Wed, 22 Jun 2022 15:05:16 +0000
Mp3 350 sport 2019
Mp3 350 sport 2019
Wed, 22 Jun 2022 15:05:16 +0000 quote
Hi, the mp3 parking brake is not holding the scooter on a hill very well.
What bolt do I need to tighten for it to become stronger?
Thank you
Wed, 22 Jun 2022 16:44:07 +0000
Wed, 22 Jun 2022 16:44:07 +0000 quote
Thank you
In the picture below, hold the thread circled in blue steady (thin pliers on the end flats will do), and undo the locknut (red circle) a turn or two. Then tighten up the thread into the brake mechanism, until it stops. Now undo it a quarter-turn. Do up the locknut.
This takes care of wear on the handbrake pads, which only happens when you start riding without releasing it. Go more than a few metres and you wear the already thin lining down to nothing.
I'm afraid I'm guilty of doing that many times when I had my Fuoco - went through several sets of pads!
Wed, 22 Jun 2022 17:20:46 +0000
Wed, 22 Jun 2022 17:20:46 +0000 quote
Mine was getting loose (wouldn't hold on a slope). I was able to adjust at the end of the cable to snug it up a bit. Looks like yours has already run out of adjustment at that spot.
Wed, 22 Jun 2022 19:14:23 +0000
Wed, 22 Jun 2022 19:14:23 +0000 quote
That cable adjustment is only to compensate for a stretched cable, not really for worn pads. Adjusting the mechanical caliper is the best way.
[ Time: 0.0268s ][ Queries: 6 (0.0066s) ][ Debug on ][ 276 ][ Thing Two ]
