, 2022 11:13 pm
Tue Jun 21, 2022 11:13 pm linkquote
si vous avez besoin d'aide, écrivez en anglais, je suis chrétien et j'écris toujours en anglais.
c'est un forum anglophone.
[ Time: 0.0357s ][ Queries: 7 (0.0132s) ][ Debug on ][ 211 ][ Thing One ]
