Wed, 12 Oct 2022 15:52:54 +0000
GTS 300 SuperSport
GTS 300 SuperSport
Wed, 12 Oct 2022 15:52:54 +0000 quote
STILL NOT! Header arrived the muffler not yet...🤬
Wed, 12 Oct 2022 16:16:53 +0000
GTS 300 hpe
GTS 300 hpe
Wed, 12 Oct 2022 16:16:53 +0000 quote
SC68TER wrote:
On taking the exhaust out of the box, I have noticed that the dB killer screw has been spot-welded in place!
It's an E5 requirement for the db killer to be not removable.
Wed, 12 Oct 2022 17:20:02 +0000
2018 GTS 300 Super Sport (Grey)
Wed, 12 Oct 2022 17:20:02 +0000 quote
Ok thanks.
So whilst not very E5 compliant, has anyone had any experience of successfully removing a dB killer?
On reflection it looks like I should have bought the race version plus an additional down pipe with cat.
Would have been more than I've spent here but would have given me the option to remove the end.
Wed, 12 Oct 2022 18:06:55 +0000
GTS 300 SuperSport
GTS 300 SuperSport
Wed, 12 Oct 2022 18:06:55 +0000 quote
I think the header without cat and the muffler with db killer combo will have a correct neighbour friendly, sporty sound.
Wed, 12 Oct 2022 19:00:25 +0000
Wed, 12 Oct 2022 19:00:25 +0000 quote
Unfortunately without the cat it won't pass an MOT from what I can see.
I'll have to come up with a plan B!
Wed, 12 Oct 2022 23:50:10 +0000
2019 Supertech EURO3 41,000km
Wed, 12 Oct 2022 23:50:10 +0000 quote
SC68TER wrote:
Well I'm stuck with it now, and looking at it in more detail, the screw doesn't even serve a purpose - removing it won't make a difference!
are you really sure about that? looking at pictures like this makes me thing you could just dremmel the tack weld off and then remove the screw (and reinstert)
Wed, 12 Oct 2022 23:54:19 +0000
Wed, 12 Oct 2022 23:54:19 +0000 quote
rdhood wrote:
Yuck. If you go down, that thing poses an additional threat to get torn off or further damage the bike. It's also extremely pillion unfriendly, and poses a burn danger to anyone on the back. Overall, a crappy design for a Vespa.
And most importantly no curry hook.
Wed, 12 Oct 2022 23:58:03 +0000
Wed, 12 Oct 2022 23:58:03 +0000 quote
and I couldn't stick a box of beer between my feet (one of the many reasons that a vespa is better than a bike)
Sat, 15 Oct 2022 09:33:45 +0000
Sat, 15 Oct 2022 09:33:45 +0000 quote
Another choice exhaust for the connoisseurs
Sat, 15 Oct 2022 09:41:59 +0000
Sat, 15 Oct 2022 09:41:59 +0000 quote
When I get a moment I am going to post some pictures as it looks like the insert is held in place by more than just the welded-screw - the edges look almost joined.
It will hopefully make more sense once I photo it...
Sun, 16 Oct 2022 20:18:25 +0000
Sei Giorni 2020
Sei Giorni 2020
Sun, 16 Oct 2022 20:18:25 +0000 quote
I recently installed an Akrapovic.
They were on sale!
I love everything about it.
Power, sound, volume and looks.
Sun, 16 Oct 2022 20:38:40 +0000
Sun, 16 Oct 2022 20:38:40 +0000 quote
Ok so here are the photos.
The screw appears to hold the two pieces of exhaust together but do not do anything other than penetrate through the two pieces.
Visually the two parts of the exhaust appear to be joined but of course this could be just the paint and will break away once the screw is removed.
That said, looking at the photo (can't upload more than one from my phone) I cannot believe that pulling the dB killer out will work as easily as hoped…
Have tried to contact Remus but they're as much use as tits on a man, so hoping to draw on the combined wisdom of the MV forum!
Photos attached and grateful for any/all opinions (as long as they're helpful!)
Sun, 16 Oct 2022 20:40:35 +0000
Sun, 16 Oct 2022 20:40:35 +0000 quote
Photo #2
Sun, 16 Oct 2022 22:33:56 +0000
Sun, 16 Oct 2022 22:33:56 +0000 quote
maybe remove the weld (dremel etc) then remove the screw and see what happens. You can always put the screw back in if you have no success
Fri, 21 Oct 2022 03:06:14 +0000
Fri, 21 Oct 2022 03:06:14 +0000 quote
And another off Instagram
https://instagram.com/drvvespa
Fri, 21 Oct 2022 13:23:25 +0000
2009 GTS250, Ducati Monster M900
Fri, 21 Oct 2022 13:23:25 +0000 quote
The look of the clamp on that Nuke is really quite nice.
I would also be upgrading my swingarm to one of those slick SIP or Zelioni options to complete the clean look.
Mon, 24 Oct 2022 03:48:08 +0000
2018 Vespa GTS 300 Super
Mon, 24 Oct 2022 03:48:08 +0000 quote
I love my Remus
Thu, 27 Oct 2022 09:08:18 +0000
'2017 GTS 300 SS
'2017 GTS 300 SS
Thu, 27 Oct 2022 09:08:18 +0000 quote
I just purchased a Malossi, hopefully having it fitted on the 7th Nov, I'll provide some feedback later šŸ‘
And here it is
Fri, 28 Oct 2022 20:00:36 +0000
300 GTS supertech HPE
Fri, 28 Oct 2022 20:00:36 +0000 quote
labphoto wrote:
I love my Remus
i have the same exhaust om my, but does anyone else have a malossi tuning on??
as i learnt from a wise man that a engine with sports exhaust would run lean!!
the tuning as i have dialed it in doesent do anything else then give it a little more gas.no effect boost...just to be nice to the engine.
thoughts??
and yes....i love the sound of my doubble remus, i run it with the noice killer in!
Sat, 29 Oct 2022 00:28:12 +0000
Sat, 29 Oct 2022 00:28:12 +0000 quote
thoughts??
I added a malossi lambda emulator when adding my arrow exhaust. made zero performance different so remvoed it.
Mon, 07 Nov 2022 01:44:48 +0000
2015 Vespa Primavera 50 (sold), 2021 Vespa Sprint 150, 2022 Sei Giorni 300ie
Mon, 07 Nov 2022 01:44:48 +0000 quote
boovilly wrote:
TSR Odyssey. Nice deep tone. Good size (for showing off more of the rear wheel) and at least half the price of Akra, Remus etc
How's your TSR odyssey holding up. I want one!
Thu, 10 Nov 2022 14:41:58 +0000
Thu, 10 Nov 2022 14:41:58 +0000 quote
Yellow300GTS wrote:
Remus Dual i cool:)
How's the Remus holding up after two years. Looks to cool!
Thu, 10 Nov 2022 14:43:23 +0000
Thu, 10 Nov 2022 14:43:23 +0000 quote
Eelco wrote:
REMUS RSC Dual Flow Carbon (i live near the beach).
What an absolutely sweet looking muffler. How's it holding up?
Thu, 10 Nov 2022 16:02:16 +0000
GTS 300, Buddy 125
GTS 300, Buddy 125
Thu, 10 Nov 2022 16:02:16 +0000 quote
My interest in an aftermarket exhaust would be a quieter and sleeker if possible. Anyone know of an exhaust that is quieter and does not negatively impact performance.
Thu, 10 Nov 2022 23:19:05 +0000
Thu, 10 Nov 2022 23:19:05 +0000 quote
just some like fancy exhausts ...
primavera / sprint
Sat, 12 Nov 2022 11:00:37 +0000
Sat, 12 Nov 2022 11:00:37 +0000 quote
A short while back Akrapovic introduced a cover for the front end of their exhaust, carbon fibre? It matches the outlet cover, and looks quite neat. It is held on by two screws going into clamps around the pipe, a little fiddly to set up and align but very simple to remove to get at the springs.
My Akra has migrated from my GTS250 to my GTS300. It was silver but is now black, and I have replaced the wadding twice.
Mon, 21 Nov 2022 22:50:55 +0000
Tue, 22 Nov 2022 18:29:14 +0000
GTS 250
GTS 250
Tue, 22 Nov 2022 18:29:14 +0000 quote
Hi I'm a PM tuning fan... Have one on my GTSand RT$ and have lasted me fro 12 years and 15 years... Oomphy and great sound...whereas in London with rain and salt on the roads the stock ones last only 3 years.
Saw this twin exhaust last mont, don't know the make , but looks stealthy.
Gass silver machine GTS 250
Steath bomber like exhaust.
Tue, 22 Nov 2022 18:35:20 +0000
Tue, 22 Nov 2022 18:35:20 +0000 quote
How do you like those rear crash bars. I think they are FA or Falco?
Tue, 22 Nov 2022 19:25:07 +0000
Tue, 22 Nov 2022 19:25:07 +0000 quote
the make is Remus dual flow, i have the one in stainless as i ride in snow and salt.
sounds goood tho.....
Tue, 22 Nov 2022 19:52:59 +0000
Tue, 22 Nov 2022 19:52:59 +0000 quote
Love the look of the Remus Dual flow! They are expensive I believe. Around $600-$700? Anyone seen a better price? Thanks
You have the Homologated version?
Fri, 25 Nov 2022 22:50:11 +0000
Fri, 25 Nov 2022 22:50:11 +0000 quote
another unusual choice (yeah, not a gts)
Mon, 05 Dec 2022 01:29:16 +0000
2023 GTS 300 Supertech
Mon, 05 Dec 2022 01:29:16 +0000 quote
Ok do tell me…is it really worth over 10% of the total cost of my 2023 GTS scooter TO BUY THIS?
https://www.scooterwest.com/2021-hpe-black-akrapovic-gts-gtv-super-250-300-performance-exhaust-muffler-coming-soon.html
Mon, 05 Dec 2022 02:04:45 +0000
Mon, 05 Dec 2022 02:04:45 +0000 quote
The scooter west ad copy says this: "As if giving it balls weren't enough, visually the Akrapovic are simply a work of art."
Hard to place a value on these attributes!
Mon, 05 Dec 2022 02:24:44 +0000
Mon, 05 Dec 2022 02:24:44 +0000 quote
šŸ¤”
ā¬†ļø    About 6w elapsed between posts    ā¬‡ļø
Mon, 16 Jan 2023 18:39:55 +0000
2022 GTS 300
2022 GTS 300
Mon, 16 Jan 2023 18:39:55 +0000 quote
To me, the value of everything is gauged individually. I feel it's worth it to drop some scooter weight and have a different look and sound. I am considering adding this updated model exhaust to my 2022 GTS, I just need to change the header pipe to the Euro 5 std, which is available too. This costs some money for sure, like all good things.
Anyone know if changing the header and installing this new model Akropovic might cause any running issues on a 2022 US model GTS?
[ Time: 0.1241s ][ Queries: 6 (0.0938s) ][ Debug on ][ 276 ][ Thing Two ]
