-Removed and reinstalled the old shift cross. No change in the sound
-inspected all the teeth of the gears. Nothing nicked or broken.
-noticed a small nick on the inside of third gear. He jammed in third and slid to a stop.
-inspected all the teeth on the primary drive. Can't see anything
-Inspected all the teeth on the cush drive. Dont see anything.
-Removed and reinstalled the clutch with a new woodruff key.
-Removed the clutch cover and pressure plate.
-Removed the rear tire and hub
-Removed the head, cylinder and exhaust during initial rebuild. New piston rings only.
-Kickstart cog inspected. Nothing and reinstalled. Makes the noise even if the kickstart lever is engaged.
-side loaded the crank by pushing on it from the flyside.
After all that and probably more that I forgot, it still makes this banging noise. Watch this video and you'll hear it. Its a little faster than once a second. It used to go away in neutral but now its all the time in every gear.
