Tue Jun 21, 2022 7:06 pm
2016 Mp3 500ie Sport
Posts: 132 Location: California |
Welcome to the club!
The Mp3 may not be the fastest bike out there but its a beast in the twisters and plenty of cargo. This form is full of mods and info including * LED headlights * EVAP Canister removal * Tires and wheels * Break-Fix * So much more. If you have a question just check the forums as someone has probably already answered it and if not then we're a helpful bunch and support eachother. |
Fri Jun 24, 2022 3:19 pm
Piaggo Tool Kit C-Spanner Sources
The only really valuable thing in the tool-kit is the C-Spanner that is bent 90 degrees. This allows you to adjust the suspension spring that is otherwise covered by the exhaust. Without this tool you would have to remove the exhaust in order to access and adjust the spring tension. The rest of the toolkit is a mix of #15 and #20 (#25?) torx drives, a fixed crescent wrench, and a spark-plug / tire-lug tool. Most everything else in the tool-kit can be done with regular off the shelf hardware store tools (in metric) The tool kit I carry with me on most trips is extensive as I like to be able to self-rescue. I can list it all out here if you want but really you have to tailor it a bit for what and where you ride.
Positive
![]() 2020 MP3 500 HPE Sport ABS/ASR
Posts: 4406 Location: El Pueblo de Nuestra Señora Reina de los Ángeles sobre el Río Porciúncula |
dariusz wrote: Hi, thanks for the answer. Are you sure? My 2007 come with, but I read in some part that the post 2020 don't come with tools, only with the one to adjust the shock absorbers |
I to have a bad habit also of carrying half my workshop tools for nothing
![]() pinheadh78 wrote: Piaggo Tool Kit C-Spanner Sources The only really valuable thing in the tool-kit is the C-Spanner that is bent 90 degrees. This allows you to adjust the suspension spring that is otherwise covered by the exhaust. Without this tool you would have to remove the exhaust in order to access and adjust the spring tension. The rest of the toolkit is a mix of #15 and #20 (#25?) torx drives, a fixed crescent wrench, and a spark-plug / tire-lug tool. Most everything else in the tool-kit can be done with regular off the shelf hardware store tools (in metric) The tool kit I carry with me on most trips is extensive as I like to be able to self-rescue. I can list it all out here if you want but really you have to tailor it a bit for what and where you ride. |
The tools are hiding under the mat in the pet carrier
The shock tool will help you take off the gas cap, a small dab of never sieze on the threads helps The original owner of mine removed the strainer from the gas tank inlet, I think it makes it easier to fill, still far too easy to make a gas splash when filling Drill out the rivets for the evap, clip the hoses Start it put you finger over each hose, plug the one with vacuum, shove the open one out of the pet carrier so the fumes vent between the panels To increase trunk space |
