Sun, 13 Nov 2022 17:34:55 +0000
Sun, 13 Nov 2022 17:34:55 +0000 quote
SoCalGuy wrote:
I'm intrigued by this.
That is Chris trying to identify what the chassis number actually is. What do y'all think?
Is it an 8 or a 3?
Sun, 13 Nov 2022 20:48:42 +0000
VNB VSC o9c VMA vbc vmb VSX
Sun, 13 Nov 2022 20:48:42 +0000 quote
Nice work. You guys rocked that mod.
Sun, 13 Nov 2022 21:02:51 +0000
Sun, 13 Nov 2022 21:02:51 +0000 quote
VIN is probably 49759 which would put it correctly in 1963. Should be a stamped star between the prefix and serial. Maybe use a wire brush to clean the surface rust...
These are the serials produced from 1962 to 1965
VLA1T 1962 1001 - 5958
VLA1T 1963 5959 - 57103
VLA1T 1964 57104 - 78009
VLA1T 1965 78010 - 80855
Sun, 13 Nov 2022 21:58:41 +0000
Sun, 13 Nov 2022 21:58:41 +0000 quote
+1 on 49759
Sun, 13 Nov 2022 22:08:45 +0000
P200
P200
Sun, 13 Nov 2022 22:08:45 +0000 quote
Thanks for help on the numbers guys it's been a real head scratcher for me.
Mon, 14 Nov 2022 01:57:14 +0000
Vespa
Vespa
Mon, 14 Nov 2022 01:57:14 +0000 quote
try doing a rubbing with paper and pencil I've had the DMV do this.
Mon, 14 Nov 2022 02:55:10 +0000
Mon, 14 Nov 2022 02:55:10 +0000 quote
That "3" is an 8.
A Piaggio 3 would have a sharp upper-right corner, like your 7.
VLA1T24849759
Mon, 14 Nov 2022 03:21:06 +0000
Mon, 14 Nov 2022 03:21:06 +0000 quote
Good info on the chassis number guys! Thank you!
So I've been checking out the wiring. It is definitely original for a VLA1T w/battery. Thank you scooterhelp.
So the way I see it, I've got three option. Whatever option I go with it'll need a handlebar switch, brake switch, and a regulator. Also, the stator is a 7 wire P200e stator.
1) Use original harness and modify for stator
2) Buy a new harness for non battery and modify for p200 stator
3) build my own
And then there is going full 12VDC and headlight config. It's original headlight case so it'd be great to stick a bulb in it and have.it "work" whether it's 12AC or DC. I have experience with hooking up a 12VAC Vape system.
For example, The 62 Allstate had both brake and handlebar switches 6v system. The VAPE 12VAC system worked great hooked up to the loom and I bought 12v bulbs from AutoZone that are still working 2 years later.
So my question to you all is: what would you do, and how would you do it?
Any input would be appreciated Thank you
VLA1T W/BATTERY it matches the colors in the existing harness.
The 7-wire stator. The engine currently will start and run like this.
The headlamp bezel and mount
Handlebar switch wiring
Tue, 15 Nov 2022 03:05:12 +0000
Tue, 15 Nov 2022 03:05:12 +0000 quote
After staring at the wiring diagram for a day I've decided to use the original wiring and leave the system AC.
I called "The Market" and talked with Matt, and he steered me in the right direction for the brake switch, headset switch, and 12VAC regulator. With that on its way, I decided to start it up and check the stator output.
13.1VAC between the red and yellow wires. It's a single yellow stator. So while I wait for the switches to arrive, I'll study the wiring diagram some more and figure out how and where to hook it all up.
And in the meantime I'll take apart the headset and clean & grease everything. Then the front hub. Then the fork.
What a fancy temporary gas tank
The fork and wires. I thinkk the wires are supposed to come up on the right, not the left. Any ideas?
Another angle
All the headset parts ready to be cleaned and put back together
Tue, 15 Nov 2022 03:08:53 +0000
Tue, 15 Nov 2022 03:08:53 +0000 quote
whodatschrome wrote:
One last thing, is the cap for that oil reservoir vented?
Here is a picture of the cap. I might make a bigger vent hole, just to be on the safe side.
A little small for my comfort
Tue, 15 Nov 2022 14:26:38 +0000
Tue, 15 Nov 2022 14:26:38 +0000 quote
A quick note of kudos. Again... great mod... The oil tank fix has a fair amount of genius in the simplicity. Really really cool fix.
*tips hat*
Tue, 15 Nov 2022 14:36:19 +0000
Tue, 15 Nov 2022 14:36:19 +0000 quote
You'll be fine. That vent hole on yours looks to be twice the size of mine
Tue, 15 Nov 2022 21:49:58 +0000
Tue, 15 Nov 2022 21:49:58 +0000 quote
Thanks BirdsNest! I think it's going to work out well!
And that's good to know FM. Thank you!
Today I don't have much time, but did get the rusty bits in to soak in a bin of E.vaporust. also took some 0000 steel wool to the inside of the headset.
Evaporust to make cleaning easier
The inside of the headset is looking good...
Breakfast of champions
Tue, 15 Nov 2022 22:27:53 +0000
Tue, 15 Nov 2022 22:27:53 +0000 quote
Not to scare you… but it appears the shifter tube has a pretty significant tumor.
Tue, 15 Nov 2022 23:29:14 +0000
Tue, 15 Nov 2022 23:29:14 +0000 quote
Ha! That's pretty funny - it's got a TUMURR
Tumor extracted!
Tue, 15 Nov 2022 23:32:23 +0000
1960 Allstate VNA, 1962 VNB
Tue, 15 Nov 2022 23:32:23 +0000 quote
Wed, 16 Nov 2022 00:08:21 +0000
Wed, 16 Nov 2022 00:08:21 +0000 quote
What a crack up!
I managed to pull the parts out of the Evaporust, rinse with water, then scrub down with steel wool and a wire brush, and WD-40, Then rinse with WD-40 and wipe down.
The headset is now ready to be reassembled with grease...
Wiping the parts down
Ready for reassembly
Wed, 16 Nov 2022 08:16:17 +0000
The Dude
The Dude
Wed, 16 Nov 2022 08:16:17 +0000 quote
Great work guys! This GL is gonB GoodLookin. Keep it up
Wed, 16 Nov 2022 15:39:51 +0000
Wed, 16 Nov 2022 15:39:51 +0000 quote
I ran into this problem trying to lift a key code off the lock cylinder for my bus. I took a photo with my iPhone, enlarged it and played with the filters, contrast, etc until I could see it clearly. Actually, I do this with stuff other people can see. You could also take a photo of the backside and reverse the photo.
Wed, 16 Nov 2022 15:51:54 +0000
Wed, 16 Nov 2022 15:51:54 +0000 quote
Here's some minutiae I just noticed ...
Does your GL have a dot or a line on the shifter tube between 1 and 2? What about the headset - line or pointer?
The guy in charge of stamping probably just grabbed whatever was nearby.
What do others have?
Line on tube and pointer on the headset
Thu, 17 Nov 2022 02:57:09 +0000
Thu, 17 Nov 2022 02:57:09 +0000 quote
Dot and line...
Sit and line, or is that a pointer?
Thu, 17 Nov 2022 03:06:15 +0000
Thu, 17 Nov 2022 03:06:15 +0000 quote
I downloaded the parts manual to see what parts we're missing in the headset. A number of parts, it turns out.
I did manage to put the shifter tube back together, and after 10 minutes of wrestling, got the aluminum cover off the fork. It was crusted on and probably hasn't been off in 48 years...
I'm going to pull the hub apart before placing another order...
Like Buttah now. It was like 80 grit before
No pin in the hub, and needs major cleaning, and a new brake pin, and brakes...
Eee-gads, that's some nasty crud. I'm surprised its still alive and moving
Thu, 17 Nov 2022 23:10:41 +0000
Thu, 17 Nov 2022 23:10:41 +0000 quote
Today was productive, and destructive....
I pulled the front hub apart, and it was a rusty, crusty mess, and removed the whole front steering column.
The shock bolt was frozen in the hub casting and the shock tube. I used penetrating oil, cleaner, and heat. I started by tapping, then escalated to pounding and still nothing. I put a wrench on the bolt and FINALLY got some moment, and the two prominent points on the shock tube promptly broke the casting of the swing arm. F$&k! Out came the pipe wrench.
Between the pipe wrench holding the shock tube, and the wrench turning the bolt, I managed to get the shock tube out, and pounded the bolt out of the swingarm.
So now I don't know if I can use this swingarm. I'm bummed ...
This thing is crusty and flattened out
Got the axle and bearings out
The brake lever barely turned! It was froze in the housing. I had to tap it out. Even with new shoes the brakes wouldn't work
Wrong nuts and bolts for the fender. I'm just gonna pull it
Snapped the spring mount off, it was so rusted
Clump of rusty bearings from the pivot
A block of rust in there
Swingarm with brake and pivot pins removed
Disaster. I finally got that dang bolt out, but look at the carnage. Do you think I could still use it?
Fri, 18 Nov 2022 14:17:53 +0000
Fri, 18 Nov 2022 14:17:53 +0000 quote
Ouch. Had the same problem, shock bolt was fused to the swing arm and wouldn't budge. For future reference, took it to a machine shop and the guy told me the trick is to heat the bolt until it's cherry red hot, then tap or press it out.
Add to shopping list.
https://www.scooterwest.com/front-fork-swing-arm-assembly-sprint-rally-078724.html
Fri, 18 Nov 2022 14:20:20 +0000
Fri, 18 Nov 2022 14:20:20 +0000 quote
Vaporblast and weld. It's original and definitely better than any repro part, especially the ones from FA that have more mozzarella in them, than aluminum…
Fri, 18 Nov 2022 14:23:00 +0000
Fri, 18 Nov 2022 14:23:00 +0000 quote
Ffffffffaaaaaaaaaaaa
ck
Sorry man. What a kick in the berries.
Fri, 18 Nov 2022 14:43:18 +0000
parallelogramerist
parallelogramerist
Fri, 18 Nov 2022 14:43:18 +0000 quote
That sucks big time Scott.
And by the way, if you're wanting to clean the VIN so that you can read it better, scrub it with a little wire brush (and not a wire wheel!) and Ospho. After a few minutes of scrubbing the metal will become very shiny (keep it wet the whole time). You might have to repeat the process a few times, but you'll have excellent results.
Fri, 18 Nov 2022 16:18:33 +0000
Fri, 18 Nov 2022 16:18:33 +0000 quote
Thanks Mike! And great info for future tteference. In hindsight I should've torched the bolt. Makes sense.
We're going to go this way as a last resort. The new hubs are different than the old hubs, and require you buy all new hardware, and probably a new axle at that point to fit. I went through that when updating the VNB2 front end.
But worse come to worse, it's not the end of the world and we can buy new...
See the bolt setup? It requires a clip between them to hold them in place
The original uses actual bolts and are recessed in the swingarm
Fri, 18 Nov 2022 16:22:05 +0000
Fri, 18 Nov 2022 16:22:05 +0000 quote
Thanks SaFiS! And I think I know just the welder here in town. Then I can just file the channels clean.
The hard part is finding a vapor blaster in the area, which they're aren't any. I'm gonna call a couple car guys. They all have media cabinets though, and not vapor blasting...
Fri, 18 Nov 2022 16:26:38 +0000
Fri, 18 Nov 2022 16:26:38 +0000 quote
Yeah, I had to walk away and swear like a sailer that just lost his sail....
But today is a new day and the seas don't look as rough
I mean, the top edge of the mount is still there, so theoretically I could just use it as is, and it should work fine. I've seen people grind off the tabs to make the shock work, so ...
Fri, 18 Nov 2022 16:38:08 +0000
Fri, 18 Nov 2022 16:38:08 +0000 quote
maybe you could have it repaired by weld / machine / drill out again. It seems like nothing worse than what Gick regularly repairs on engine cases. Maybe cheaper than a new one too or the same cost but saves you replacing other bits.
Fri, 18 Nov 2022 17:02:37 +0000
Fri, 18 Nov 2022 17:02:37 +0000 quote
And by the way....
Thanks JohnnyG! I'm gonna try this, or Chris will.
Fri, 18 Nov 2022 17:07:45 +0000
Fri, 18 Nov 2022 17:07:45 +0000 quote
Yes! Thank you John! This is what the calm seas of a new day are bringing to my peabrain while I swill some coffee and contemplate the front end.
And thank you all for the conformation and alternatives. With these 50+ year old machines, it seems there is always a Plan A, Plan B, and C, D & E, just in case A doesn't pan out, which it rarely does.
This one rattled me though. I fought with every single nut and bolt taking this front end apart, and the shock bolt was the last piece to remove....
Fri, 18 Nov 2022 17:18:04 +0000
parallelogramerist
parallelogramerist
Fri, 18 Nov 2022 17:18:04 +0000 quote
I usually start out with a brass brush since it's a bit softer. If i'm not getting the results i'm after, then i'll switch out to a stainless steel. They're cheap to buy at Homo Depo. I've also bought them at a welding supply store as well. Make sure to wear gloves and glasses since that Ospho seems to get spattered everywhere when you're scrubbing with a wire brush.
Sat, 19 Nov 2022 00:32:29 +0000
Sat, 19 Nov 2022 00:32:29 +0000 quote
Happens to the best of us. Always seems to happen when you are coming down the home stretch.
Sun, 20 Nov 2022 03:53:36 +0000
Sun, 20 Nov 2022 03:53:36 +0000 quote
e parts is the next order of business. I've been degreasing the bearings and scrubbing the 59 years of gunk off these parts.
I'm soaking some in Evaporust that have some rust, then wire brush. I'll break out the Dremel with the abrasive heads tomorrow to take the next layer off. I haven't found someone in town yet that does vapor blasting, but I'll keep looking.
Jeez, these parts are gunky
Cleaning up the steering tube
The speedo gear was frozen in the housing....
Lots of.parts soaking in Evaporust
Fri, 25 Nov 2022 06:28:01 +0000
Fri, 25 Nov 2022 06:28:01 +0000 quote
I hope everyone had a Happy Thanksgiving and y'all ate your fill. I made a couple pumpkin p.i.e.s with a gluten free graham cracker crust that was delicious! And of course, real whipped cream, by hand, with a touch of nutmeg and vanilla.
But I digress. A friend of mine in town said I should try these aluminum rods to weld the pieces back in to the shock mount, and he gave a few to use.
Big fail. the chip essentially melted into a puddle. I at least have it shot. Time to take the piece to the welder.
In the meantime, I'm cleaning up the parts of the front end to paint. We're going to go the route exmayor went on one of his smallies - ford wheel paint grey and satin clear.
Yummm
Epic fail with those aluminum rods. Time to take it to a professional
Lots of sanding and cleanup to do before paint
Paint from AutoZone
Fri, 25 Nov 2022 15:44:58 +0000
Fri, 25 Nov 2022 15:44:58 +0000 quote
Yummy stuff there and good luck on the welding!
Fri, 25 Nov 2022 16:42:21 +0000
Fri, 25 Nov 2022 16:42:21 +0000 quote
Yeah, building up aluminum is a lot harder than building up steel, I've found. I pretty much have to just build up a giant pile and then machine it back down to what I wanted in the first place.
Fri, 25 Nov 2022 17:44:36 +0000
Fri, 25 Nov 2022 17:44:36 +0000 quote
That's how I weld everything. I could only get so good at welding, so I became an accomplished grinder.
[ Time: 0.0520s ][ Queries: 6 (0.0259s) ][ Debug on ][ 276 ][ Thing Two ]
