Thu Jun 09, 2022 9:47 am
Piaggio MP3
Piaggio MP3
Thu Jun 09, 2022 9:47 am linkquote
I'm new to piaggio so I have no clue where are parts located
Please help
No spark
I can hear the pump coming on and starter but I've pulled the spark plug out and no spark
Some people say bad CDI
If so, where is it located?what does it look like and a part number?
Also how do I check the cdi if it's good or bad
I'm comfortable to work with a multimeter
Some people said it could be the transmitter
If so, why is the pump and starter coming in
Pictures would be very helpful
Thu Jun 09, 2022 11:59 am
Thu Jun 09, 2022 11:59 am linkquote
Sounds like the immobilizer is playing interference.
Is the red CODE (anti theft) LED staying on when you turn on ignition?
IF so, then that is the reason why you have no spark.
Thu Jun 09, 2022 12:08 pm
Thu Jun 09, 2022 12:08 pm linkquote
You should go to the wiki
MP3 400
The key has a chip that has to be detected or the cdi won't get power
Here's some manuals
Thu Jun 09, 2022 12:22 pm
Piaggio MP3
Piaggio MP3
Thu Jun 09, 2022 12:22 pm linkquote
The red light is indeed on
Do you by chance have a part # of the immobilizer and also where is it located?
Should I try to reprogram the key before I buy the immobilizer?also how can I check if the immobilizer is bad?
Fri Jun 10, 2022 4:12 am
Fri Jun 10, 2022 4:12 am linkquote
2008 piaggio mp3 400 no start
[ Time: 0.0260s ][ Queries: 5 (0.0070s) ][ Debug on ][ 211 ][ Thing One ]
