Fri May 13, 2022 10:23 am
Fri May 13, 2022 10:23 am linkquote
Jack221 wrote:
Finished the panel dent too. General shape is ok enough. Gave it a quick thin coat of primer to see how the filling was looking and this is what happened. Looks like a world map. Why is this? Seems smooth. Been sanded with 180 grit and appears like a skating rink to me.
Finer paper and plenty more coats of primer?
A primer surfacer must be painted over body filler to prevent that from happening!
Fri May 13, 2022 2:28 pm
PX221 MHR, O tuned PX200, PX180 Quattrini and some motorbikes
Fri May 13, 2022 2:28 pm linkquote
chandlerman wrote:
You probably want to re-skim it, as thinly as you can, then sand it with 320 before you prime again. Final prep sanding with 600 grit
What kind of block are you using when you sand? I use a 1/4" thin foam block on rounded panels.
Also, are you using guide coat to help you find low spots?
Even with all that, I still miss spots...
Sanding wet by hand. I'll try it again. Refill, 320 grit, spray it again. This was my guide coat wanted to see if it covered ok and it didn't.
WDC , using this primer. Is this a surfacer too?
https://www.optimasolution.co.uk/aerosols-and-coatings/primer/high-build-primer/
Fri May 13, 2022 5:28 pm
Fri May 13, 2022 5:28 pm linkquote
Jack221 wrote:
Looks great, Jack!
It is.
But if you can source glaze (aka glaze putty/aka glaze compound) you'll have a much easier job of it. Keep in mind that your high gloss clear-coat will highlight every, little, thing.
Glaze is a little spendy! But in terms of time and effort saved it's worth it, vs multiple coats of sandable primer/surfacer, sanding, re-coating.
And btw, sorry if I came off as an arse in my earlier reply...
"I'll use a filler of my choosing."
This a decent part of my day-job. I've got quite a few fillers to choose from here, depending on what I can get away with in the shortest time possible.
Technique here at 3:00. Adheres to bare metal as well.
Fri May 13, 2022 6:00 pm
PX 200
PX 200
Fri May 13, 2022 6:00 pm linkquote
The solvent is getting absorbed differently by the different surfaces. The bare metal vs filler/primer vs existing paint, hence the world map.
This will happen with epoxy primer as well, but a filler primer would level out the finish for a base colour coat to sit perfectly on.
If you aim for a cleaner finish, like CM mentioned you'll aim to finish on at least 320 grit… if not you'll always have scratch marks
Fri May 13, 2022 6:52 pm
Fri May 13, 2022 6:52 pm linkquote
I use 320 to get the filler smooth, then 600 after high-build primer.
And if you really want the clear coat to shine, you'll want to do a wet sand with 600 before you lay down the final coat. It'll be a royal PITA, but the difference will be significant.
When I fixed my GL, the parts I'd sanded with 600 grit before clearcoat were so much glossier than the rest that I had to go back and do the other panels because they looked dull--and I'd though they looked shiny before the comparison!
Tue Jun 07, 2022 10:02 am
Tue Jun 07, 2022 10:02 am linkquote
So close. Been following all your advices. Rubbing, filling, priming, repeat and repeat and repeat. Now its so close. From this shot I filled some tiny pin marks and and given it another coat.
If this dries any good, I'll rub it with 600, give it a last thin prime, 600 again....and we're done. Ready for actual coloured paint. So excited to see if its any good.
Its not going to be any pro job but hopefully good enough until it falls over in the wind or something.
Hopefully this is it.
Pre this last coat of primer...or maybe the one before that
Tue Jun 07, 2022 10:07 am
Tue Jun 07, 2022 10:07 am linkquote
The worst that will happen with a nice, smooth starting point like that is that you'll have to wet sand it to get the color coat nice n' shiny.
Tue Jun 07, 2022 5:12 pm
Tue Jun 07, 2022 5:12 pm linkquote
I posted a while back about how to rattle-can the color coat. Used metallic paint as well, which can be really tricky.
Page 8 on the "how to paint" thread.
One addition (particular to cowls) is ONLY spray perpendicular to the surface, to avoid dripping or orange peel. Kind of like a robot paints a car.
If you can, shoot something else(even cardboard) you don't care about with the same primer, to practice on.
Tue Jun 07, 2022 5:28 pm
PX 200
PX 200
Tue Jun 07, 2022 5:28 pm linkquote
Looks great!
Tue Jun 07, 2022 5:44 pm
Tue Jun 07, 2022 5:44 pm linkquote
Ray8 is the man on advice here, obviously.
I literally taped a piece of cardboard, in a mock spray, and practiced moving the gun and keeping the fake cardboard spray perpendicular to the cowl surface. It's easier said than done.
I literally practiced this for two hours. You heard me right - TWO HOURS, until I felt like I could turn the gun and keep the spray straight, especially on the inside.
After I let my arm have a break, I dialed in the pressure and spray, on a big ass piece of cardboard, purposely going over and under, to see what was what, then went for it.
Your cowl Jack is looking fabulous!
Tue Jun 07, 2022 6:04 pm
P208 Stock Ported Stroker, Stella VMC Stelvio 187, Stella 150, VNX1T, V9A1T, V9B1T
Tue Jun 07, 2022 6:04 pm linkquote
Yeah that is going to look good. You are under selling yourself. Can't wait to see it finished.
Tue Jun 07, 2022 10:06 pm
Tue Jun 07, 2022 10:06 pm linkquote
that cowl looks very good. Nice work. Layers and layers and layers of primer, and sanding, and work. It will pay off.
Wed Jun 08, 2022 10:51 pm
Wed Jun 08, 2022 10:51 pm linkquote
Done. Maybe colour today. Doesn't look quite this good in reality, some slight bumps and a high spot but not filling anymore.
QA Two hours gun practice, if I had a gun I'd do it too. This is just a rattle can job on a piece of cardboard, on the ground in the garden. If the colour nearly matches and doesn't run I'll be happy.
RAY that painting thread only has 4 pages. Is there another one? Might be a gem in there that helps me not screw it up.
CM this is two stage. Should it be shiny after just the colour is on? How many coats of colour should I do? and rub down in between?
Thu Jun 09, 2022 6:50 am
Thu Jun 09, 2022 6:50 am linkquote
Based on my GL, since it's two-stage paint, it should have a sheen about like if it was sanded with 600 grit.
This was the legshield after color coat but before top coat.
Fri Jun 10, 2022 4:52 am
Fri Jun 10, 2022 4:52 am linkquote
We have colour. looks just like yours CM. Right colour but flat. This is coats 1 and 2 below. I sanded between and it went really flat. One more coat of colour and that's it. Should I sand the last coat of colour before clear coat? Or not?
And how many coats of clear?
1st coat not sanded
2nd coat not sanded
Fri Jun 10, 2022 5:24 am
Fri Jun 10, 2022 5:24 am linkquote
I only sand between coats if I've messed up something and need to fix it or gone outside the window for chemical bonding of coats. Re-prepping is just so much work and it stretches out the process significantly.
That being said, I wound up having to re-clearcoat a lot of my GL after the accident because I sanded and then re-clearcoated the mudguard and it was so much glossier than the rest of the bike that I wound up having to do the same to other parts that I wouldn't have done otherwise (and I *thought* it was glossy before the accident!).
Fri Jun 10, 2022 5:31 am
Fri Jun 10, 2022 5:31 am linkquote
Nothing needs sanding due to issues, so I'll leave it. How many coats of clear? With sanding between? Or just until I like it?
Fri Jun 10, 2022 5:33 am
Fri Jun 10, 2022 5:33 am linkquote
I did two coats of color, two coats of clear, but wound up with three from the re-coating after the accident. I think two, then if it needs it, sand and shoot the third is probably the best bet. Others know better than I, though, I'm sure.
Fri Jun 10, 2022 7:27 am
Fri Jun 10, 2022 7:27 am linkquote
Three coats, ten minutes between. No sanding.
First coat should look dull.
Fri Jun 10, 2022 1:11 pm
Fri Jun 10, 2022 1:11 pm linkquote
*Watch this video at around 10:00. Clear-coat lays out differently vs color:
Fri Jun 10, 2022 2:29 pm
Fri Jun 10, 2022 2:29 pm linkquote
Thanks for that. Watched it all. Seems like I did it about right so far. Three coats of colour on but a small bit of fluff got on it, so light rub and do that once more.
Impressive how the clear goes on. Dull paint just wakes up. Mine doesn't have hardener but hopefully shiny enough to match the original paint.
Panel on then it's road test and MOT time. Can't be long now.
Fri Jun 10, 2022 3:42 pm
Fri Jun 10, 2022 3:42 pm linkquote
Base coat is ready usually flat…like inside the trunk of any modern car. It is usually just base coated. Only exterior seems to get clear.
Sat Jun 11, 2022 5:53 am
Sat Jun 11, 2022 5:53 am linkquote
I never thought about that until you mentioned it.
Fri Jul 01, 2022 10:01 am
Fri Jul 01, 2022 10:01 am linkquote
Now, this was way better than expected. Colour match is near perfect. See what Safis means about difficult to paint, some of the metal flakes are in clusters but really need to look closely.
Came out great. Put the 125 badge on now and think the paint job would go un-noticed.
Prefect result, thanks for all the help.
I'm feeling a little smug about painting and might buy a project that needs a whole job, we'll see.
Shiny :)
Fri Jul 01, 2022 2:39 pm
Fri Jul 01, 2022 2:39 pm linkquote
FANTASTIC
Fri Jul 01, 2022 3:20 pm
Vespa
Vespa
Fri Jul 01, 2022 3:20 pm linkquote
Looks great almost better than the OG but probably because it's fresh. Painting requires skill and patience I do not possess.
Fri Jul 01, 2022 4:40 pm
Fri Jul 01, 2022 4:40 pm linkquote
That looks fantastic! The only real tricks to painting are attention to detail and patience. Well, and the ability to follow directions, but that's really just a subset of attention to detail.
There's an extra level of pride for me to have a scoot that not only goes like crazy, but also looks super-sharp while doing it.
Fri Jul 15, 2022 2:46 pm
Fri Jul 15, 2022 2:46 pm linkquote
Took the 172 for a ride today. Jetting in getting better. Still running in. 100 miles done. Long ride out Sunday probably another 100 then.....full thrash begins.
Goes really well. Super zippy up to 50mph. Quickly spotted 70mph a couple of times. Feeling like it will just about do 75mph but we'll see when I can hold it at wot.
Not all good news,when revving the nuts off it on the stand while jetting in. There was a flash of light at 9000rpm and it went dark in the garage. Headlight blew. Haven't checked but suspect the regulator is fine but not up to the job. All electrics are stock. 5 pin regulator with battery and AC lights.
What's the options? Is there any additional regulator I can tack on top to keep the AC voltage down at high rpm?
Fri Jul 15, 2022 3:55 pm
Fri Jul 15, 2022 3:55 pm linkquote
Yeah:
https://www.amazon.com/Trail-Tech-7003-AC01-Universal-Regulator/dp/B00FMVWPKK/ref=asc_df_B00FMVWPKK/?tag=hyprod-20&linkCode=df0&hvadid=241973068692&hvpos=&hvnetw=g&hvrand=8389171071454739019&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061104&hvtargid=pla-494074596478&psc=1
If you can wait, I've got an extra laying around here. DM me your address and I'll send it out to you for $0.
Fri Jul 15, 2022 3:56 pm
Fri Jul 15, 2022 3:56 pm linkquote
Do you have the wiring diagram for your scooter? Maybe a link to one online? Most I have seen have no regulator on AC for lighting.
A lot of options, these are in US, but should give you an idea of what your looking for.
https://www.amazon.com/Trail-Tech-7003-AC01-Universal-Regulator/dp/B00FMVWPKK/ref=asc_df_B00FMVWPKK/?tag=hyprod-20&linkCode=df0&hvadid=241973068692&hvpos=&hvnetw=g&hvrand=2310411215170684514&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9019817&hvtargid=pla-494074596478&psc=1
https://www.ebay.com/itm/391808142028?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=f8IGlM0eTuC&sssrc=2349624&ssuid=&var=&widget_ver=artemis&media=COPY
Sun Jul 17, 2022 7:32 am
Sun Jul 17, 2022 7:32 am linkquote
It's possible a stock regulator wasn't really up to the task of 9,000 RPM's worth of output, especially if it was already hot from dealing with excess load over a period of time.
Also, regulators fail due to cumulative heat damage over time, so it may be that you just finally pushed it over the edge. Replace it and go on.
Mon Jul 18, 2022 4:36 am
Mon Jul 18, 2022 4:36 am linkquote
Think the stock regulator is working fine but just isn't made for 9000rpm. These are only half wave AC on the euro models. An additional regulator on the AC out, maybe even to DC would do it.
The ones Ray and Chris found I can't get in the UK but they would have been just the job. I'll try to find something similar.
SaFiS wrote:
Check this out. I believe this is the one you want...
http://www.chaneysworld.co.uk/sipeflspeedo/vespapx200elestartwiring1.jpg
This is the wiring
Mon Jul 18, 2022 6:04 am
Mon Jul 18, 2022 6:04 am linkquote
I'd contact Anthony Tambs from Scootronics since he's been doing some pretty nice custom regulators, CDIs, etc.
[ Time: 0.0544s ][ Queries: 7 (0.0303s) ][ Debug on ][ 211 ][ Thing One ]
