sdjohn wrote:
well the new crank arrives today - perhaps we'll measure before installing for science
Posts: 3454 Location: Florence, OR |
Thu, 06 Oct 2022 16:45:27 +0000
quote
sdjohn wrote: well the new crank arrives today - perhaps we'll measure before installing for science |
![]() Parmakit Primavera -74, Polini Primavera -68, Stock 150 Touring -59, VMC 177 Bajaj Chetak 125 -95
Posts: 504 Location: Finland |
Thu, 06 Oct 2022 17:14:37 +0000
quote
FINYoshi wrote: The one used on the video above has bearings to roll the crankshaft on. I don't like this because bearings always have their tolerances and play which adds unnecessary uncertainty to the measurement. V-shape wedge is better and if you are worried about leaving a slight marks on your crank bearing necks, you can add a strip of softer metal to the edge. This should not be necessary though, because you will not be spinning the crank on the stand (at least hopefully) for thousands of revolutions. Smooth surfaces on the V with dab of oil and you are golden. 1. Make it beefy enough - you don't want to guess if you have flex 2. No need to make it very tall unless you want to use if for some static balancing action 3. Adjustment for crank width is nice to have 4. Get two dial gauges with mounts to see both sides of the crank at same time ![]()
Positive
Posts: 6878 Location: San Diego, CA |
Thu, 06 Oct 2022 18:17:27 +0000
quote
I managed to get it within +/- .001" (about 0.002" total) on each far end by using the video above. Is that good enough? It's a lot closer than it was. For now, it seems each side is asking for the opposite correction of the other side, so this is the happy middle. Probably means something about the pin itself or about my measurement steadiness.
I'm not sure that I dare to reinstall the collar and use it. Do I? |
Fri, 07 Oct 2022 00:10:02 +0000
quote
chandlerman wrote: Lucky for you, you Know A Guy who has a couple smallie cranks close at hand. 65mm is going to be pretty wide, and definitely can't be done with a bearing race/bearing in place. New iteration should work on any crank, with or without a race installed. Height/width adjustable. 3/16 x 1 1/2" aluminum flatbar riser. One tube fixed. The other slides horizontally. Getting past the $20 fixed 65mm plan, but maybe you guys can get some ideas. If I did it again both posts would be adjustable aluminum landings. |
Posts: 4067 Location: Staten Island, NY |
Fri, 07 Oct 2022 00:14:56 +0000
quote
Ray8 wrote: Thanks, C'man! New iteration should work on any crank, with or without a race installed. Height/width adjustable. 3/16 x 1 1/2" aluminum flatbar riser. One tube fixed. The other slides horizontally. Getting past the $20 fixed 65mm plan, but maybe you guys can get some ideas. If I did it again both posts would be adjustable aluminum landings. |
Fri, 07 Oct 2022 00:55:53 +0000
quote
It lives!! Anyone need a brand new crank for a slight discount??
Positive
![]() Fri, 07 Oct 2022 01:01:43 +0000
Posts: 7165 Location: Nashville |
quote
sdjohn wrote: It lives!! Anyone need a brand new crank for a slight discount?? |
Posts: 1514 Location: northern New York |
Fri, 07 Oct 2022 01:43:49 +0000
quote
other key lessons from today:
-sneak up on your adjustments, but you will get a feel pretty quick how hard to hit things. I had a bit of spread going but I used the vice and ended up in squished condition - I guess that was too much, but a quick hit with a wedge and it was sorted. The majority of my issue was twist, as suspected. -a big brass drift about the width of a hammer handle works well with a regular hammer if you don't have the brass one -that guy in the video knows his stuff -don't try to judge if you've succeeded while the crank puller is still installed and the other case half is not - it will freak you out unnecessarily. the crank was hitting the rotary pad until I removed the cantilevered weight. -don't order the new parts until you are sure the old ones are trash ![]()
Positive
Posts: 6790 Location: Hustletown, TX |
Fri, 07 Oct 2022 14:33:04 +0000
quote
Runout on new Mazz crank:
0.001" on fly side so small it can't be measured with this indicator on clutch side
Positive
Fri, 07 Oct 2022 14:53:22 +0000
quote
sdjohn wrote: Runout on new Mazz crank: 0.001" on fly side so small it can't be measured with this indicator on clutch side |
Fri, 07 Oct 2022 14:59:27 +0000
quote
sdjohn wrote: Yeah
Positive
Fri, 07 Oct 2022 16:59:35 +0000
quote
swiss1939 wrote: If this is going into limited production, I'll throw $20 plus shipping! Or more if the initial pricing was under shot. It looks like a perfect tool. I can send you the prototype in the video for $0 + shipping if you want to try it out. Just DM me your address. I'll make another 4 next week, both landings aluminum with CNC'd landings/channels, and put 3 in the Classifieds. Only doing this for fun!
Positive
Fri, 07 Oct 2022 17:06:06 +0000
quote
Ray8 wrote: The next run are looking more like $45. I can send you the prototype in the video for $0 + shipping if you want to try it out. Just DM me your address. I'll make another 4 next week, both landings aluminum with CNC'd landings/channels, and put 3 in the Classifieds. Only doing this for fun! |
Posts: 12568 Location: The state of insanity, SoCal |
Sat, 08 Oct 2022 19:47:47 +0000
quote
Ugly duckling but it will be fine. Hidden by the Vaders helmet anyways
Positive
Sat, 08 Oct 2022 21:25:42 +0000
quote
Leak test 10 psi goes to 8 over 10 minutes. Every leak I found was on the tester interfaces. I don't think there's more that can be done, nothing is bubbling with soapy water. I think it's ok.
Positive
Sat, 08 Oct 2022 22:11:50 +0000
quote
Shroud debacle - I think it's for an early engine, the cowl cover and it don't get along.
![]() Sat, 08 Oct 2022 23:26:10 +0000
Posts: 3239 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
sdjohn wrote: Junction box fail |
![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Posts: 4524 Location: Oceanside, CA |
Sat, 08 Oct 2022 23:31:20 +0000
quote
Christopher_55934 wrote: Why's it a fail? When I started cleaning mine up I got rid of junctions and soldered it all together, added water tight heat shrink tubing. I don't see me fixing it on the side of the rode with a new stator. |
Sat, 08 Oct 2022 23:45:06 +0000
quote
It is a px engine but the wire exit lands at the screw of the air box, need this one, what is it???
Sun, 09 Oct 2022 00:14:28 +0000
quote
I found the detail of why it doesn't work. The box I have is for estart and the one I need is for not e-start.
https://www.sip-scootershop.com/en/product/junction-box-piaggio_21683700 |
Sun, 09 Oct 2022 02:02:38 +0000
quote
looks like a SIP order via Mercato is required because Mercato is out of stock
anyone else do that when Mercato is out of stock? It's like a prompt - please get these back in stock.... |
Sun, 09 Oct 2022 02:21:06 +0000
quote
sdjohn wrote: anyone else do that when Mercato is out of stock? |
Sun, 09 Oct 2022 04:59:12 +0000
quote
I ordered this one too (Piaggio code: 216837)
https://www.lambretta-teile.de/Wire-connector-PIAGGIO-Vespa-PX-Lusso-without-Elestart Either I got the wrong part or the new Piaggio parts are just no good. It fouled the airbox so I just shortened the airbox side exit. ![]() |
Sun, 09 Oct 2022 05:02:50 +0000
quote
Also the original had the airbox side exit from center of the junction box:
![]() Heads up for you to double check before you order a wrong part. |
Sun, 09 Oct 2022 05:10:39 +0000
quote
I'm beginning to think I just had a wrong part delivered though.
Sun, 09 Oct 2022 05:43:14 +0000
quote
Actually two mishaps combined. I ordered the wrong one
![]() https://www.lambretta-teile.de/Cable-connection-box-PIAGGIO-Vespa-PX-Lusso-T5 ... and they seem to have image of a wrong box on their product page: https://www.lambretta-teile.de/Wire-connector-PIAGGIO-Vespa-PX-Lusso-without-Elestart Sent a message to Marco so product images could be corrected. |
Sun, 09 Oct 2022 06:10:09 +0000
quote
Ha very good. I was starting to doubt the part pictures on SIP but now we know what happened.
Mon, 10 Oct 2022 13:39:40 +0000
quote
Well the plot thickens once again
![]() When I asked if the images are wrong on this product page: https://www.lambretta-teile.de/Wire-connector-PIAGGIO-Vespa-PX-Lusso-without-Elestart Response: "Thats whats Piaggio sends us at this part code, we have no influence on that… Mit freundlichen Grüßen / best regards Marco Büttner" It seems not to be an error on LTH, just Piaggio superceding a part with newer and less compatible one ![]() |
