Finally Vespa is done!
Now jetting journey begins again
I really hope on your help guys.
·Cases not ported to match the cylinder.
·Mazzucchelli racing crankshaft 57 mm rotary intake
·SI 24/24 drilled to 2.5 mm
·Polini box exhaust
·Original Piaggio air filter drilled above jets
·Polini carb case cover
·PX electronic ignition with SIP Touren flywheel 1600 g.
I started with:
AC 120
BE 5
135 mj
50/120 ij
Mix 2.5 out
I tried ride a little without air filter and carb case cover. It was not very bad.
But then I mounted air filter and carb case cover. All turned out extremely rich. Even start to ride was really hard scoot not revs up at all.
So I start to downjetting.
132 mj, then 130 mj.
Bit better and have a good punch after 4300-4500 rpm but I don't want to rev more than 5000 rpm according to cylinder kit manual.
Then I tried leaner main jets - 45/120 then 50/140.
Bit better than with 50/120 but still too rich.
Tell me please what I need to do next? Try AC 140? Or still move down in idle and main jets?
Here is all stuff what I have for carb tune:
AC: 160, 140, 120
Mixer: BE2, BE3, BE4, ВЕ5
MJ: 114, 116, 117, 118, 119, 120, 122, 125, 128, 130, 132, 135
IJ: 52/120, 50/120, 45/120, 52/140, 50/140, 55/160, 48/140, 40/120, 45/140, 42/140.
