Sat, 18 Jun 2022 11:00:26 +0000
Vespa Primavera 50 (sold), 2021 Vespa Sprint 150 (sold), 2022 Sei Giorni 300ie
Sat, 18 Jun 2022 11:00:26 +0000 quote
Back in February, the owner of one of these bikes started this link about their beautiful GTV wondering how many were built:
2016 Vespa GTV 300 i.e Silver/maroon how many were made?
I fell in love. I don't need another Vespa, though I don't have a 300 yet!
I love the way it looks and there aren't that many of them. I should have bought the one listed below, but didn't.
If I find the right one with low mileage will it be just a pretty old 300?
If I could ride one of these older GTV's side by side with a new GTS 300 and the new HPE engine would the difference be dramatic?
PS. I'm just having fun dreaming about a new scooter. Try not to be mad at me for just wanting to talk about a dream. I'm pretending to be rational, but clearly not.
The 2016 GTV that got away
⚠️ Last edited by Billrush on Fri, 04 Nov 2022 19:02:21 +0000; edited 1 time
Sat, 18 Jun 2022 11:17:51 +0000
Sat, 18 Jun 2022 11:17:51 +0000 quote
Yeah get one for sure.
Ditch the 50.
Sat, 18 Jun 2022 11:21:31 +0000
Sat, 18 Jun 2022 11:21:31 +0000 quote
znomit wrote:
Ditch the 50.
The 50 will soon be gone leaving space for something!
PS. For me the 50 was a Gateway drug. It was such an easy way to enter the Vespa world. Relatively low cost and no extra license needed. But once in, I was hooked and wanted more. IMHO, buy a used 50 because you will want another.
Sun, 19 Jun 2022 21:32:30 +0000
GTS super 300
GTS super 300
Sun, 19 Jun 2022 21:32:30 +0000 quote
I've seen it, it is beautiful !!
I am sure you will find one.
Live the dream!!!
⚠️ Last edited by Spirovision on Mon, 20 Jun 2022 01:36:03 +0000; edited 1 time
Mon, 20 Jun 2022 01:30:57 +0000
2016 GTV 300 ABS
2016 GTV 300 ABS
Mon, 20 Jun 2022 01:30:57 +0000 quote
I have this exact 2016 GTV 300, and it's indeed a beauty. I've since had the full Malossi performance upgrade kit installed, and it'll really haul azz now (not that it was slow before - it ran great - I just wanted a bit more oomph). It's sitting at about 9,500 miles now.
Mon, 20 Jun 2022 12:55:02 +0000
300GTS Supertech & 300GTS Touring
Mon, 20 Jun 2022 12:55:02 +0000 quote
That is a stunning color combination....wow....in the sunshine it just pops!
Mon, 20 Jun 2022 13:47:22 +0000
2018 Vespa 300 GTS Touring
Mon, 20 Jun 2022 13:47:22 +0000 quote
There maybe a slight difference in power for the new HPE's over the older GTS's but generally speaking you will not find any major difference in ride quality.
I'd say go for it and take the advanced MSF course so you can enjoy the GTS at higher speeds on the highways.
Tue, 21 Jun 2022 20:20:07 +0000
Tue, 21 Jun 2022 20:20:07 +0000 quote
Just one little scratch.
This is a candidate GTV. But the owner sadly let it fall.
It doesn't look too bad from a distance. The closeup shows the damage and the panel above the seam looks pushed in a bit.
Based upon another post on MV, it looks to me as though this could be touched up well.
Thoughts?
2016 GTV
Sad scrape on right rear panel.
Tue, 21 Jun 2022 20:49:09 +0000
Tue, 21 Jun 2022 20:49:09 +0000 quote
The lower "skirt" panel can easily be removed...a good shop should be able to respray it. Being as it's Silver, I wouldn't expect an exact color match to the original panels....but it should be close.
Wed, 22 Jun 2022 00:16:36 +0000
Wed, 22 Jun 2022 00:16:36 +0000 quote
Another dent another GTV. This one a 2007 GTV 250ie with 4000 miles. The dent was made by the headlight on the front fender. Happened before 2010 with first owner. No reported front end issues.
I suppose I'd have to live with this dent in the leg shield. I'm sure there is no simple fix?
I like the portofino green.
2007 GTV 250
Wed, 22 Jun 2022 00:21:03 +0000
2019 GTS300 Supertech E3 52,000km
Wed, 22 Jun 2022 00:21:03 +0000 quote
by the headlight? I really doubt that ... I'd personally avoid that scoot
Wed, 22 Jun 2022 00:56:05 +0000
Wed, 22 Jun 2022 00:56:05 +0000 quote
Ya got to tell me more!
I'm guessing the headlight because when you see a full picture, the head light would hit at that point and the head light trim ring is cracked there.
Wed, 22 Jun 2022 02:43:16 +0000
2016 GTV300, 2010 GTS300 Super (sold), 2006 LX150 (sold)
Wed, 22 Jun 2022 02:43:16 +0000 quote
I bought one of these last year, it is a beautiful color combo. I got it for a bargain price and rode it the 300kms home on the highway and it handled great. Definitely recommend!
Wed, 22 Jun 2022 02:46:07 +0000
Wed, 22 Jun 2022 02:46:07 +0000 quote
Stored it inside during the winter!
Wed, 22 Jun 2022 09:22:36 +0000
Wed, 22 Jun 2022 09:22:36 +0000 quote
Is the headlight assembly on a gtv plastic? I would guess yes, i know the fender is. Smashing the plastic shell of the headlight assembly against the heavy steel of the legshield wouldn't make a dent like that unless the headlight was pulverised into tiny fragments.
Wed, 22 Jun 2022 09:29:08 +0000
Wed, 22 Jun 2022 09:29:08 +0000 quote
What a beautiful scooter!
Wed, 22 Jun 2022 09:37:38 +0000
Wed, 22 Jun 2022 09:37:38 +0000 quote
You are right. The present owner bought it in 2010 and claims it was that way when he bought it and to not know how it happened.
It does seem odd anyone would buy a scooter with a dent like that and not ask what happened.
Having said that, is that dent really a big deal? It has been serviced by the local Vespa dealer. Does removing the glove box panel expose that dent from the inside?
Wed, 22 Jun 2022 11:45:12 +0000
Wed, 22 Jun 2022 11:45:12 +0000 quote
Although the scoot is probably fine, it's the dishonesty and unknowing what really happened that concerns me. It is also possible that front fork is slightly bent - that's the sorta unknowing that concerns me.
Yes, I'm pretty sure if the glovebox was removed then a panel beater could have a decent go at pushing the dent out.
Wed, 22 Jun 2022 16:10:03 +0000
Wed, 22 Jun 2022 16:10:03 +0000 quote
Steelbytes:
1. I really agree with you. The seller buys a 3 year old Vespa in 2010 with that big dent in the front and didn't find out how it happened from the guy he bought it from? Doesn't make sense! If he's not telling the truth about that, what else isn't true?
2. Is a panel beater a tool?
Cheers
Wed, 22 Jun 2022 16:52:11 +0000
Wed, 22 Jun 2022 16:52:11 +0000 quote
I'd wager that scooter has spent most of it's life with that nasty crease because of the cost and complexity of getting it out. The metal has even split where the crease ends. Keep your money in the bank and wait for a cherished one-owner GTV to come along.
A panal beater is a person who removes dents from car bodies.
Wed, 22 Jun 2022 16:59:57 +0000
Wed, 22 Jun 2022 16:59:57 +0000 quote
I think your earlier alternative with the scratching on the plastic skirt is a better candidate. A dent like that in the monocoque frame is darned near unfixable unless the scooter is torn down, the dent is pushed out and smoothed by a skilled autobody technician, and the scooter repainted. More money than you would want to spend on that bike, and why consider "living with it"? The whole point of a scooter like this is appearance.
And BTW, as steelbytes commented, that dent wasn't made by the headlight nacelle - (a) the nacelle wouldn't dent the body like that, and (b) the nacelle doesn't contact the body when the bike turns. That bike was in some kind of collision, and it hit something (or something hit it) fairly hard.
Wed, 22 Jun 2022 17:53:00 +0000
2020 GTS 300
2020 GTS 300
Wed, 22 Jun 2022 17:53:00 +0000 quote
I have a friend out here in Seattle who just purchased a new GTS, to replace her Silver GTV. It has the Maroon seats, and back rest. Heated grips, and a nice Windshield. I think she may have the original short windshield which came with it.
She is asking $6K, I don't know the miles, but I do know it is always serviced locally and well maintained.
If you are interested I can get you both together and you can talk about it.
Here are some photos of it.
Fri, 24 Jun 2022 11:41:08 +0000
2021 GTS 300 Super (white), 2021 GTS 300 Super (yellow), 1976 Bianchi Snark, 1980 General 5 Star, 2002 Bajaj Chetak
Fri, 24 Jun 2022 11:41:08 +0000 quote
Here's a 2007 model GTV 250 in NJ. I had the pleasure of meeting the owner of this bike several years ago. The bike was absolutely spotless. He's getting up in years now, which is why I assume he has decided to part with it.
https://www.facebook.com/marketplace/item/1385275515303803/
Sat, 25 Jun 2022 09:59:49 +0000
Sat, 25 Jun 2022 09:59:49 +0000 quote
Thanks for this lead. Looks in great shape. Wow he is proud of it considering the $5900 asking price!
Cheers
⬆️    About 18w elapsed between posts    ⬇️
Sun, 30 Oct 2022 23:36:22 +0000
Sun, 30 Oct 2022 23:36:22 +0000 quote
Finally closed the deal on my 2016 silver GTV yesterday. I waited for the right one. Not a scratch. Now I just need to wait for it to be shipped here. Pictures to follow!
Sun, 30 Oct 2022 23:48:45 +0000
Sun, 30 Oct 2022 23:48:45 +0000 quote
make sure to update your profile with the model and year of the new bike!
Mon, 31 Oct 2022 00:44:05 +0000
Mon, 31 Oct 2022 00:44:05 +0000 quote
But of course. After it arrives safely. Also sold the primavera 50. Now the GTV can fit in my garage. Big profile change.
Mon, 31 Oct 2022 05:13:41 +0000
Mon, 31 Oct 2022 05:13:41 +0000 quote
Congratulations on your find. I can't wait for the pictures
Mon, 31 Oct 2022 17:10:12 +0000
2018 Vespa Sei Giorni
Mon, 31 Oct 2022 17:10:12 +0000 quote
I bought a brand new 2018 vespa sei giorni in September and I love it.
Mon, 31 Oct 2022 19:27:47 +0000
Mon, 31 Oct 2022 19:27:47 +0000 quote
Nice looking bike Darrell. How many miles have you put on it? Done anything or added anything? I really like the green color!
Wed, 02 Nov 2022 21:45:58 +0000
Wed, 02 Nov 2022 21:45:58 +0000 quote
I haven't ridden it much yet. I got it in September. It's got 280 miles on it so far. It is stock the way it came from the dealer. Not planning on anything yet to add to it so far.
Wed, 02 Nov 2022 22:17:33 +0000
2009 250 GTS Super
2009 250 GTS Super
Wed, 02 Nov 2022 22:17:33 +0000 quote
I have the 2016 GTV 300 with maroon seats as well, silver.
I bought a black banana style seat with the white piping though, so i no longer have the maroon seats. I sold the maroon seat on eBay. Didnt realize this color combo was desired, or that not many were made.
Wed, 02 Nov 2022 23:04:44 +0000
Wed, 02 Nov 2022 23:04:44 +0000 quote
Show us a picture Noel. Thanks. Mine ships tomorrow. 2700 miles to go!
Thu, 03 Nov 2022 00:44:35 +0000
2009 250 GTS Super
2009 250 GTS Super
Thu, 03 Nov 2022 00:44:35 +0000 quote
Here mine is, before the seat swap to black banana with piping.
When I bought it, the upholsterer was unable to locate fabric that matched the maroon, so i had a mismatched topcase and seat.
I found the maroon split seat to be uncomfortable (pushes you up a bit), so I bought a black w/ piping that matched the top case.
Thu, 03 Nov 2022 04:59:00 +0000
Thu, 03 Nov 2022 04:59:00 +0000 quote
Congrats on the purchase Billrush, I just brought mine inside for the winter 2 days ago.
Thu, 03 Nov 2022 05:06:10 +0000
Thu, 03 Nov 2022 05:06:10 +0000 quote
I think y'all should start your own 'Silver GTV Owner's Club'
Thu, 03 Nov 2022 05:38:12 +0000
Atypical Canadian
Atypical Canadian
Thu, 03 Nov 2022 05:38:12 +0000 quote
The fender mounted headlight isn't for me... but the exposed handlebar - *drools* - yes please!
Thu, 03 Nov 2022 06:10:06 +0000
2009 250 GTS Super
2009 250 GTS Super
Thu, 03 Nov 2022 06:10:06 +0000 quote
i use the front rack. wouldn't your stuff block the headlight if it was on top?
Thu, 03 Nov 2022 06:43:24 +0000
Atypical Canadian
Atypical Canadian
Thu, 03 Nov 2022 06:43:24 +0000 quote
Depends. How high do you stack your stuff? lol
Thu, 03 Nov 2022 06:50:21 +0000
2009 250 GTS Super
2009 250 GTS Super
Thu, 03 Nov 2022 06:50:21 +0000 quote
you only got like 8 inches before it hits the headlight.....
what would you put up there that WOULDN'T hit the headlight
[ Time: 0.0555s ][ Queries: 4 (0.0311s) ][ Debug on ][ 299 ][ Thing Two ]
