You can find a non p side stand or a Mrp main stand offset on SIP and order from Mercato to avoid crazy shipping cost.
http://www.scootermercato.com/Scooter-Parts/Vintage-Vespa-Parts/SIP-Part
![]() GL, PK, PE200 with hack, Sears Rust Badge
Posts: 1341 Location: Deep in the heart of Texas |
Tue, 25 May 2021 04:06:10 +0000
quote
http://www.scootermercato.com/Scooter-Parts/Vintage-Vespa-Parts/SIP-Part |
Tue, 25 May 2021 05:13:13 +0000
quote
FNG wrote: My SIP Road 2 fits nicely but I haven't gone 2up with it yet. |
![]() Tue, 25 May 2021 13:04:46 +0000
Posts: 3237 Location: Rochester, Minnesota |
![]() 2007 Stella 225
![]() 1960 Allstate VNA, 1962 VNB
Posts: 227 Location: Cambria, CA |
Thu, 27 May 2021 15:39:18 +0000
quote
rowdyc wrote: You can find a non p side stand or a Mrp main stand offset on SIP and order from Mercato to avoid crazy shipping cost. http://www.scootermercato.com/Scooter-Parts/Vintage-Vespa-Parts/SIP-Part I found the side stand in stock at Marcato. So that will get me going next week sometime. Also I ordered the MRP main stand offset from ScooterSpeed. I think this is the option I will end up using but I'll decide after looking at both. |
Thu, 03 Jun 2021 04:14:00 +0000
quote
I got home from work today and the side stand had arrived from Mercato.
After wrestling with it for a while I finally finished the install and it was time for a ride. First ride with the sprint veloce cases, VMC 177 Stelvio, Pinasco 24 ER carb Pinasco ignition and Polini box exhaust. I took it easy to break it in but boy does it feel fast. This thing is going to go. I did suffer one setback. It blew the pilot light, headlight and tail light. I must have some wires connected to the regulator incorrectly. It got dark so I had to stop playing with it. Time to order more 12v bulbs. Not sure why I didn't order more than 1 set in the first place. |
Sun, 11 Sep 2022 19:33:33 +0000
quote
My shift housing on my VNB is touching on the exhaust and melting slightly.
Is my housing too long or did I route it incorrectly? Thank for your help. ![]() |
Posts: 12559 Location: The state of insanity, SoCal |
Sun, 11 Sep 2022 20:16:46 +0000
quote
pull the locating bracket up and out a little and that should give you the clearance you need.
Posts: 6632 Location: So Cal |
Mon, 12 Sep 2022 06:14:31 +0000
quote
No, that ain't right. The cables go behind the pipe. It should be more or less a straight shot from the frame. No big wavy bends in the cables.
Mon, 12 Sep 2022 06:21:13 +0000
quote
SoCalGuy wrote: No, that ain't right. The cables go behind the pipe. It should be more or less a straight shot from the frame. No big wavy bends in the cables. yeah, socal is right- behind the pipe on the small block. |
![]() Mon, 12 Sep 2022 14:01:30 +0000
Posts: 7159 Location: Nashville |
quote
TIL I have the shift cables run wrong on every bike I own.
Positive
Tue, 13 Sep 2022 01:28:52 +0000
quote
SoCalGuy wrote: No, that ain't right. The cables go behind the pipe. It should be more or less a straight shot from the frame. No big wavy bends in the cables. It looks much better now. ![]() |
Sun, 20 Nov 2022 21:36:19 +0000
quote
On yesterday's SLO county ride someone told me that my fork is bent.
I thought it just looks wrong because of the repop mudguard. What do you guys think? ![]() |
Mon, 21 Nov 2022 03:40:11 +0000
quote
SoCalGuy wrote: Is the mud guard rubbing against the leg shield? |
![]() Mon, 21 Nov 2022 16:22:53 +0000
quote
If it's bent, it's not bent much, or not bent in line front-to-back.
It's actually easier to tell in a picture like that if you can see the headset, too. And for side-to-side bent (like when it gets bent with the wheel over while parked), take a picture from the front and you can see it that way. |
Tue, 22 Nov 2022 05:39:33 +0000
quote
chandlerman wrote: If it's bent, it's not bent much, or not bent in line front-to-back. It's actually easier to tell in a picture like that if you can see the headset, too. And for side-to-side bent (like when it gets bent with the wheel over while parked), take a picture from the front and you can see it that way. I'll get some better pictures on Wednesday. |
