Mid summer this started playing up and I lost interest in it for a while. When originally built I didn't split the engine and just bolted the kit on to run in. The engine only had about 8,000 miles on it, so thought I would get away with it. I didn't, clutch side oil seal started passing.
I wanted to upgrade it anyway and just brought the plan forward. P200 23/65 primary. P200 bell crank and 6.0mm packer. Exhaust port raised 1.9mm. As well as clutch parts, cruciform, seals etc.
VHSH30 and Bullet177 exhaust as before.
Was a straightforward split and build. Got it going a few months ago and it's great. Before as a 172 it was fine. 22/68 primary and was good for a solid 72mph when held out. Uphill, into wind, anywhere. Lots of torque and comfortable to ride. Now, as a 181 with much higher port timings, it's awake. Accelerates briskly and has topped out at 78mph so far, with possibly a little more to go. If we had 80 on 10s stickers I'd be going for one. Hasn't lost much torque. Will still roll on to over 60mph in 4th up the same big hills. Timing 19 degrees static and squish 1.0mm. Jetting about done and so far so good.
