Anyway, she is beautiful and what a joy to ride!
Unfortunately, the rear left turn signal appears to be out of order... nothing happening... the right side is A-OK. Any thoughts?
![]() 2022 GTS 300 HPE Super, aka Lola
Posts: 59 Location: Palm Springs, CA |
Wed, 22 Jun 2022 21:16:29 +0000
quote
Just took her out for about 30 minutes through Palm Springs. In a bizarre coincidence I got her home just before a huge thunderstorm rolled through, which is fairly unusual here...
Anyway, she is beautiful and what a joy to ride! Unfortunately, the rear left turn signal appears to be out of order... nothing happening... the right side is A-OK. Any thoughts? ![]() ![]() ![]()
Highly Rated
Wed, 22 Jun 2022 21:19:35 +0000
2020 primavera 150
Posts: 423 Location: Lorton virginia |
2020 primavera 150
quote
Beautiful. check to make sure tire did not hit tail light wires as this was a problem on early models.
![]() 2015 GTS 300 Super (Melody: 2015-2021, RIP), 2022 GTS SuperTech (Thelonica; bit the dust 02-22-23)
Posts: 3910 Location: Asbury Park, NJ |
Wed, 22 Jun 2022 21:53:41 +0000
quote
L-O-L-A, Lola, la-la-la-la, Lo-laaaa…
Oh, she's gorgeous. The beginning of Good Stuff. (Might want to check the bulb; burnt-out or, more likely, might've come loose from its socket.) EDIT: Okay, had to add this, couldn't help it… Last edited by amateriat on Thu, 23 Jun 2022 02:06:22 +0000; edited 2 times |
Wed, 22 Jun 2022 22:01:19 +0000
2020 primavera 150
2020 primavera 150
quote
My favorite color as I had 2 red ones before and got a lot of compliments.
![]() 2018 Vespa 300 GTS Touring
Posts: 1305 Location: NYC |
Wed, 22 Jun 2022 22:09:18 +0000
quote
Congratulations.
She looks gorgeous. Did I read it right, 8 miles on the odometer. Im envious of that beautiful garage space.. |
Thu, 23 Jun 2022 00:03:43 +0000
quote
thanks everyone... I have the dealer looking into fixes... funny how they all seem to look to Robot on YouTube for advice...
I had a hard time deciding on color because quite frankly they are all beautiful, but I am VERY happy with the red This is my first Vespa and I am loving it already... |
Thu, 23 Jun 2022 00:06:38 +0000
quote
baba12 wrote: Congratulations. She looks gorgeous. Did I read it right, 8 miles on the odometer. Im envious of that beautiful garage space.. ![]()
Positive
![]() Thu, 23 Jun 2022 00:12:52 +0000
2019 GTS300 Supertech E3 50,000km
Posts: 4039 Location: Batmania aka Melbourne, Australia |
![]() 2019 GTS300 Supertech E3 50,000km
quote
SlyDanner wrote: here's an even rounder number |
Thu, 23 Jun 2022 00:45:42 +0000
2020 primavera 150
2020 primavera 150
![]() Thu, 23 Jun 2022 00:53:30 +0000
GTS super 300
Posts: 333 Location: Montreal Canada |
![]() GTS super 300
Thu, 23 Jun 2022 01:36:50 +0000
lx150/et-4
Posts: 124 Location: otherdesertcities, ca |
lx150/et-4
quote
Welcome to the desert. As mentioned in other posts:
1.tryswapping the bulb with the right side bulb. That might indicate if bulb or socket is not good. 2.Red is faster Enjoy…but avoid afternoon rides when upcoming temps are forecast To be about 110* |
Thu, 23 Jun 2022 02:22:44 +0000
quote
steelbytes wrote: so didn't your dealer test ride it? I'm more annoyed they did not catch the turn signal issue. But, first world problems. |
![]() 2018 GTS 300 Touring Rosso Vignola, 2020 BV 350 Matte Green, 1956 VL3
Posts: 1156 Location: Herriman, Utah |
Thu, 23 Jun 2022 03:04:20 +0000
quote
amateriat wrote: L-O-L-A, Lola, la-la-la-la, Lo-laaaa… Oh, she's gorgeous. The beginning of Good Stuff. (Might want to check the bulb; burnt-out or, more likely, might've come loose from its socket.) EDIT: Okay, had to add this, couldn't help it… |
![]() GT 2.4
Posts: 8407 Location: NWAOK |
Thu, 23 Jun 2022 03:04:41 +0000
quote
steelbytes wrote: so didn't your dealer test ride it? Seriously, the left turn signal issue should have been caught in the Set-up, where they go over a checklist as they take it out of the crate and put it together, or Pre-delivery inspection, when they went over the bike with the buyer and showed them that everything was working. And the 0 miles is something I've not seen. Right out of the crate, bikes usually have a mile or so on them from being pushed around the factory before they take it apart and stick it in a box. And the dealer set up involves a real road test, not a short jaunt around the parking lot. I would take it out for a spin and make sure the odometer works. Might as well check the oil too. Corners were cut. The OP should have a predelivery inspection sheet that shows all the systems were working. I would go over that again and see if someone signed off on the indicators.
Positive
![]() Gigi, '13 GTS 300ie Touring
Posts: 2871 Location: Phoenix, AZ. |
Thu, 23 Jun 2022 03:07:04 +0000
quote
Congrats on your beautiful scoot and the rain. Keep the cooler temps but send the rain here, please.
Thu, 23 Jun 2022 03:13:35 +0000
quote
SlyDanner wrote: https://www.youtube.com/watch?v=A7_Lg5dd_9g Goes well with the Red Lola we have in the desert .. |
![]() Thu, 23 Jun 2022 05:16:09 +0000
Posts: 2071 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
quote
A little known fact. Ray Davies of The Kinks originally wrote the song using 'Coca-Cola' in the lyrics. The BBC refused to play the record because of their strict policy at the time against product placement.
Unaware of this, The Kinks released the record and went on a U.S. tour. On hearing of the BBC ban, Ray Davies had to quickly make a 6,000 mile round trip back to London to re-record the track using the lyrics 'Cherry-Cola' instead. |
Thu, 23 Jun 2022 05:53:15 +0000
quote
Touring300 wrote: A little known fact. Ray Davies of The Kinks originally wrote the song using 'Coca-Cola' in the lyrics. The BBC refused to play the record because of their strict policy at the time against product placement. Unaware of this, The Kinks released the record and went on a U.S. tour. On hearing of the BBC ban, Ray Davies had to quickly make a 6,000 mile round trip back to London to re-record the track using the lyrics 'Cherry-Cola' instead. |
![]() 2021 GTS 300 Supersport, Triumph Tiger 800
Posts: 377 Location: Oxford, UK |
Thu, 23 Jun 2022 08:45:07 +0000
quote
SlyDanner wrote: They did, basically a systems check ride around their parking lot. Not enough to click the odo past zero. I'm more annoyed they did not catch the turn signal issue. But, first world problems. |
![]() Thu, 23 Jun 2022 09:01:56 +0000
ET3 & PX150 & GTS 300 Super Sport
Posts: 1815 Location: Berlin |
![]() ET3 & PX150 & GTS 300 Super Sport
![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 3979 Location: Kingdom of Lanna |
Thu, 23 Jun 2022 15:57:25 +0000
quote
Der Blechfahrer wrote: Is that a red toilet in your garage? |
Thu, 23 Jun 2022 17:36:31 +0000
quote
Lovely bike - red is definitely my favourite in the Super trim.
That pink lifesaver in the background - is that in case it rains a bit too much? |
Thu, 23 Jun 2022 17:46:43 +0000
quote
OscarSass wrote: Lovely bike - red is definitely my favourite in the Super trim. That pink lifesaver in the background - is that in case it rains a bit too much? |
![]() LX150, GTS250
Posts: 378 Location: Banning, CA |
Thu, 23 Jun 2022 19:52:17 +0000
quote
A nice ride to take not to far from your area is the Palms to Pines highway. I've done it once and it was an amazing ride. Bring a jacket just in case Idyllwild is cold on that particular day.
Nice Vespa! My first Vespa, an LX150, is red. |
![]() Fri, 24 Jun 2022 00:30:01 +0000
Posts: 3259 Location: Minneapolis USA |
![]() 2013 Vespa 300 Super, 2022 Kymco AK 550
quote
Dragon Red super looking Vespa. Enjoy the road and be safe.
I drove mine down to AmeriVespa today in Minneapolis. Bob Copeland Minnesota ![]() |
Fri, 24 Jun 2022 00:55:40 +0000
quote
Bob Copeland wrote: Dragon Red super looking Vespa. Enjoy the road and be safe. I drove mine down to AmeriVespa today in Minneapolis. Bob Copeland Minnesota |
![]() Fri, 24 Jun 2022 17:00:26 +0000
quote
Slydanner,
The seat is actually a cover from a company called Cheeky Seats. You can go online and see all the different covers for your exact Vespa. Very responsive service orientated company. I think they can also do a custom cover that you design. Mine was $100 - with this bad inflation, they may be more now. Just fits snuggly over your current seat. I liked the black and white checked seat with my Dragon Red GTS300. I have the same seat as yours under my Cheeky Seat. Bob Copeland ![]() |
Fri, 24 Jun 2022 19:45:06 +0000
quote
Update on my rear turn signal issue.
This goes in the category of 'you can't make it up'. Dealer van shows up to my house and before I roll Lola over to have her brought back for a check, I decide to try one last time. Whaddya know - it works. I have no explanation and before anyone calls me crazy, trust me the thought has crossed my own mind. I will obviously keep a close eye on it. |
![]() Fri, 24 Jun 2022 20:01:24 +0000
quote
Probably the bulb not seated quite correctly inside the bulb holder. Just remove the indicator pod and give it a jiggle.
