Posts: 3449 Location: Florence, OR |
Sun, 03 Jul 2022 17:30:08 +0000
quote
I knew you'd find it. I'm just glad you didn't need to split the cases again
![]() Sun, 03 Jul 2022 17:33:27 +0000
Posts: 7156 Location: Nashville |
quote
qascooter wrote: I knew you'd find it. I'm just glad you didn't need to split the cases again ![]() What I really want to do is get the Smallie going, but that means clearing up my backlog of largeframe projects first. And money. Lots of money for what I'm planning... |
![]() Sun, 03 Jul 2022 19:55:37 +0000
quote
I think that I can now officially tick "fixing the GL" off the list.
Positive
![]() Sun, 03 Jul 2022 20:28:12 +0000
Posts: 3236 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
chandlerman wrote: Digging in on electrical, I swapped the plug to start. No difference. I'm apparently out of spare new plugs, so I had to see which of the random used plugs I had would work. This was not all bad, because it caused me to throw out the various fouled plugs that I've never thrown away because I'm a hoarder. With a Known Good plug, I finally got to timing. I had to re-mark the cases and flywheel, but once I did, I put the gun on it and...it was firing at TDC at 5,000 RPM's. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() (That's one ![]() So whoever had "timing set to TDC" in the betting pool can claim their prize. Naturally, while I was adjusting the stator, the first rain in two weeks decided to roll in, so now I'm waiting out the thunderstorm to see if that's fixed it, but my gut is that it has. |
![]() Sun, 03 Jul 2022 21:24:41 +0000
quote
Christopher_55934 wrote: You were so close to having a scooter that ran backwards only needed a few more degrees. |
Mon, 04 Jul 2022 02:43:49 +0000
quote
chandlerman wrote: I think that I can now officially tick "fixing the GL" off the list. 2 down, 1 to go Time it takes for parts to arrive for the smallie. You can start your saving plan now… ![]() |
![]() Mon, 04 Jul 2022 03:31:27 +0000
quote
I was thinking egig 170 for the Smallie, but the cylinders are sold out and the cranks are stupid-expensive, so I'm back to evaluating my options. I'm interested in the egig one-finger clutch, too.
But it's going to be a reed valve screamer, whatever I do. Maybe I'll splurge for a PipeDesign exhaust. |
Mon, 04 Jul 2022 04:33:36 +0000
quote
chandlerman wrote: I was thinking egig 170 for the Smallie, but the cylinders are sold out and the cranks are stupid-expensive, so I'm back to evaluating my options. I'm interested in the egig one-finger clutch, too. But it's going to be a reed valve screamer, whatever I do. Maybe I'll splurge for a PipeDesign exhaust. Oh don't skimp on the clutch basket… even if the basket on mine wasn't trashed, I think it wouldn't have took long to trash it… There's no competition between the pressed basket vs CNC basket. It's light years ahead in terms of construction. Just the thickness of materials is evident. But doing the maths… it still works out cheaper than a largeframe CNC clutch and it's better design. No wonder those German and Italian companies work on so many smallframe parts…!! |
![]() Parmakit Primavera -74, Polini Primavera -68, Stock 150 Touring -59, VMC 177 Bajaj Chetak 125 -95
Posts: 504 Location: Finland |
Mon, 04 Jul 2022 05:42:03 +0000
quote
chandlerman wrote: I was thinking egig 170 for the Smallie, but the cylinders are sold out and the cranks are stupid-expensive, so I'm back to evaluating my options. I'm interested in the egig one-finger clutch, too. But it's going to be a reed valve screamer, whatever I do. Maybe I'll splurge for a PipeDesign exhaust. https://www.10pollici.com/en/homepage/classic-vespa/engine/cylinders/smallframe/racing-cylinder-vmc-135cc-et7-58x51-aluminum-booster-outlet-vespa-smallframe-side-spark-plug-2-piston-rings.2.1.25.gp.9466.uw Sounds good to me: https://www.lambretta-teile.de/Clutch-complete-LTH-Hartz-43-Vespa-V50-PV-PK-XL2 ![]() ![]() |
Mon, 04 Jul 2022 05:53:36 +0000
quote
FINYoshi wrote: I'd go one step further on the clutch. Get the Hartz 4 if you possibly can. With the Hartz, which engine cases are you using? V50 or primavera? Does it rub on tire with the extra spacer if it's 3.00 tire? |
Mon, 04 Jul 2022 07:07:54 +0000
quote
Primmy cases for me with PK XL2 clutch cover. The XL2 cover with geared actuator is not needed with this clutch though.
It needed the clutch cover to be spaced out a tad with the supplied spacer and I made my own shims behind the brake plate and wheel hub to get them out 1mm. Detailed installation instructions writeup can be found here: https://vespasmallframeforum.proboards.com/thread/23950/installing-hartz-4-clutch |
Mon, 11 Jul 2022 20:47:29 +0000
PX Vespa 125
Posts: 26 Location: Moira |
quote
You know what I have got the same problem with the 3)4 gear's slipping in and out my front wheel lock up but Hay l just kept pushing on for about 200 yards or so and I believe it is the clutch burnout. Hopefully a new plates may solve it just need to try and find a way to do it ✊
![]() Mon, 11 Jul 2022 21:10:04 +0000
quote
I was expecting that I'd find bent tabs on the clutch plates as a big part of the problem, but it was definitely the excess gear play and cruiciform replacement that finally fixed it.
Tue, 12 Jul 2022 15:50:46 +0000
PX Vespa 125
quote
YER MAN just what I was thinking about and now I am starting to get the right plates ! and that seclusion part 👍 nice one l will get one of them as well ✊
![]() Sat, 16 Jul 2022 01:15:28 +0000
quote
I added some indicator LED's to my dash plate tonight. This will hopefully reduce the amount of time I spend cruising down the road oblivious to the fact my blinker has been on since I last turned.
Positive
![]() Sat, 23 Jul 2022 16:08:49 +0000
Posts: 346 Location: San Francisco Bay Area |
![]() 1979 P200, 1960 Lambretta s2, 1975 Rally 200
![]() Sat, 23 Jul 2022 16:35:17 +0000
quote
Cdevillasante wrote: What's that speedo stuff? See the trail tech nearby….. The trailtech is a tach, and mostly out of frame in the bottom right is a Koso CHT. |
