Sat, 11 Jun 2022 18:55:47 +0000
Moderibbit
Moderibbit
Sat, 11 Jun 2022 18:55:47 +0000 quote
Finally got around to installing an "anti-dive" kit on my et3 (I know Patrick, I know ). I really wish I'd done this sooner - especially riding in stop-and-go traffic around the city all the time, I'm basically in perma-dive mode.
It's amazing what a relatively small change in suspension geometry does for how force is transferred to the shock. My only concern is I'm not sure this would be pleasant with sport suspension - it firms things up a lot on its own, and I feel like I'd probably only want to run it with sport suspension if I was doing a lot of performance riding.
I will say the Carbone instructions, in charmingly poorly-translated English, left a bit to be desired - I actually wound up taking it back apart and putting things together a little differently from the implied procedure in the printed instructions.
I love the cute little briefcase it comes in too
How italian
OG configuration for reference
New configuration, where a new shock support inserts where the rubber cover on the hub used to be
All together
Freaking snoopy is never impressed
Sat, 11 Jun 2022 21:01:58 +0000
VNB VSC o9c VMA vbc vmb VSX
Sat, 11 Jun 2022 21:01:58 +0000 quote
Cool!
Can you take a pic with the carbon fiber dust cover removed next time you are out and have time? I can visualize it I think from the first pic, but want to confirm as I am a bit thick.
Sat, 11 Jun 2022 21:09:41 +0000
Sat, 11 Jun 2022 21:09:41 +0000 quote
NM... found a install pictorial on SC.
https://www.scooter-center.com/media/image/34/93/45/Einbauanleitung_Instruction_.jpg
Sat, 11 Jun 2022 21:16:26 +0000
Sat, 11 Jun 2022 21:16:26 +0000 quote
And here's a video...
https://www.youtube.com/watch?v=Q2XsSTiaeG4
Sat, 11 Jun 2022 21:33:27 +0000
Sat, 11 Jun 2022 21:33:27 +0000 quote
Xantu- you mentioned you wouldn't want it with a "sport"suspension. Does that mean stiff hard race suspension (Bitubo?) or does that mean everyday soft gentle suspension like YSS/ stock?
Sat, 11 Jun 2022 21:40:18 +0000
Moderibbit
Moderibbit
Sat, 11 Jun 2022 21:40:18 +0000 quote
Oh I just meant the bitubo-type stuff sorry. I think it would be OK with the slightly stiffened shocks. Obviously I'm still rocking the stock squishy on this so I can't say for sure - just trying to translate my experiences with different shocks on my p2 and how this might feel (the guy in the video above has a bitubo with it so what do I know )
Sun, 12 Jun 2022 01:34:46 +0000
Sun, 12 Jun 2022 01:34:46 +0000 quote
I can attest, anti-dive OR sport shock. Not both.
Mon, 13 Jun 2022 13:13:01 +0000
64 V90 survivor '65 Allstate survivor. '75 V90 SOLD. '77 P200 SOLD
Mon, 13 Jun 2022 13:13:01 +0000 quote
On the 64 smalldoor I have both a Crimaz anti dive and a Carbone shock set on lowest setting.
It is a little stiff but acceptable since the rear has PLC urathane bushings and another.
For those of you with closed 4 bolt wheels. Also have BGM iron front drum https://www.scooter-center.com/en/front-brake-hub-9-10-bgm-pro-cast-iron-vespa-smallframe-1963-1984-v50-n-v5a1t-v50-s-v5sa1t-v50-l-v5a1t-sr50-v5ss2t-4515-v50-r-v5a1t-752188-v90-v9a1t-3332266
And Newfren AntiAqua shoes.
Very linear braking for a drum. More than enough stopping power fed the Malossi 136 powered scooter.
Mon, 13 Jun 2022 13:58:16 +0000
parallelogramerist
parallelogramerist
Mon, 13 Jun 2022 13:58:16 +0000 quote
Sounds like the exact same for a Lambretta. Either use an anti-dive OR stiff springs, but not both.
Mon, 20 Jun 2022 13:47:25 +0000
Moderibbit
Moderibbit
Mon, 20 Jun 2022 13:47:25 +0000 quote
I just can't get over how much better the scoot rides with this
Tue, 21 Jun 2022 19:58:55 +0000
Tue, 21 Jun 2022 19:58:55 +0000 quote
Thanks I didn't know of this mod, huge improvement for the small frames! Jut ordered the BGM - Crimaz, Carbone … functionally all them seem like perfect clones.
Wed, 22 Jun 2022 10:44:42 +0000
Wed, 22 Jun 2022 10:44:42 +0000 quote
I have a doubt concerning the installation of the anti dive bracket, if anyone can clear it out?
No way to find instructions other than the Carbone version
Am I reading correctly as not to install the 2 original spring washers? is this because of the bracket thickness leaves no room to tighten the nuts with the washers, no danger of loosening?
I guess the pin should be lubed no? sorry the basic questions but this seems a simple job that I'm doing myself, the "Italian like" English translation is not optimal...
Wed, 22 Jun 2022 12:19:04 +0000
Moderibbit
Moderibbit
Wed, 22 Jun 2022 12:19:04 +0000 quote
Correct.
I definitely would. Also note I managed to keep the rubber o-ring on the hub (clutch) side of the front hub pin because it flares around the metal but i could not re-use the rubber o-ring on the hub side of the new rear pin (the clutch side of the shock) - it's the wrong size and prevented the thing from tightening down flush. The pin comes with a grease groove instead so I glooped that up before pushing the shock on
The instructions are bad - I was unable to mount the new pin on the bracket and shock first and hub second. I had to mount it on the hub first, then shock, then had my wife push down a bit on the front with the wheel mounted to get it to line up with the bracket hole.
Wed, 22 Jun 2022 14:39:13 +0000
Wed, 22 Jun 2022 14:39:13 +0000 quote
Thanks for feedback! Cheers
Wed, 22 Jun 2022 23:59:03 +0000
Wed, 22 Jun 2022 23:59:03 +0000 quote
Crimaz had a video posted on Facebook IIRC. Try searching his videos.
Or maybe I was thinking of this one
Thu, 23 Jun 2022 00:35:45 +0000
Moderibbit
Moderibbit
Thu, 23 Jun 2022 00:35:45 +0000 quote
His went together too easily. Just cgi
(Naw it was fine, just took a little cognitive flexibility)
Thu, 23 Jun 2022 02:42:08 +0000
Thu, 23 Jun 2022 02:42:08 +0000 quote
5 minute job max lol
[ Time: 0.0435s ][ Queries: 6 (0.0213s) ][ Debug on ][ 283 ][ Thing Two ]
