Tue, 08 Nov 2022 14:19:25 +0000
Tue, 08 Nov 2022 14:19:25 +0000 quote
The double nut would have to be on the adjuster side, where you can already use the nut this way. It was corroded like so many other things in these cases.
Wed, 09 Nov 2022 23:46:56 +0000
Wed, 09 Nov 2022 23:46:56 +0000 quote
I have cut a notch in whichever end was protruding and then backed out with a flat blade screwdriver when this has happened to me.
Sun, 13 Nov 2022 01:04:38 +0000
Sun, 13 Nov 2022 01:04:38 +0000 quote
Today was gear cables and electrical cleanup. Also bashing the flywheel cover into submission for about 1/2 hour to make it fit. I had to replace one gear cable as it frayed going into the selector box. Stealing from my road spares again…
Mon, 14 Nov 2022 16:41:25 +0000
Mon, 14 Nov 2022 16:41:25 +0000 quote
Really all that needs to happen on this engine is fill the oil, shorten one new gear cable to put the lid on the selector box, and kick start it. I don't have a shroud yet that fits - I had ordered one in my Mercato order but it was on hold waiting for sip to get stock on that junction box. I called last week and figured it out with Dave - so we went ahead and did the rest of the order without the box. That still probably doesn't put the box into my hands this week though, as there are a couple other SIP order items in there.
Tue, 22 Nov 2022 06:53:28 +0000
Tue, 22 Nov 2022 06:53:28 +0000 quote
sdjohn wrote:
we will see what happens when you order that part number from SIP as a comparison...
Have you got your junction box yet?
Wed, 23 Nov 2022 04:59:36 +0000
Wed, 23 Nov 2022 04:59:36 +0000 quote
nope, they were out of stock and it was holding up my Mercato order so I told them to forget it and get me the rest
Wed, 23 Nov 2022 11:19:04 +0000
PX 200
PX 200
Wed, 23 Nov 2022 11:19:04 +0000 quote
The little black junction box for the stator wires? Think I might have a stock spare one lying around.
Wed, 30 Nov 2022 16:30:42 +0000
Wed, 30 Nov 2022 16:30:42 +0000 quote
Thanks - could you check what you have? It needs to be like below, if you have one. Center exit on the front side and outside exit on the rear side. It's for non-electric start PX, a rear beast in the USA.
Thu, 01 Dec 2022 00:18:17 +0000
PX 200
PX 200
Thu, 01 Dec 2022 00:18:17 +0000 quote
Yup! We might be lucky!
Let me check! I might have it in storage, which might be a weeks wait, or we might be lucky and I have it with me in the tool shed.
I definitely know my local guy has one… literally on the floor not being used.
I'm using a 3D printed one, just more space for the vape wiring, so can pass you my spare
Thu, 01 Dec 2022 01:06:06 +0000
Thu, 01 Dec 2022 01:06:06 +0000 quote
I'm pretty sure I have a spare one like that, too. I can check if 108 doesn't have one handy.
Thu, 01 Dec 2022 05:37:21 +0000
Thu, 01 Dec 2022 05:37:21 +0000 quote
You all rock, now if I could just get the rest of that order already….
Sun, 11 Dec 2022 03:11:00 +0000
Sun, 11 Dec 2022 03:11:00 +0000 quote
Was going for first start glory today but struggled mightily. First was no spark. The stator is a used item from Greasy, the flywheel a leftover from my P200. Swapped CDI's, no love. The flywheel was swapped for the one on the Stella engine and seemed to make some spark but still didn't start. Swapped the stator as well. New plug went in. It started but didn't want to rev out at all. Seemed to flood way too easily. So off came the stock exhaust that I had used and on went the Sito that was being used with the Stella engine. It wouldn't idle well until I swapped an undrilled filter for a drilled one. Now it would rev out, but if you stopped the engine, would flood again if you left it for a bit. I took off the float bowl cover - the float is OK, shot some carb cleaner at the needle and seat and put it back together but no real improvement.
It looks like time to swap carbs or at least float bowls. The engine has good compression and sounds OK as you rev it, so it's just a bolt on item, I guess. Based on all the swaps, the freebie SI20 I got in my parts exchange is looking suspect.
I need it to run right, then I can go back through the parts pile and figure out what to do with these by swapping them one at a time:
-suspect stator
-flywheel probably needs remagnetized
-stock exhaust is likely plugged
-filter - likely OK for the right application, just not sure this is it
I'm thinking some of this stuff is going to become automatic replacement in future rebuild. Was trying to see what we could make of the stuff I had but honestly it's probably not worth the effort on electrical....
Sun, 11 Dec 2022 03:32:33 +0000
Sun, 11 Dec 2022 03:32:33 +0000 quote
nice that you made a little headway! which used stator was it that I pawned off on you?
Sun, 11 Dec 2022 05:41:45 +0000
Sun, 11 Dec 2022 05:41:45 +0000 quote
It's a PX AC stator. I knew used stators are basically a gamble, but I rolled the dice. I will try it again once I sort the crabby carb. I'm honestly wondering if the pickup isn't lined up right or something. It all ohm'd out OK.
I felt kind of dirty putting that POS exhaust on there in the first place. I'm probably just going to chuck that. My guess is that pipe also filled with water like the engine while it was sitting and it's full of rust inside.
Yeah I was frustrated but realistically the engine build seems OK. It's really handy having a spare engine will all known good parts sitting on the side. I will order whatever I need to to make sure the spare engine stays with known good parts.
Sun, 18 Dec 2022 00:19:35 +0000
Sun, 18 Dec 2022 00:19:35 +0000 quote
I don't get it.
I now have the same stator, flywheel, exhaust, CDI, and carb from my running engine. It won't start. If you kick it enough, and then hold open the throttle like it's flooded, it eventually starts but runs like it's flooded. The engine was pressure tested OK. The cylinder makes 120+ psi compression. The arrow on the piston points at the exhaust.
How can it not run????
Sun, 18 Dec 2022 00:40:15 +0000
Sun, 18 Dec 2022 00:40:15 +0000 quote
Fuel, spark, air, compression.
You have compassion, so that's not it. Air is kindve a given with commission.
Check spark with a plug grounded you the case.
Use starter fluid instead of fuel. If it fires, then it's the carb.
You know this, you got this.
Sun, 18 Dec 2022 00:53:31 +0000
Sun, 18 Dec 2022 00:53:31 +0000 quote
Yeah it sparks against the case no issue.
Fuel is definitely getting in there, there was a haze of fuel when I pulled the head and the piston is wet.
That's the thing, it seems like I have fuel, spark, air, compression. Wtf?? There's no filter on the carb and the exhaust is known good. Air kinda has to be there, doesn't it?
Sun, 18 Dec 2022 00:56:34 +0000
Sun, 18 Dec 2022 00:56:34 +0000 quote
Starter fluid idea is interesting...
Old gas?
Sun, 18 Dec 2022 01:07:32 +0000
Sun, 18 Dec 2022 01:07:32 +0000 quote
It seems the gas is likely from July.
Sun, 18 Dec 2022 01:08:44 +0000
Sun, 18 Dec 2022 01:08:44 +0000 quote
Old gas?
Old gas could be an issue. Starter fluid is great because it covers all the fuel and carb issues, which means you now know the issue if it fires up with it.
Sun, 18 Dec 2022 01:10:36 +0000
Sun, 18 Dec 2022 01:10:36 +0000 quote
Change the plug? Hmmmm....
Sun, 18 Dec 2022 02:36:45 +0000
Sun, 18 Dec 2022 02:36:45 +0000 quote
Did try a new plug already.
Sun, 18 Dec 2022 03:02:43 +0000
Sun, 18 Dec 2022 03:02:43 +0000 quote
Hmmmm. Green wire kinda shorting out? Hmmm
I'm really curious to hear what fixes this. It's a mystery....
Sun, 18 Dec 2022 03:34:13 +0000
'58 VBA
'58 VBA
Sun, 18 Dec 2022 03:34:13 +0000 quote
Is the spark hot enough? I had a loose plug end on the wire that would spark, but not start.
Sun, 18 Dec 2022 03:51:21 +0000
Sun, 18 Dec 2022 03:51:21 +0000 quote
I tried with the known good cdi/wire/cap, it should be. But I like how we are thinking out of the normal box here.
Sun, 18 Dec 2022 04:06:23 +0000
Sun, 18 Dec 2022 04:06:23 +0000 quote
... and timing. Check the timing.
Sun, 18 Dec 2022 05:18:33 +0000
Sun, 18 Dec 2022 05:18:33 +0000 quote
I can make marks to check timing but if it doesn't run it's hard to use them. I set it to IT for now. That worked well enough on the Stella engine with these parts. Any suggestions?
Sun, 18 Dec 2022 05:57:45 +0000
Sun, 18 Dec 2022 05:57:45 +0000 quote
Green wire was fine on last engine and I've tried it disconnected just in case.
Sun, 18 Dec 2022 10:57:50 +0000
Sun, 18 Dec 2022 10:57:50 +0000 quote
Did you try starter fluid yet? I always feel kind've cheap n' dirty resorting to it, but it's a great troubleshooting tool all the same.
Sun, 18 Dec 2022 15:46:18 +0000
Sun, 18 Dec 2022 15:46:18 +0000 quote
I've got to reseal the head and then starting fluid is next. Lots going on though, so it may be a little bit.
Sun, 18 Dec 2022 15:49:12 +0000
Vespa 125 VMA, Vespa SS 180
Sun, 18 Dec 2022 15:49:12 +0000 quote
A while back I had a similar issue to yours. I would check for spark and spark was good. Tried to start it and wouldn't start. New spark plug, and still wouldn't start. Robbed a known good CDI, stator, flywheel, carb, etc off another Vespa and still wouldn't start. At this point, frustrated, I gave up for a few days. I finally decided the only thing I hadn't taken off the known working Vespa was the spark plug. Put it in and started right up. Turns out I had a pack of 4 new NGK spark plugs that were all bad. They would show spark when you checked, but wouldn't start when in the cylinder head. Not sure if this is your issue, but thought I'd put it out there. Best of luck figuring it out!
Sun, 18 Dec 2022 17:39:51 +0000
Sun, 18 Dec 2022 17:39:51 +0000 quote
thanks Langolson - definitely worth checking, I've got different plugs around from different times, so will do if the starting fluid test fails.
cylinder head back on with copper spray a gasket, will try to fire it later, hopefully. if not, then tomorrow.
Tue, 20 Dec 2022 01:41:49 +0000
Tue, 20 Dec 2022 01:41:49 +0000 quote
I'll second a plug change as a just in case.
if that fuel is from July it's suspect for sure. like CM said, starter fluid or even carb/brake clean should sort that right out quick.
you're right there, it's just a hiccup!
Wed, 21 Dec 2022 04:51:15 +0000
Wed, 21 Dec 2022 04:51:15 +0000 quote
update:
starter fluid makes no appreciable difference. i assume that means the carb and gasoline are probably ok. doesn't it mean my problem is ignition?
plug removed from stella engine and put into the PX125 engine, no difference
green wire from harness removed, no difference
what gives? I have all the components from the running engine onboard and it won't run.
i'm thinking along socalguy's ideas now - is it possible the crank key is in the wrong location, putting the timing off? is it possible the stator is 120 off? I don't think so on that one, the stator timing marks and case timing marks are together, set to IT.
is it somehow possible the plug won't spark in the head but is OK out of it? if so why?
I was thinking maybe the piston is stamped wrong for direction but the ring pegs were on the top side where they belonged. I don't think this can be it.
Wed, 21 Dec 2022 05:59:36 +0000
parallelogramerist
parallelogramerist
Wed, 21 Dec 2022 05:59:36 +0000 quote
You can get a visibly good spark from a bad plug...even if that plug is brand new. Many knockoff NGK plugs (and many other brands too) are sold on ebay.
Wed, 21 Dec 2022 06:33:14 +0000
Wed, 21 Dec 2022 06:33:14 +0000 quote
quick thought, is the Stella flywheel external trigger and the PX is internal?
beyond that, I think there's a ghost in the machine...
Wed, 21 Dec 2022 10:06:11 +0000
Wed, 21 Dec 2022 10:06:11 +0000 quote
sdjohn wrote:
update:
Weird. So it still starts eventually but won't rev? Or won't run at all? Is it a Stella with reeds?
Wed, 21 Dec 2022 14:13:02 +0000
Wed, 21 Dec 2022 14:13:02 +0000 quote
With much effort eventually it can sort of run but wants to stall. It will rev once you get it there. It acts like it's always flooding.
It's a px 125 with all px parts. To be clear I was running all these parts on my Stella engine - I've gotten rid of all the Stella specific parts a long time ago as far as ignition goes.
I'm thinking now to advance the stator a lot - I'm at the far end of the slots in the retard direction. Since it can run maybe it's just super late.
Wed, 21 Dec 2022 14:41:01 +0000
VNB VSC 09C VMA VSX - vbc vmb
Wed, 21 Dec 2022 14:41:01 +0000 quote
I had the flywheel slip (always use a torque wrench... ahem) on my white P rebuild and it went all pear shaped...
Pull the flywheel, (assess timing marks again but don't make drastic changes unless you were obviously wrong the first go around), new woodruff, reassemble, torque to spec.
Wed, 21 Dec 2022 14:43:38 +0000
Wed, 21 Dec 2022 14:43:38 +0000 quote
Yeah I'll look at that when I pull it to advance it. My idea is to make it run well enough that I actually can make marks and check timing appropriately.
[ Time: 0.1961s ][ Queries: 4 (0.1716s) ][ Debug on ][ 298 ][ Thing Two ]
