Thu, 25 Aug 2022 12:26:50 +0000
Thu, 25 Aug 2022 12:26:50 +0000 linkquote
Greetings from Colorado!
1st post and I'm sure many more to come.
I misplaced the OEM washers when removing my mirrors. Anyone out there know what part numbers they are and where to buy?
Thank you!
Thu, 25 Aug 2022 23:52:44 +0000
2019 Supertech (EURO3/APAC 38,000km)
Thu, 25 Aug 2022 23:52:44 +0000 linkquote
from the Elettrica parts list. expect would match the Primavera
https://www.af1racing.com/ProdImages/st3/EVE5000US4.pdf
Fri, 26 Aug 2022 01:20:36 +0000
Fri, 26 Aug 2022 01:20:36 +0000 linkquote
You could go down to your local hardware store with one of the mirrors and get a washer and lock washer for both sides
Fri, 26 Aug 2022 01:26:56 +0000
2012 LX150ie
2012 LX150ie
Fri, 26 Aug 2022 01:26:56 +0000 linkquote
Tierney, that's what i would do.
Fri, 26 Aug 2022 01:32:55 +0000
Fri, 26 Aug 2022 01:32:55 +0000 linkquote
Thanks for replies! I'll head to my local hardware store. 👍
Fri, 26 Aug 2022 03:11:33 +0000
2018 Primavera 150, 2015 Sprint 150, 2018 GTS 300
Fri, 26 Aug 2022 03:11:33 +0000 linkquote
If you have an Ace Hardware in your area they have an excellent nut, bolt and fasteners section
Fri, 26 Aug 2022 06:35:17 +0000
GT 2.4
GT 2.4
Fri, 26 Aug 2022 06:35:17 +0000 linkquote
I'm pretty sure it's an 8mm washer, the kind you can buy in a pack of five for $1 or in Piaggio packaging for $9 each.
Fri, 26 Aug 2022 12:17:39 +0000
Fri, 26 Aug 2022 12:17:39 +0000 linkquote
I do. Thank you!
Fri, 26 Aug 2022 12:18:12 +0000
Fri, 26 Aug 2022 12:18:12 +0000 linkquote
Thanks. I appreciate the info. I just took a measurement and it is indeed 8mm.
Thu, 22 Sep 2022 07:42:37 +0000
Thu, 22 Sep 2022 07:42:37 +0000 linkquote
I was sorting my boxes of Vespa bits and pieces and found the original mirrors that came with my supertech, with them were two unopened little bags of two washers each - one silver plain and one black domed. Why did i have these? Because i didn't like the mirrors on my supertech when i bought it as they were shorter than my old gts but i did like the newer style. So i had bought some mirrors that were for a 2015(?) Primavera that have the new style but old length and also have reverse thread on the left. Perfect, i was happy. The new mirrors had come with washers in little bags that have never been used. So since I'd always had issues with my mirrors coming loose when bouncing along bad roads, I've today switched to these washers from the bags. Hopefully they'll not come loose now
[ Time: 0.0245s ][ Queries: 6 (0.0028s) ][ Debug on ][ 240 ][ Thing Two ]
