SoCalGuy wrote:
I'm intrigued by this.
Is it an 8 or a 3?
Posts: 3459 Location: Florence, OR |
Sun, 13 Nov 2022 17:34:55 +0000
quote
SoCalGuy wrote: I'm intrigued by this. ![]() Is it an 8 or a 3? |
Posts: 6804 Location: Hustletown, TX |
Posts: 3458 Location: Veria, Greece |
Sun, 13 Nov 2022 21:02:51 +0000
quote
VIN is probably 49759 which would put it correctly in 1963. Should be a stamped star between the prefix and serial. Maybe use a wire brush to clean the surface rust...
These are the serials produced from 1962 to 1965 VLA1T 1962 1001 - 5958 VLA1T 1963 5959 - 57103 VLA1T 1964 57104 - 78009 VLA1T 1965 78010 - 80855 |
![]() P200
Posts: 75 Location: Springfield, Oregon |
Sun, 13 Nov 2022 22:08:45 +0000
quote
Thanks for help on the numbers guys it's been a real head scratcher for me.
![]() Vespa
Posts: 1464 Location: California |
Mon, 14 Nov 2022 01:57:14 +0000
quote
try doing a rubbing with paper and pencil I've had the DMV do this.
Mon, 14 Nov 2022 02:55:10 +0000
quote
Scootnewb wrote: Thanks for help on the numbers guys it's been a real head scratcher for me. A Piaggio 3 would have a sharp upper-right corner, like your 7. VLA1T24849759 |
Mon, 14 Nov 2022 03:21:06 +0000
quote
Good info on the chassis number guys! Thank you!
So I've been checking out the wiring. It is definitely original for a VLA1T w/battery. Thank you scooterhelp. So the way I see it, I've got three option. Whatever option I go with it'll need a handlebar switch, brake switch, and a regulator. Also, the stator is a 7 wire P200e stator. 1) Use original harness and modify for stator 2) Buy a new harness for non battery and modify for p200 stator 3) build my own And then there is going full 12VDC and headlight config. It's original headlight case so it'd be great to stick a bulb in it and have.it "work" whether it's 12AC or DC. I have experience with hooking up a 12VAC Vape system. For example, The 62 Allstate had both brake and handlebar switches 6v system. The VAPE 12VAC system worked great hooked up to the loom and I bought 12v bulbs from AutoZone that are still working 2 years later. So my question to you all is: what would you do, and how would you do it? Any input would be appreciated Thank you ![]() VLA1T W/BATTERY it matches the colors in the existing harness. ![]() The 7-wire stator. The engine currently will start and run like this. ![]() The headlamp bezel and mount ![]() Handlebar switch wiring |
Tue, 15 Nov 2022 03:05:12 +0000
quote
After staring at the wiring diagram for a day I've decided to use the original wiring and leave the system AC.
I called "The Market" and talked with Matt, and he steered me in the right direction for the brake switch, headset switch, and 12VAC regulator. With that on its way, I decided to start it up and check the stator output. 13.1VAC between the red and yellow wires. It's a single yellow stator. So while I wait for the switches to arrive, I'll study the wiring diagram some more and figure out how and where to hook it all up. And in the meantime I'll take apart the headset and clean & grease everything. Then the front hub. Then the fork. ![]() What a fancy temporary gas tank ![]() The fork and wires. I thinkk the wires are supposed to come up on the right, not the left. Any ideas? ![]() Another angle ![]() All the headset parts ready to be cleaned and put back together |
Tue, 15 Nov 2022 03:08:53 +0000
quote
whodatschrome wrote: One last thing, is the cap for that oil reservoir vented? ![]() A little small for my comfort |
Tue, 15 Nov 2022 14:26:38 +0000
quote
A quick note of kudos. Again... great mod... The oil tank fix has a fair amount of genius in the simplicity. Really really cool fix.
*tips hat* |
Tue, 15 Nov 2022 14:36:19 +0000
Posts: 1288 Location: Philadelphia |
quote
qascooter wrote: Here is a picture of the cap. I might make a bigger vent hole, just to be on the safe side.
Positive
Tue, 15 Nov 2022 21:49:58 +0000
quote
Thanks BirdsNest! I think it's going to work out well!
And that's good to know FM. Thank you! Today I don't have much time, but did get the rusty bits in to soak in a bin of E.vaporust. also took some 0000 steel wool to the inside of the headset. ![]() Evaporust to make cleaning easier ![]() The inside of the headset is looking good... ![]() Breakfast of champions |
Tue, 15 Nov 2022 22:27:53 +0000
quote
Not to scare you… but it appears the shifter tube has a pretty significant tumor.
![]() 1960 Allstate VNA, 1962 VNB
Posts: 227 Location: Cambria, CA |
Tue, 15 Nov 2022 23:32:23 +0000
quote
Birdsnest wrote: Not to scare you… but it appears the shifter tube has a pretty significant tumor. ;- ![]()
Positive
Wed, 16 Nov 2022 00:08:21 +0000
quote
What a crack up!
![]() I managed to pull the parts out of the Evaporust, rinse with water, then scrub down with steel wool and a wire brush, and WD-40, Then rinse with WD-40 and wipe down. The headset is now ready to be reassembled with grease... ![]() Wiping the parts down ![]() Ready for reassembly
Positive
The Dude
Posts: 1473 Location: PNW from LBC |
Posts: 1522 Location: northern New York |
Wed, 16 Nov 2022 15:39:51 +0000
quote
qascooter wrote: That is Chris trying to identify what the chassis number actually is. What do y'all think?
Positive
Posts: 6644 Location: So Cal |
Wed, 16 Nov 2022 15:51:54 +0000
quote
Here's some minutiae I just noticed ...
Does your GL have a dot or a line on the shifter tube between 1 and 2? What about the headset - line or pointer? The guy in charge of stamping probably just grabbed whatever was nearby. What do others have? ![]() Line on tube and pointer on the headset |
Thu, 17 Nov 2022 02:57:09 +0000
quote
SoCalGuy wrote: Does your GL have a dot or a line on the shifter tube between 1 and 2? What about the headset - line or pointer? ![]() Sit and line, or is that a pointer? |
Thu, 17 Nov 2022 03:06:15 +0000
quote
I downloaded the parts manual to see what parts we're missing in the headset. A number of parts, it turns out.
I did manage to put the shifter tube back together, and after 10 minutes of wrestling, got the aluminum cover off the fork. It was crusted on and probably hasn't been off in 48 years... I'm going to pull the hub apart before placing another order... ![]() Like Buttah now. It was like 80 grit before ![]() No pin in the hub, and needs major cleaning, and a new brake pin, and brakes... ![]() Eee-gads, that's some nasty crud. I'm surprised its still alive and moving |
Thu, 17 Nov 2022 23:10:41 +0000
quote
![]() I pulled the front hub apart, and it was a rusty, crusty mess, and removed the whole front steering column. The shock bolt was frozen in the hub casting and the shock tube. I used penetrating oil, cleaner, and heat. I started by tapping, then escalated to pounding and still nothing. I put a wrench on the bolt and FINALLY got some moment, and the two prominent points on the shock tube promptly broke the casting of the swing arm. F$&k! Out came the pipe wrench. Between the pipe wrench holding the shock tube, and the wrench turning the bolt, I managed to get the shock tube out, and pounded the bolt out of the swingarm. So now I don't know if I can use this swingarm. I'm bummed ... ![]() This thing is crusty and flattened out ![]() Got the axle and bearings out ![]() The brake lever barely turned! It was froze in the housing. I had to tap it out. Even with new shoes the brakes wouldn't work ![]() Wrong nuts and bolts for the fender. I'm just gonna pull it ![]() Snapped the spring mount off, it was so rusted ![]() Clump of rusty bearings from the pivot ![]() A block of rust in there ![]() Swingarm with brake and pivot pins removed ![]() Disaster. I finally got that dang bolt out, but look at the carnage. Do you think I could still use it? |
Fri, 18 Nov 2022 14:17:53 +0000
quote
Ouch. Had the same problem, shock bolt was fused to the swing arm and wouldn't budge. For future reference, took it to a machine shop and the guy told me the trick is to heat the bolt until it's cherry red hot, then tap or press it out.
Add to shopping list. https://www.scooterwest.com/front-fork-swing-arm-assembly-sprint-rally-078724.html
Positive
Fri, 18 Nov 2022 14:20:20 +0000
quote
Vaporblast and weld. It's original and definitely better than any repro part, especially the ones from FA that have more mozzarella in them, than aluminum…
Fri, 18 Nov 2022 14:23:00 +0000
quote
Ffffffffaaaaaaaaaaaa
ck Sorry man. What a kick in the berries. |
Fri, 18 Nov 2022 14:43:18 +0000
parallelogramerist
Posts: 4165 |
quote
That sucks big time Scott.
And by the way, if you're wanting to clean the VIN so that you can read it better, scrub it with a little wire brush (and not a wire wheel!) and Ospho. After a few minutes of scrubbing the metal will become very shiny (keep it wet the whole time). You might have to repeat the process a few times, but you'll have excellent results.
Positive
Fri, 18 Nov 2022 16:18:33 +0000
quote
SoCalGuy wrote: Ouch. Had the same problem, shock bolt was fused to the swing arm and wouldn't budge. For future reference, took it to a machine shop and the guy told me the trick is to heat the bolt until it's cherry red hot, then tap or press it out. Add to shopping list. https://www.scooterwest.com/front-fork-swing-arm-assembly-sprint-rally-078724.html We're going to go this way as a last resort. The new hubs are different than the old hubs, and require you buy all new hardware, and probably a new axle at that point to fit. I went through that when updating the VNB2 front end. But worse come to worse, it's not the end of the world and we can buy new... ![]() See the bolt setup? It requires a clip between them to hold them in place ![]() The original uses actual bolts and are recessed in the swingarm |
Fri, 18 Nov 2022 16:22:05 +0000
quote
SaFiS wrote: Vaporblast and weld. It's original and definitely better than any repro part, especially the ones from FA that have more mozzarella in them, than aluminum… The hard part is finding a vapor blaster in the area, which they're aren't any. I'm gonna call a couple car guys. They all have media cabinets though, and not vapor blasting... |
Fri, 18 Nov 2022 16:26:38 +0000
quote
Birdsnest wrote: Sorry man. What a kick in the berries. But today is a new day and the seas don't look as rough I mean, the top edge of the mount is still there, so theoretically I could just use it as is, and it should work fine. I've seen people grind off the tabs to make the shock work, so ... |
Posts: 6888 Location: San Diego, CA |
Fri, 18 Nov 2022 16:38:08 +0000
quote
maybe you could have it repaired by weld / machine / drill out again. It seems like nothing worse than what Gick regularly repairs on engine cases. Maybe cheaper than a new one too or the same cost but saves you replacing other bits.
Fri, 18 Nov 2022 17:02:37 +0000
quote
whodatschrome wrote: That sucks big time Scott. And by the way.... |
Fri, 18 Nov 2022 17:07:45 +0000
quote
sdjohn wrote: maybe you could have it repaired by weld / machine / drill out again. It seems like nothing worse than what Gick regularly repairs on engine cases. Maybe cheaper than a new one too or the same cost but saves you replacing other bits. And thank you all for the conformation and alternatives. With these 50+ year old machines, it seems there is always a Plan A, Plan B, and C, D & E, just in case A doesn't pan out, which it rarely does. This one rattled me though. I fought with every single nut and bolt taking this front end apart, and the shock bolt was the last piece to remove.... |
Fri, 18 Nov 2022 17:18:04 +0000
parallelogramerist
Posts: 4165 |
quote
qascooter wrote: Thanks JohnnyG! I'm gonna try this, or Chris will.
Positive
Sat, 19 Nov 2022 00:32:29 +0000
quote
Happens to the best of us. Always seems to happen when you are coming down the home stretch.
Sun, 20 Nov 2022 03:53:36 +0000
quote
e parts is the next order of business. I've been degreasing the bearings and scrubbing the 59 years of gunk off these parts.
I'm soaking some in Evaporust that have some rust, then wire brush. I'll break out the Dremel with the abrasive heads tomorrow to take the next layer off. I haven't found someone in town yet that does vapor blasting, but I'll keep looking. ![]() Jeez, these parts are gunky ![]() Cleaning up the steering tube ![]() The speedo gear was frozen in the housing.... ![]() Lots of.parts soaking in Evaporust |
Fri, 25 Nov 2022 06:28:01 +0000
quote
I hope everyone had a Happy Thanksgiving and y'all ate your fill. I made a couple pumpkin p.i.e.s with a gluten free graham cracker crust that was delicious! And of course, real whipped cream, by hand, with a touch of nutmeg and vanilla.
But I digress. A friend of mine in town said I should try these aluminum rods to weld the pieces back in to the shock mount, and he gave a few to use. Big fail. the chip essentially melted into a puddle. I at least have it shot. Time to take the piece to the welder. In the meantime, I'm cleaning up the parts of the front end to paint. We're going to go the route exmayor went on one of his smallies - ford wheel paint grey and satin clear. ![]() Yummm ![]() Epic fail with those aluminum rods. Time to take it to a professional ![]() Lots of sanding and cleanup to do before paint ![]() Paint from AutoZone
Positive
![]() Fri, 25 Nov 2022 16:42:21 +0000
Posts: 7205 Location: Nashville |
quote
Yeah, building up aluminum is a lot harder than building up steel, I've found. I pretty much have to just build up a giant pile and then machine it back down to what I wanted in the first place.
Fri, 25 Nov 2022 17:44:36 +0000
quote
chandlerman wrote: Yeah, building up aluminum is a lot harder than building up steel, I've found. I pretty much have to just build up a giant pile and then machine it back down to what I wanted in the first place.
Positive
