Sun, 16 Oct 2022 20:04:28 +0000
Sun, 16 Oct 2022 20:04:28 +0000 quote
GickSpeed wrote:
A couple of observations:
The fork you have is for the later 1-piece headsets. The earlier split headsets have the headset bolt entering on the side. You may be able to get away with removing material off your fork to make it work—-but be careful here.
The earlier chassis' would have come with loose bearings.
Is that some type of metal "repair" on the chassis I see in earlier photo? If so, best to have it TIG welded up-best and correct approach. Check to make sure the steering stops are in the correct position to stop the fork from turning so much the headset hits the chassis. This is the most common reason why these legshields get torn up.
The piece of metal around the shifter cables only serves one purpose-to royaly piss anyone off attempting to remove said cables. I do a lot of things by the book but this is one I pass on.
I use USA made rubber fuel line.
Well that explains that! Thanks. I know it doesn't mean shit but the fork even has 58 Allstate written on it. I ground in a new one so all is good. Went as light as possible and kept fitting it until the screw finally slid in. That way it's impossible to take out too much.
Yes it has the dreaded JBWeld. I'm going to tackle that when I paint it in the future. Steering stops are good.
I thought this type of fuel line was ethanol resistant. Oh well. I'll grab one soon.
About 15 seconds with the angle grinder and we're good to go.
Thu, 20 Oct 2022 17:59:59 +0000
Thu, 20 Oct 2022 17:59:59 +0000 quote
My welder friend had covid so he finally got back to work and tack welded the studs on the seating jawn.
Just waiting on the cables to arrive today then I'm good to button her up. And then chase 100 electrical gremlins cause I'm sure that won't be a smooth painless experience.
Just in time too. Today is frigid. But it's supposed to warm up this weekend into next week so I may get a ride in before the big freeze sets in soon.
Thu, 20 Oct 2022 18:22:48 +0000
parallelogramerist
parallelogramerist
Thu, 20 Oct 2022 18:22:48 +0000 quote
For future fork notchings, use a flapper disc with a bullnose on it. It can quickly give you factory like results.
Thu, 20 Oct 2022 20:44:32 +0000
Thu, 20 Oct 2022 20:44:32 +0000 quote
Good idea! Hopefully I'll never need that but one day someone may.
Fri, 21 Oct 2022 14:45:09 +0000
Fri, 21 Oct 2022 14:45:09 +0000 quote
Does anyone have any tips on getting the front brake cable to seat in the lever perch properly?
If you look inside you see there's a stop in there for the cable inner to go through and blocks the outer from being pulled through. However there's also PLENTY of space behind that for the outer to pass. I can't seem to get it to not pass the stop. Which then doesn't allow for the brake to pull properly. Halp!
Here's a WILDLY terrible picture of the issue. My phone won't focus that close sorry! You can see what I mean though. The outer slides right past the stop!
Fri, 21 Oct 2022 14:48:08 +0000
Fri, 21 Oct 2022 14:48:08 +0000 quote
Here's another maybe better pic. Am I missing something in both of the headsets I have or is this user error? I didn't have an issue at all when I put Bluey together.
That gap on the backside is the issue.
Fri, 21 Oct 2022 15:12:45 +0000
1964 Allstate Cruisaire, 1966 Allstate Blue Badge Small Frame, 2022 Husqvarna Vitpilen 401, 1980 Honda NC50
Fri, 21 Oct 2022 15:12:45 +0000 quote
Do you have a tophat behind the perch for the cable to sit in? It still goes thought with one?
Fri, 21 Oct 2022 16:03:56 +0000
Fri, 21 Oct 2022 16:03:56 +0000 quote
Does the top hat sit outside of the lever housing? Like so…
Top hat don't go further than that! Maybe that's kosher? I dunno. If so does the clutch get the same?
Fri, 21 Oct 2022 16:13:19 +0000
Fri, 21 Oct 2022 16:13:19 +0000 quote
put the tophat on the inner and feed it through from the lever side? Tophat should definitely be seated into that slot. On all mine, it has a rounded hole for the top of the tophat and a slot for the cable, so it looks like a keyhole.
Fri, 21 Oct 2022 16:30:54 +0000
Fri, 21 Oct 2022 16:30:54 +0000 quote
Remove the tophat.
Run the cable though it and clamp the other end with a third hand tool or a cable stop.
With a flat blade screwdriver to direct it, pull the ferrule up into the seat with the cable.
Fri, 21 Oct 2022 17:15:44 +0000
Fri, 21 Oct 2022 17:15:44 +0000 quote
Thanks Chandlerman and Ray!
Had a brain fart apparently and never even thought to try that. Got that part sorted then went to town on the f@$@)#g throttle nonsense. I think I got that sorted too.
Time to kick her over after lunch and see what's up
Fri, 21 Oct 2022 18:09:03 +0000
Fri, 21 Oct 2022 18:09:03 +0000 quote
Gr8.
Just to be clear, don't use the tophat.
There's a socket in there that only a ferrule will seat in.
Fri, 21 Oct 2022 18:49:04 +0000
Fri, 21 Oct 2022 18:49:04 +0000 quote
Ray8 wrote:
Gr8.
Now ya tell me! Guess that'll get fixed once I brake the cable or something.
Fri, 21 Oct 2022 20:00:06 +0000
'58 VBA
'58 VBA
Fri, 21 Oct 2022 20:00:06 +0000 quote
I have a top hat on mine. Brakes well. If the top hat fits between where the cable goes through I'd leave it. The diagram shows no top hat but one on the clutch side. It's the opposite on mine, weird.
⚠️ Last edited by Grumpnut on Sat, 22 Oct 2022 02:06:01 +0000; edited 1 time
Fri, 21 Oct 2022 21:00:33 +0000
Fri, 21 Oct 2022 21:00:33 +0000 quote
Moving on to the first start. Did it. Ran for about 30 seconds then died. Won't restart. I have spark and a new fuel line. The fuel line is rubber so I can't see if there's gas in it. How do you all test for flow from the tank?
Going to toss the clear Toyox brand one or whatever it's called and see if the gas gets to the carb later. Wanted to see if anyone had tips on how to check the line prior to that.
Fri, 21 Oct 2022 21:07:02 +0000
Fri, 21 Oct 2022 21:07:02 +0000 quote
It's messy, but if you loosen the screw on the float cover, it'll leak all over the airbox if it has fuel.
Fri, 21 Oct 2022 22:12:43 +0000
Fri, 21 Oct 2022 22:12:43 +0000 quote
I was hoping to avoid mess. So it goes I suppose. I'll try that tonight before I swap the hose.
Fri, 21 Oct 2022 22:17:20 +0000
Fri, 21 Oct 2022 22:17:20 +0000 quote
is that even possible with a vespa?
Fri, 21 Oct 2022 22:27:34 +0000
Fri, 21 Oct 2022 22:27:34 +0000 quote
Absolutely not.
They make my chicken coop seem pristine!
Fri, 21 Oct 2022 22:44:32 +0000
Fri, 21 Oct 2022 22:44:32 +0000 quote
I should correct myself - my GTS doesn't seem to soil the digs. But modern is a different world.
Sat, 22 Oct 2022 00:27:37 +0000
Sat, 22 Oct 2022 00:27:37 +0000 quote
Yahtzee! Pulled the float cover all the way off and zilch gas flowed. Will swap the hose this weekend if I have time. Thanks!
Sat, 22 Oct 2022 03:25:07 +0000
Sat, 22 Oct 2022 03:25:07 +0000 quote
You avoided the mess!
Sat, 22 Oct 2022 11:51:12 +0000
Sat, 22 Oct 2022 11:51:12 +0000 quote
Yeah, that's the irony. If you avoid the mess, you're going to have to make a mess.
Sat, 22 Oct 2022 22:18:52 +0000
Sat, 22 Oct 2022 22:18:52 +0000 quote
Interesting development. Leaving me more confused.
Replaced the gas line with the clear one. Noticed the fuel tap was backwards. Ie Closed was reserve and reserve was closed. So I flipped that back around to the correct way. Before I did that I emptied a small amount of gas from the tap to make sure that wasn't the issue. Gas flowed fine.
Put the clear hose one and attached it all up and put gas in the tank then opened the tap. Nothing. Tried all 3 positions with the gas cap on and off. No flow. Pulled up the tank to try and see if that helped. Nope. Pulled the tank and rested it on top of the cavity and tried the tap again and no gas. Wtf could be causing this?
Vent hole is clear as far as I know since the gas didn't flow when I opened it up so it's not that. But I'm stumped. Brand new line, 24" long like it should be, no kinks, tap works but no fuel flow. Any ideas?
Sat, 22 Oct 2022 22:51:58 +0000
Sat, 22 Oct 2022 22:51:58 +0000 quote
That's bizarre. Only thing I can think of is bring it back to the source. Prop up the tank with some gas in it and check the tap fully opened.
I know, you did this, but fully opened? Watching a stream come out of the tap? Gotta catch it somehow and all, but I can't think of what else it could be...
Hmmmmm
Sat, 22 Oct 2022 23:10:31 +0000
Sat, 22 Oct 2022 23:10:31 +0000 quote
Hmmmmm
I'll run through it again. Can't hurt to at least. It's gotta be the tap somehow. May as well take that out and clean it just to make sure also. Its gonna be in the 70's tomorrow and Tuesday here so I'm hoping to get a ride in then. Fingers crossed.
Sun, 23 Oct 2022 00:00:14 +0000
Sun, 23 Oct 2022 00:00:14 +0000 quote
Update.
Took the tank out and put gas in. Opened the tap. Well didn't have to open it. Gas came right out. Turns out I didn't fix the backwards tap lever thingy. So closed was reserve and out it came. Quickly closed that off so not to make a huge mess and got to testing.
Test One- tank out no hose attached:
Lever in off works as reserve, fuel flows.
Full open is middle and no gas comes out.
Closed is the reverse setting and no gas comes out.
Test Two- open tank cap while working the lever. No change in any position from above.
Test Three- attached hose, tank on top of frame
Lever in off position, gas flows about 10" down the line where it stops.
Full Open middle, no gas flow
Reverse, no gas flow
Test Four- hose attached, tank in frame
same results as Test Three.
I'm stumped. Gonna take apart the tap tomorrow. I got my sons hockey game at 6am tomorrow so I gotta go to bed now.
You can see where the gas is stuck just above that red/orange wire
Sun, 23 Oct 2022 00:57:29 +0000
parallelogramerist
parallelogramerist
Sun, 23 Oct 2022 00:57:29 +0000 quote
qascooter wrote:
That's bizarre.
How bizarre how bizarre
Sun, 23 Oct 2022 01:18:26 +0000
Sun, 23 Oct 2022 01:18:26 +0000 quote
How does the tap work backwards? Like the lever is installed upside down, so that the open position is straight down instead of straight up? (I'm just assuming it works the same as a smallframe one)
Sun, 23 Oct 2022 14:10:51 +0000
Sun, 23 Oct 2022 14:10:51 +0000 quote
Mike,
i suspect you have the disk valve installed backwards. you should rotate it 180 degrees and i reckon this will resolve your VNA fuel petcock issue.
Sun, 23 Oct 2022 15:04:20 +0000
Sun, 23 Oct 2022 15:04:20 +0000 quote
GickSpeed wrote:
Mike,
Yeah.
You can see what's happening in your test here. "Closed" is reserve and the rest is off.
Sun, 23 Oct 2022 17:54:57 +0000
Sun, 23 Oct 2022 17:54:57 +0000 quote
Ray8 wrote:
Yeah.
So I wanna make sure the blocked off hole is on the right when I reassemble it? Or is that a picture of how is should look already and that's what I wanna match?
Sun, 23 Oct 2022 17:56:40 +0000
Sun, 23 Oct 2022 17:56:40 +0000 quote
GickSpeed wrote:
Mike,
Thanks! Dang user error. Although that's better than something being broken. I thought I rotated it but I think I just must have spun the piece that the lever sits in instead of the whole shebang
Sun, 23 Oct 2022 18:17:23 +0000
Sun, 23 Oct 2022 18:17:23 +0000 quote
Just rotate the disk 180, so the channel is positioned as in red when the lever's closed. Currently it's in the yellow position.
Channel
Sun, 23 Oct 2022 18:25:08 +0000
Sun, 23 Oct 2022 18:25:08 +0000 quote
Thank you! The visual is a big help. Appreciated!
Mon, 24 Oct 2022 14:23:03 +0000
Mon, 24 Oct 2022 14:23:03 +0000 quote
Well it only kinda helped. Helped me see that no matter what I did, the tap only let gas out on the off setting.
Makes sense since my lights also only work on the off setting. Seems to be a thing over here. Going to try the second tap I have and see if that one is kosher.
Stay tuned
Mon, 24 Oct 2022 14:47:52 +0000
Mon, 24 Oct 2022 14:47:52 +0000 quote
I don't know why I'm struggling so bad with this fucking tap.
I'm about to blast them into the sun. Been at it for over an hour now and still only works when closed. Both of them. So it's user error cause they sure as shit worked before. Maybe I should eat something. Before I set this whole damn scooter and house on fire.
Mon, 24 Oct 2022 15:07:59 +0000
parallelogramerist
parallelogramerist
Mon, 24 Oct 2022 15:07:59 +0000 quote
Hang in there! I've been there before trying to figure out just which combination to position the disc, cover plate, and lever at. It was definitely perplexing for me to get them all correctly placed.
Mon, 24 Oct 2022 15:47:08 +0000
Mon, 24 Oct 2022 15:47:08 +0000 quote
Which taps are you using?
Maybe I can take a few more pics. Been meaning to drill-out a stock I have for fast-flow anyway. Also have an SIP v2.
Mon, 24 Oct 2022 17:06:22 +0000
Mon, 24 Oct 2022 17:06:22 +0000 quote
SIP 2.0 if you could that'd be extra helpful. I feel kinda crazy right now.
Edit: GOT IT!!! Good lord that was painful. All kosher on the tap now though. Time to see if it flows through the hose now!
[ Time: 0.0438s ][ Queries: 4 (0.0189s) ][ Debug on ][ 297 ][ Thing Two ]
