Thu, 06 Oct 2022 16:45:27 +0000
Thu, 06 Oct 2022 16:45:27 +0000 quote
sdjohn wrote:
well the new crank arrives today - perhaps we'll measure before installing for science
Yes, please do!
Thu, 06 Oct 2022 17:14:37 +0000
Thu, 06 Oct 2022 17:14:37 +0000 quote
FINYoshi wrote:
The one used on the video above has bearings to roll the crankshaft on. I don't like this because bearings always have their tolerances and play which adds unnecessary uncertainty to the measurement. V-shape wedge is better and if you are worried about leaving a slight marks on your crank bearing necks, you can add a strip of softer metal to the edge. This should not be necessary though, because you will not be spinning the crank on the stand (at least hopefully) for thousands of revolutions. Smooth surfaces on the V with dab of oil and you are golden.
1. Make it beefy enough - you don't want to guess if you have flex
2. No need to make it very tall unless you want to use if for some static balancing action
3. Adjustment for crank width is nice to have
4. Get two dial gauges with mounts to see both sides of the crank at same time
My vision of a stand coming together. Still going to shape the ends like V and line them with some softer metal like brass. Plate is big enough to comfortably mount magnetic stands for dial indicators and there is a possibility to drill additional holes to accomodate almost any crank. If one side has a bearkng sleeve, washers can be applied under the holding arms to compensate.
Thu, 06 Oct 2022 18:17:27 +0000
Thu, 06 Oct 2022 18:17:27 +0000 quote
I managed to get it within +/- .001" (about 0.002" total) on each far end by using the video above. Is that good enough? It's a lot closer than it was. For now, it seems each side is asking for the opposite correction of the other side, so this is the happy middle. Probably means something about the pin itself or about my measurement steadiness.
I'm not sure that I dare to reinstall the collar and use it. Do I?
Thu, 06 Oct 2022 18:22:13 +0000
Thu, 06 Oct 2022 18:22:13 +0000 quote
My notes from the video
Thu, 06 Oct 2022 22:03:41 +0000
Thu, 06 Oct 2022 22:03:41 +0000 quote
found this on the interwebs - it looks like my 0.002" may be OK.
Scootering used to do some pretty kick ass articles.
crankshafts_scootering_article.pdf
 Description:
Download
 Filename:  crankshafts_scootering_article.pdf
 Filesize:  3.6 MB
Fri, 07 Oct 2022 00:10:02 +0000
Fri, 07 Oct 2022 00:10:02 +0000 quote
chandlerman wrote:
Lucky for you, you Know A Guy who has a couple smallie cranks close at hand.
65mm is going to be pretty wide, and definitely can't be done with a bearing race/bearing in place.
Thanks, C'man!
New iteration should work on any crank, with or without a race installed. Height/width adjustable.
3/16 x 1 1/2" aluminum flatbar riser. One tube fixed. The other slides horizontally.
Getting past the $20 fixed 65mm plan, but maybe you guys can get some ideas. If I did it again both posts would be adjustable aluminum landings.
Fri, 07 Oct 2022 00:14:56 +0000
Fri, 07 Oct 2022 00:14:56 +0000 quote
Ray8 wrote:
Thanks, C'man!
If this is going into limited production, I'll throw $20 plus shipping! Or more if the initial pricing was under shot. It looks like a perfect tool.
Fri, 07 Oct 2022 00:55:53 +0000
Fri, 07 Oct 2022 00:55:53 +0000 quote
It lives!! Anyone need a brand new crank for a slight discount??
Fri, 07 Oct 2022 01:01:43 +0000
Fri, 07 Oct 2022 01:01:43 +0000 quote
That's awesome! Also goes to show how much of a difference checking if things are to spec makes.
Fri, 07 Oct 2022 01:10:07 +0000
Fri, 07 Oct 2022 01:10:07 +0000 quote
Well done! Good thing to be able to check…even in a new one.
Fri, 07 Oct 2022 01:43:49 +0000
Fri, 07 Oct 2022 01:43:49 +0000 quote
other key lessons from today:
-sneak up on your adjustments, but you will get a feel pretty quick how hard to hit things. I had a bit of spread going but I used the vice and ended up in squished condition - I guess that was too much, but a quick hit with a wedge and it was sorted. The majority of my issue was twist, as suspected.
-a big brass drift about the width of a hammer handle works well with a regular hammer if you don't have the brass one
-that guy in the video knows his stuff
-don't try to judge if you've succeeded while the crank puller is still installed and the other case half is not - it will freak you out unnecessarily. the crank was hitting the rotary pad until I removed the cantilevered weight.
-don't order the new parts until you are sure the old ones are trash
Fri, 07 Oct 2022 02:12:03 +0000
VNB VSC o9c VMA vbc vmb VSX
Fri, 07 Oct 2022 02:12:03 +0000 quote
Good sorting!
Fri, 07 Oct 2022 14:33:04 +0000
Fri, 07 Oct 2022 14:33:04 +0000 quote
Runout on new Mazz crank:
0.001" on fly side
so small it can't be measured with this indicator on clutch side
Fri, 07 Oct 2022 14:53:22 +0000
Fri, 07 Oct 2022 14:53:22 +0000 quote
0.001" on fly side
Yup, even the new ones. Those Mazz boxes are shit. Wish they'd pack them better for shipping. I wouldn't ship a paperweight like that.
Fri, 07 Oct 2022 14:55:06 +0000
Fri, 07 Oct 2022 14:55:06 +0000 quote
Yeah
Fri, 07 Oct 2022 14:59:27 +0000
Fri, 07 Oct 2022 14:59:27 +0000 quote
sdjohn wrote:
Yeah
Exactly how mine arrived. JFC. It's a crankshaft, not an old ashtray.
Fri, 07 Oct 2022 16:06:09 +0000
Fri, 07 Oct 2022 16:06:09 +0000 quote
crank sold! mjrally is taking it off my hands
Fri, 07 Oct 2022 16:59:35 +0000
Fri, 07 Oct 2022 16:59:35 +0000 quote
The next run are looking more like $45.
I can send you the prototype in the video for $0 + shipping if you want to try it out.
Just DM me your address.
I'll make another 4 next week, both landings aluminum with CNC'd landings/channels, and put 3 in the Classifieds.
Only doing this for fun!
Fri, 07 Oct 2022 17:06:06 +0000
PX 200
PX 200
Fri, 07 Oct 2022 17:06:06 +0000 quote
I'll take one!
Fri, 07 Oct 2022 18:38:20 +0000
Fri, 07 Oct 2022 18:38:20 +0000 quote
Ray8 count me in!
Fri, 07 Oct 2022 22:47:40 +0000
Fri, 07 Oct 2022 22:47:40 +0000 quote
me three!
Sat, 08 Oct 2022 19:05:40 +0000
Sat, 08 Oct 2022 19:05:40 +0000 quote
Son of a bitch dropped it trying to fit it.
It's not sealing surface, think it's ok.
Sat, 08 Oct 2022 19:47:47 +0000
Sat, 08 Oct 2022 19:47:47 +0000 quote
Ugly duckling but it will be fine. Hidden by the Vaders helmet anyways
Sat, 08 Oct 2022 21:25:42 +0000
Sat, 08 Oct 2022 21:25:42 +0000 quote
Leak test 10 psi goes to 8 over 10 minutes. Every leak I found was on the tester interfaces. I don't think there's more that can be done, nothing is bubbling with soapy water. I think it's ok.
Sat, 08 Oct 2022 22:11:50 +0000
Sat, 08 Oct 2022 22:11:50 +0000 quote
Shroud debacle - I think it's for an early engine, the cowl cover and it don't get along.
Sat, 08 Oct 2022 22:44:45 +0000
Sat, 08 Oct 2022 22:44:45 +0000 quote
Initial jetting
48/160
Be3
160ac
107 mj for sito
Sat, 08 Oct 2022 23:19:43 +0000
Sat, 08 Oct 2022 23:19:43 +0000 quote
Junction box fail
Sat, 08 Oct 2022 23:26:10 +0000
Sat, 08 Oct 2022 23:26:10 +0000 quote
sdjohn wrote:
Junction box fail
Why's it a fail? When I started cleaning mine up I got rid of junctions and soldered it all together, added water tight heat shrink tubing. I don't see me fixing it on the side of the rode with a new stator.
Sat, 08 Oct 2022 23:31:20 +0000
Sat, 08 Oct 2022 23:31:20 +0000 quote
Box for a PX. He needs the smaller square shaped one for the Super cases.
Sat, 08 Oct 2022 23:45:06 +0000
Sat, 08 Oct 2022 23:45:06 +0000 quote
It is a px engine but the wire exit lands at the screw of the air box, need this one, what is it???
Sun, 09 Oct 2022 00:14:28 +0000
Sun, 09 Oct 2022 00:14:28 +0000 quote
I found the detail of why it doesn't work. The box I have is for estart and the one I need is for not e-start.
https://www.sip-scootershop.com/en/product/junction-box-piaggio_21683700
Sun, 09 Oct 2022 02:02:38 +0000
Sun, 09 Oct 2022 02:02:38 +0000 quote
looks like a SIP order via Mercato is required because Mercato is out of stock
anyone else do that when Mercato is out of stock? It's like a prompt - please get these back in stock....
Sun, 09 Oct 2022 02:21:06 +0000
Sun, 09 Oct 2022 02:21:06 +0000 quote
Numerous times
Sun, 09 Oct 2022 04:59:12 +0000
Sun, 09 Oct 2022 04:59:12 +0000 quote
I ordered this one too (Piaggio code: 216837)
https://www.lambretta-teile.de/Wire-connector-PIAGGIO-Vespa-PX-Lusso-without-Elestart
Either I got the wrong part or the new Piaggio parts are just no good. It fouled the airbox so I just shortened the airbox side exit.
Sun, 09 Oct 2022 05:02:50 +0000
Sun, 09 Oct 2022 05:02:50 +0000 quote
Also the original had the airbox side exit from center of the junction box:
Heads up for you to double check before you order a wrong part.
Sun, 09 Oct 2022 05:08:38 +0000
Sun, 09 Oct 2022 05:08:38 +0000 quote
Thanks Finyoshi
Sun, 09 Oct 2022 05:10:39 +0000
Sun, 09 Oct 2022 05:10:39 +0000 quote
I'm beginning to think I just had a wrong part delivered though.
Sun, 09 Oct 2022 05:43:14 +0000
Sun, 09 Oct 2022 05:43:14 +0000 quote
Actually two mishaps combined. I ordered the wrong one
https://www.lambretta-teile.de/Cable-connection-box-PIAGGIO-Vespa-PX-Lusso-T5
... and they seem to have image of a wrong box on their product page:
Sent a message to Marco so product images could be corrected.
Sun, 09 Oct 2022 06:10:09 +0000
Sun, 09 Oct 2022 06:10:09 +0000 quote
Ha very good. I was starting to doubt the part pictures on SIP but now we know what happened.
Mon, 10 Oct 2022 13:39:40 +0000
Mon, 10 Oct 2022 13:39:40 +0000 quote
Well the plot thickens once again
When I asked if the images are wrong on this product page:
Response:
"Thats whats Piaggio sends us at this part code, we have no influence on that…
Mit freundlichen Grüßen / best regards
Marco Büttner"
It seems not to be an error on LTH, just Piaggio superceding a part with newer and less compatible one
[ Time: 0.0417s ][ Queries: 6 (0.0143s) ][ Debug on ][ 276 ][ Thing Two ]
