Tue, 25 Oct 2022 18:37:41 +0000
SYM HD300i
SYM HD300i
Tue, 25 Oct 2022 18:37:41 +0000 quote
Hello, i have a scooter and it has no light under seat storage and when it's dark outside i want to see what's there easily. How you managed that?
-First i think for a lamp with a motion sensor but for sure when i pass over potholes things will move and could turn on the light
-Second ideea is to have a timer lamp, push a button and for x minutes to stay on
-A switch to make a contact and power on a light when the seat is open
Other ideea or solutions?
Tue, 25 Oct 2022 18:50:21 +0000
Tue, 25 Oct 2022 18:50:21 +0000 quote
This is the easiest to implement. Any lever operated microswitch will do. Or even a Piaggio brake light switch.
https://www.sip-scootershop.com/en/product/brake-light-switch-tommaselli_DO221820
Tue, 25 Oct 2022 18:54:44 +0000
SYM HD300i
SYM HD300i
Tue, 25 Oct 2022 18:54:44 +0000 quote
I know, but i want something less intrusive, eventually battery powered. I found in my tool box a switch for hood in case of aftermarket alarm, but this require a 12V output etc.
Tue, 25 Oct 2022 19:08:45 +0000
Tue, 25 Oct 2022 19:08:45 +0000 quote
I don't know if this would work, but sticking one of these to the underside of the seat or back of the pet carrier might do the trick....I suspect they're available individually or smaller amounts somewhere....
closet lights
Tue, 25 Oct 2022 19:10:58 +0000
SYM HD300i
SYM HD300i
Tue, 25 Oct 2022 19:10:58 +0000 quote
There are diffrent types, but i want one, a idiot proof, in case of rush not to let to discharge and next time i need it will be dark. But thanks for suggestion
Tue, 25 Oct 2022 19:11:57 +0000
Tue, 25 Oct 2022 19:11:57 +0000 quote
There are multitudes of "stick up" lights that would be a far easier, if less elegant, solution - many that rechargeable via USB cord. Most you'd have to turn on and off manually, but there are some that are motion sensitive.
Auvon Inc (store on amazon and probably their own web site has a wide variety of rechargeable lights, but I'm sure there are dozens of companies world wide selling similar items.
Tue, 25 Oct 2022 19:22:20 +0000
Tue, 25 Oct 2022 19:22:20 +0000 quote
Unless I'm missing something, it sounds like your switch will work. You probably want a Normally Closed switch, so that it opens the circuit when the seat presses the switch pushbutton. I think a switch rated for 12 volts, for automotive applications, would be ideal. It would work to switch the scooter's battery, if that's the way you go, or it would switch a light with its own internal battery (a light with 3 or 4 AA batteries for example).
A "metal ball tilt switch" attached to the seat might work, too. Or a "magnetic reed switch" as are used on window and door security systems.
Tue, 25 Oct 2022 20:30:55 +0000
Grumpy Biker
Grumpy Biker
Tue, 25 Oct 2022 20:30:55 +0000 quote
My Garmin smart watch has a flash light built into it. Super easy to get to and very effective for these types of things.
Garmin Fenix 7X Sapphire Solar
Tue, 25 Oct 2022 22:06:07 +0000
Tue, 25 Oct 2022 22:06:07 +0000 quote
There are under hood mercury switch activated lights available. Search.
Tue, 25 Oct 2022 22:13:42 +0000
2015 Sprint 150, 2018 GTS 300
Tue, 25 Oct 2022 22:13:42 +0000 quote
closet lights
With today's battery powered LED light technology and options, I wouldn't scab into scooters wiring for a trunk light
Tue, 25 Oct 2022 22:20:41 +0000
Tue, 25 Oct 2022 22:20:41 +0000 quote
I carry small flashlight in the under seat compartment because I don't want to limited to just under the seat illumination. Of course most people have these built in to their phones.
Tue, 25 Oct 2022 23:00:25 +0000
Tue, 25 Oct 2022 23:00:25 +0000 quote
There's always a cooler light, designed in just this way to turn on when the lid is opened:
https://www.amazon.com/Coghlans-Inside-Cooler-Lid-Light/dp/B001N7FIVU
Wed, 26 Oct 2022 09:44:16 +0000
Vespa C38 - S50 4T Super.
Wed, 26 Oct 2022 09:44:16 +0000 quote
I've used IR motion activated light meant to light stairs, USB rechargeable. Roughly 2 inch wide, 1/4 inch thick. I glue it under the seat.
Works nicely, I take it in and charge it once or twice a year.
Wed, 26 Oct 2022 15:03:59 +0000
Wed, 26 Oct 2022 15:03:59 +0000 quote
I think Californiacruisng has the best answer - or simply put a small
flashlight in the nder seat.
Bob Copeland
Wed, 26 Oct 2022 16:00:43 +0000
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Wed, 26 Oct 2022 16:00:43 +0000 quote
I bought that exact light. It worked great until it fell apart.
The theory is sound, though.
Fri, 28 Oct 2022 11:11:51 +0000
SYM HD300i
SYM HD300i
Fri, 28 Oct 2022 11:11:51 +0000 quote
Hello! I finished my little project. I bought a door switch from a car audio shop, i had a spare led trip, some water tight connectors, a fuse and 1 hour of work.
The power i have taken from starter relay via a fuse and the ground from a stud.
When i want to remove the seat basket, i wired a connector for those moments.
Thanks for help!
Fri, 28 Oct 2022 11:15:39 +0000
Fri, 28 Oct 2022 11:15:39 +0000 quote
Well done!
Fri, 28 Oct 2022 15:28:31 +0000
Atypical Canadian
Atypical Canadian
Fri, 28 Oct 2022 15:28:31 +0000 quote
I have a cargo net in case I am running errands, a screw driver in case I need to access my battery, and my papers are in a zip lock bag taped to the underside of the seat in case the cops decide to stick it to me.
Is the lighting really necessary? How much junk do you keep in your trunk?
Fri, 28 Oct 2022 15:36:36 +0000
SYM HD300i
SYM HD300i
Fri, 28 Oct 2022 15:36:36 +0000 quote
Under my seat there is space for a full face helmet and most of the time I carry tools. And now being here in RO, Europe, winter, the sun goes down quickly and i need what tools i need to get.
Wed, 02 Nov 2022 00:16:33 +0000
GTS300 Super
GTS300 Super
Wed, 02 Nov 2022 00:16:33 +0000 quote
Wed, 02 Nov 2022 13:32:09 +0000
SYM HD300i
SYM HD300i
Wed, 02 Nov 2022 13:32:09 +0000 quote
Haha, yesterday evening i was watching on this clip. It's a good option, but i am lazy and i don't want to turn on/off all the time.
Wed, 02 Nov 2022 14:02:46 +0000
Wed, 02 Nov 2022 14:02:46 +0000 quote
rarevintea,
Welcome to you from Minnesota USA. If you can, it would be great to
see some photos from Romania as you scoot around. I have not had
the opportunity to travel to Romania but understand it is beautiful.
Bob Copeland
Minnesota USA
Welcome Romania.
Wed, 02 Nov 2022 14:42:13 +0000
Atypical Canadian
Atypical Canadian
Wed, 02 Nov 2022 14:42:13 +0000 quote
How often is your Vespa breaking down???
Wed, 02 Nov 2022 14:47:26 +0000
SYM HD300i
SYM HD300i
Wed, 02 Nov 2022 14:47:26 +0000 quote
My scooter is a Sym HD300i, a taiwan company and it's reliable so far. It's a 300cc engine with 27hp.
I am electrical engineer and in my spare time i repair household electrical issues and for that i need tools like a drill, strippers and other electrician tools.
And btw Romania is a beautiful country, with interesting roads and good food. If you plan arrive here for work or vacantion let me know!
Wed, 02 Nov 2022 18:48:09 +0000
Wed, 02 Nov 2022 18:48:09 +0000 quote
People used to laugh at me for carrying tools, but the few times I was able to ride home because I had pliers, screwdrivers, etc on my bike it made it all worthwhile.
I changed a broken belt alongside the road in the rain and rode my bike home one afternoon. I felt ten feet tall and bulletproof.
Wed, 02 Nov 2022 19:05:42 +0000
Atypical Canadian
Atypical Canadian
Wed, 02 Nov 2022 19:05:42 +0000 quote
...but did you feel the need to install underseat lighting?
Wed, 02 Nov 2022 19:16:47 +0000
Wed, 02 Nov 2022 19:16:47 +0000 quote
Wed, 02 Nov 2022 19:26:28 +0000
SYM HD300i
SYM HD300i
Wed, 02 Nov 2022 19:26:28 +0000 quote
Maybe
[ Time: 0.0383s ][ Queries: 4 (0.0159s) ][ Debug on ][ 297 ][ Thing Two ]
