Sat, 09 Jul 2022 19:53:37 +0000
px 125 disc
px 125 disc
Sat, 09 Jul 2022 19:53:37 +0000 quote
Hi all
I have arthritis in both wrists and the px levers do sit at awkward angles, so 2 questions.
Firstly can i change the angle of the shift grip simply by adjusting the cables i.e so 1st is where neutral is and prorata so that the clutch lever id 'flatter' in 1st or is there another way?
And secondly is there a way to move the disc brakes lever 'down' without major surgery?
( I'm finding my fingers keep catching on the underside of the lever when I go to use the front brake)
Only idea I've come up with so far is a plate to drop it lower relative to the handlebar.
Sat, 09 Jul 2022 21:00:51 +0000
Sat, 09 Jul 2022 21:00:51 +0000 quote
Never liked the way the brake master cylinder sits that's why I always convert a drum handlebar to disc by welding a plate at an angle. SIP does a brake master cylinder that has the lever at an angle so it's a direct fit without modifying your handlebars. As for the gear side, yes you can play with the cables…
Aluminum…
https://www.sip-scootershop.com/en/product/brake-master-cylinder-sip-disc-brake-front-right_56370000
Black…
https://www.sip-scootershop.com/en/product/brake-master-cylinder-sip-disc-brake-front-right_56371000
Sat, 09 Jul 2022 21:17:44 +0000
px 125 disc
px 125 disc
Sat, 09 Jul 2022 21:17:44 +0000 quote
[quote="SaFiS"]
Aluminum…
Black…
[/quote
Thank you Safis will have a play with the cables in the morning.
Sun, 10 Jul 2022 21:15:22 +0000
Sun, 10 Jul 2022 21:15:22 +0000 quote
andyx wrote:
Hi all
A big advantage to you is that you have a cosa clutch in your scoot as standard . You wouldn't cope with earlier clutches and when I get rsi from too much computer work my pk xl clutch which has a reinforced heavy duty spring in it can make me whelp with pain after a 10 mile run out.
Mon, 11 Jul 2022 21:19:32 +0000
px 125 disc
px 125 disc
Mon, 11 Jul 2022 21:19:32 +0000 quote
Agree it is light, its just the angle my wrist is at when plonking it into 1st is painfull, oh the joys of growing old disgracefully
Mon, 11 Jul 2022 22:12:18 +0000
Mon, 11 Jul 2022 22:12:18 +0000 quote
You could:
Disconnect the cables at the shifter box.
Tape the lever to 2nd at the headset.
Adjust cables with the batwing in neutral.
1st gear now lines up with the neutral mark, etc.
Mon, 11 Jul 2022 22:18:03 +0000
px 125 disc
px 125 disc
Mon, 11 Jul 2022 22:18:03 +0000 quote
Ray8 wrote:
You could:
Thanks Ray, Thats the next job as soon as I've sorted the jammed front brake and the battery not charging, should keep me out of mischief lol
Mon, 11 Jul 2022 22:43:38 +0000
Mon, 11 Jul 2022 22:43:38 +0000 quote
Just skip first!
May have to upgrade your top end for that though…
I have a similar issue where first just plain sucks to use so I just stopped using it and start from 2nd instead. My first gear is pretty useless already though.
Tue, 12 Jul 2022 05:32:15 +0000
px 125 disc
px 125 disc
Tue, 12 Jul 2022 05:32:15 +0000 quote
FridayMatinee wrote:
Just skip first!
Could you clarify that Friday Matinee? What do you mean by upgrade?
Tue, 12 Jul 2022 13:49:50 +0000
Tue, 12 Jul 2022 13:49:50 +0000 quote
177cc. More power so first gear is obsolete more or less is what I meant. Sorry I should have clarified
Wed, 13 Jul 2022 13:05:35 +0000
px 125 disc
px 125 disc
Wed, 13 Jul 2022 13:05:35 +0000 quote
Aluminum…
Black…
[/quote
wow thats a bit of a premium 100 quid over standard for 20 deg drop, but in the absence of anything else looks like the bank balance is going to take a hit.
Wed, 13 Jul 2022 20:03:04 +0000
px 125 disc
px 125 disc
Wed, 13 Jul 2022 20:03:04 +0000 quote
Not a problem, have just adjusted the cables second is now neutral etc.
I've just got to remember that, may have to remark the handle bar to suit as a reminder.
Thanks to all for your help, just the front brake lever to sort now
Wed, 13 Jul 2022 20:05:19 +0000
px 125 disc
px 125 disc
Wed, 13 Jul 2022 20:05:19 +0000 quote
andyx wrote:
Not a problem, but I need all 4 gears for pulling the side car that will be attached in the future.
I have just adjusted the cables second is now neutral etc.
Thu, 14 Jul 2022 09:52:03 +0000
px 125 disc
px 125 disc
Thu, 14 Jul 2022 09:52:03 +0000 quote
Adjusted the gear change this morning so that 'second 'is now neutralgiving me a 'flatter' clutch lever when in 1st.
Took it for a ride, its so much more comfortable very gldd I've done it.
Thanks for all the advice. from you lovely lot, its appeciated.
Thu, 14 Jul 2022 09:56:35 +0000
px 125 disc
px 125 disc
Thu, 14 Jul 2022 09:56:35 +0000 quote
Just to summarise how I did it. (Ray 8 you nailed it)
Slackened off both gear cables completely.
put the bar lever in '2nd', taped gear change in place.
Clamped cables back into position, using adjusters to fine tune.
Job Done.
Thu, 14 Jul 2022 13:08:27 +0000
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Thu, 14 Jul 2022 13:08:27 +0000 quote
For audit purposes you should put a "FOR REFERENCE ONLY" sticker on the shifter.
Sorry, just the metrologist in me acting out.
Thu, 14 Jul 2022 13:19:38 +0000
px 125 disc
px 125 disc
Thu, 14 Jul 2022 13:19:38 +0000 quote
the way I look at it, if someone trys to ride it a way, it'll confuse the hell out of them
[ Time: 0.0439s ][ Queries: 4 (0.0145s) ][ Debug on ][ 276 ][ Thing Two ]
