![]() 1969 Vespa Rally 180, 2014 Yamaha Bolt 950, 2015 Vespa Primavera 150, 2015 Honda Grom 125
Posts: 376 Location: Gulf Breeze, FL |
Sat, 26 Mar 2016 23:58:57 +0000
quote
Hey there! I just pulled my clutch bell off for a belt replacement. It was a pain- stuck as heck. Now, trying to get it back on, it won't go. Gets stuck at the spline. Do I need to replace it? Not an expert but don't see damage to the bell or spline?
Sun, 27 Mar 2016 00:20:54 +0000
quote
Jescka084 wrote: Sticks here. Won't go pat this. I use a three leg puller to get it off. To get it back on I use a stack of washers and tighten bolt until it bottoms out. Then I add more washers and repeat till the bell is fully seated. |
![]() 2009 LX 150, 2008 GTS 250
Posts: 875 Location: Birmingham, Alabama, USA |
Sun, 27 Mar 2016 00:42:18 +0000
quote
Maybe you should clean the spline grooves on both parts very thoroughly with a screw driver blade. One groove at a time to get any corrosion out. Then check to be sure there isn't a distorted tooth. Follow up with some WD40 on the mating splines using a tooth pick and a rag. Then wipe it all off before you assemble. That will give the splines their best chance at a smooth, normal fit.
Bill
Positive
Sun, 27 Mar 2016 01:15:40 +0000
quote
That worked!! It may be hard to take off again next time, but it's on there and I think seated well.
I love MV! Thanks again! |
![]() 63 GL 150, 05 Typhoon, 09 Beo 200
Posts: 1725 Location: Grand Pothole Rapids, Michigan |
Sun, 27 Mar 2016 06:33:30 +0000
quote
What I do, is mark both parts, in one spot, before taking it off, so I can Aline them together at the same spot, when I reinstall them....
Vespa LX 150. Yamaha AS1. Honda CX500. Triumph Bonneville T100 2017
Posts: 96 Location: NZ |
Sun, 27 Mar 2016 08:51:07 +0000
quote
I used a 2 leg puller on mine today and it was still extremely difficult to remove. In the end I used a rattle gun on the puller bolt. It slowly came loose but fought the whole way. I also tried to clean the splines and replace the bell. No way is it going back on smoothly. I have still to get a belt etc so not refitting yet. Is a small amount of grease wise here? I know the clutch would not appeaciate grease but it is protected by the sleeve.
LX150 27,000 km. Don |
Sun, 27 Mar 2016 13:19:10 +0000
quote
I would say that a very light coat of copper anti seize grease is ok. Rub it thin because sliding the pieces together will potentially plow the grease off and into a small lump.
My bell slides right off so I would be worried if it was tight like yours. Bill |
2015 BV350 2007 GTS(sold) 2003 BV200
Posts: 773 Location: nyc |
Sun, 27 Mar 2016 13:37:26 +0000
quote
Cosmos wrote: I would say that a very light coat of copper anti seize grease is ok. Rub it thin because sliding the pieces together will potentially plow the grease off and into a small lump. My bell slides right off so I would be worried if it was tight like yours. Bill I agree should not be so tight on or off. John |
![]() Sun, 27 Mar 2016 13:56:29 +0000
Scooter Pimp
Posts: 3098 Location: England |
quote
Rub the splines/grooves lightly with some wet'n'dry to remove any rust or debris.......and then clean off with brake cleaner or similar.
I use a very light smeer of white grease when re-assembling to aid slipping the clutch back onto the splines. |
Posts: 42054 Location: Pleasant Hill, CA |
Sun, 27 Mar 2016 14:27:50 +0000
quote
On Ivana Tinkle's LX a new clutch bell was the only answer. No matter how much I scraped and filed, the original bell was far too tight on the splines.
![]() Sun, 27 Mar 2016 14:29:13 +0000
Posts: 2380 Location: St. Pete, Fla |
![]() Vespa LX150 GTS250ie GTS300x2 sold 'em
quote
jimc wrote: On Ivana Tinkle's LX a new clutch bell was the only answer. No matter how much I scraped and filed, the original bell was far too tight on the splines. |
![]() Sun, 27 Mar 2016 14:29:27 +0000
quote
Sun, 27 Mar 2016 14:33:31 +0000
quote
A rubber hammer wouldn't have touched it. I didn't want to have the same aggro in a few month's time, so just installed a new bell.
Sun, 27 Mar 2016 19:09:37 +0000
quote
![]() Sun, 13 Nov 2022 11:17:32 +0000
Vespa et4 leadier 125, Vespa Lx 50 2t
Posts: 21 Location: Vilnius |
![]() Vespa et4 leadier 125, Vespa Lx 50 2t
quote
Thank you all for your posts. This is what I found on my et4 leader 125 engine today. I pulled the bell off with a makeshift puller (pic), then, the bell didn't go back on, even after cleaning. Then I flipped the bell upside down and easily slid it onto the shaft by its other end! - so it appeared, that the part of the splines that are tight are not engaging with the shaft in this way. It is very difficult to see the difference between the splines on both ends of the bell's barrel hole, so I filed lightly the tops of the splines on the though end, and the bell felt easier a bit, then (see pic), I covered the spline grooves with the marker ar tried it on again and it showed the scratches in the grooves, while spline tops were untouched. So again, I filed each groove lightly with a metal file at about 5 degree angle to the spline's horizontal plane. Bel now fits snugly, and comes off pulled by hand. My theory of what happened here: the splines on the shaft are shorter that the splines on the bell. It allows putting the bell on in dirty road conditions - the dirt will collect in the recessions on both ends of the spline and will not alter the length of the stack. But at the same time it happens, that the inner ridge of the bell spline rams into the edge of the shaft's groove at 45 degree angle. I guess that in case the shaft bolt is overtightened, affected by heating and cooling cycles, those few millimeters of the bell spline that hangs over the shaft's groove, get compressed and get out of shape by less than 10 microns, that's absolutely perfectly enough to stick the bell in place. Lubrication may not help here, best is not to overtighten the bolt using a new bolt every time or using old one with Loctite blue. Btw, no tapping on the shaft even with rubber mallet! The long arm makes huge leverage that may shatter bearings!
![]() the puller ![]() spline ridge |
Sun, 13 Nov 2022 15:58:23 +0000
quote
I had a similar problem getting mine off - but that was due to a bit too much loctite (which got into the splines).
![]() Sun, 13 Nov 2022 16:22:29 +0000
S150 '09, Beo 500ie '08
Posts: 996 Location: Bermuda |
![]() S150 '09, Beo 500ie '08
quote
Harbor Freight sells a very inexpensive set of three-arm gear pullers that make short work of clutch bell and variator removal.
You can see how the clutch axle has a countersink in its center - that's there to help center removal tools like the gear puller. |
