Tue, 15 Nov 2022 16:39:14 +0000
parallelogramerist
parallelogramerist
Tue, 15 Nov 2022 16:39:14 +0000 quote
Another year, another bump...
I still haven't got around to firing up this scooter yet. For some reason i haven't been too motivated to finish up a few details on it...such as the wiring. All i need to do is buy a battery for it, then i can build a battery tray, wire in a relay and fuses, and hook up the ignition switch wires. It would literally be a one day job, but i've just been unmotivated to by a single flippin battery! I must be lazy or something.
BUT, i did install a LED inside my taillight. I used an off the shelf trucker light (that i bought from Six-States). I figure if the light can handle the riggers of being on a semi-trailer, then it can surely work on the back of a Vespa.
I simply gutted out the stock taillight housing enough to just barely fit in the LED. Then i gooped in a bunch of epoxy. Yes it looks ghetto, but once the lens is back on, it hides a multiple of sins. The bonus about using a "trucker" light is that they are pretty darn bright, which is always good thing when it comes to being seen on a moto.
Fri, 18 Nov 2022 12:27:01 +0000
PK50XL, PK100S, ET3
PK50XL, PK100S, ET3
Fri, 18 Nov 2022 12:27:01 +0000 quote
Do you need the wiring connected to start it? Surely just hearing it running will give you the motivation to get it finished so you can impress your neighbours with impromptu wheelies.
Fri, 18 Nov 2022 14:37:23 +0000
parallelogramerist
parallelogramerist
Fri, 18 Nov 2022 14:37:23 +0000 quote
Yes, i just need to finish up some wiring. Since i installed a variable Vape DC i need to move around a few wires and then add in a relay and some fuses...which i have had for at least a year all waiting to for me to install. For some reason i haven't been motivated to finish up the last little bit. It probably has to do with working on multiple other scooter projects that i'm trying to knock out...which is no excuse. I just need to pony up and buy a little Li-ion battery and spend the day or two to button it up.
Fri, 18 Nov 2022 21:38:27 +0000
Fri, 18 Nov 2022 21:38:27 +0000 quote
hey! I demand royalties! that is my trademarked excuse!
all kidding aside, I love the tail light mod. if I wasn't fully AC on the PK I'd totally do the same.
Sat, 19 Nov 2022 06:01:01 +0000
parallelogramerist
parallelogramerist
Sat, 19 Nov 2022 06:01:01 +0000 quote
Proof that i am really that close to finishing up the scooter. The stator and rectifier have been all wired up for the past year. I've also had the fuse/relay block fixings for the past year as well. I just need to buy a battery...so that i can fab a battery tray. Once the tray is built and positioned on the frame then i know where i can mount the fuse block...then i can finish the wiring. I'm also thinking about going back and installing an in-line flashing brake line module. Simply because i don't want to get rear ended by a car. I have them installed in all my other PX scooters and they do their job very well.
i'll wire it up so that the ignition key will activate the relay. I'll run my grip heaters and LED headlight (and eventually spot lights) through the relay.
It's about as compact of a water resistant fuse holder that i could find.
You can see the Vape rectifier tucked back in the frame. I left the stock regulator hooked up for now (so that i wouldn't forget what those wires are for when i go to finish up the wiring).
Fri, 30 Dec 2022 05:26:01 +0000
parallelogramerist
parallelogramerist
Fri, 30 Dec 2022 05:26:01 +0000 quote
I finished welding up a battery tray this evening. I made two battery trays. One for my Allstate 200 and one for this scooter. I ordered some aluminum spacers from Mcmaster and they arrived this afternoon.
If you look closely in the pic, you can see me still wearing a stiff sole medical sandal. Reason being is that i had metal plates and screw surgery removed from my foot about 1.5 weeks ago. I find it's a perfect footwear for welding in.
Spacers tack welded to the backside of the battery trays.
The rubber band is a 2000-2020 KTM dirtbike battery retaining strap and a kickstand retaining strap.
The box was built to fit a battery that i removed from my KTM.
Fri, 30 Dec 2022 05:46:10 +0000
parallelogramerist
parallelogramerist
Fri, 30 Dec 2022 05:46:10 +0000 quote
I also removed my Grimeca disc brake kit (it's going on my Allstate 200) and installed a LML Stella hydro brake. I couldn't find the LML's little metal retaining tab that compresses the little black rubber speedo cable doughnut, so i welded up extra material around that area so that i could use a PX/Grimeca retaining tab. I didn't take any pics of the welding process, but here's a couple of what the final product looks like. The paint was dry enough that i fitted the caliper carrier this evening.
You can kinda see where i built up some material, drilled a hole, then tapped it to a M5x.8 thread pitch.
I'm sure the missing LML retaining tab will show up very shortly...since i modified the caliper carrier to us a Piaggio tab.
Wed, 04 Jan 2023 02:39:20 +0000
parallelogramerist
parallelogramerist
Wed, 04 Jan 2023 02:39:20 +0000 quote
...and the propriety LML speedo cable retaining tab decided to grace me with its presence today. Turned out it was in a transparent peanut butter container...with "PK 125 parts" clearly written on the lid. Except the container was hiding out underneath the Allstate 200 project and not the PK project. I spent a lot of time looking for this part, both in my shop and online. I also spent even more time welding extra material onto the LML caliper carrier in order to utilize a PX retaining tab.
derp
⬆️    About 11w elapsed between posts    ⬇️
Wed, 22 Mar 2023 04:27:09 +0000
parallelogramerist
parallelogramerist
Wed, 22 Mar 2023 04:27:09 +0000 quote
I was looking around for some 12 volt SMD LED lights in my shop today AND i came across a brake light strobe module that i forgot i had! I've been wanting to install one, so it was definitely a good excuse to wire it up this evening.
This is the module that i have. Supposedly it's designed for incandescent lights and not LED, but since my LED has a high enough power, it works just fine. I also called the manufacturer today and the guy said it will work fine with my LED. https://www.signaldynamics.com/01001
This is the one that's recommended for LED https://www.signaldynamics.com/01004
Anyhow, i couldn't quite fit the module under my modified taillight housing, so i had to sand down the aluminum cased module a little bit. I mixed up some epoxy and stuck it to the PK's plastic taillight housing. A couple crimps and a smidge of solder and everything got buttoned back up about an hour ago.
Also a glamour shot of my new to me 1986 "vintage" Oregon license plate (if you can call 86 vintage). I found it on ebay and got it registered to this 1986 PK. I'm a HUGE anorak when it comes to license plates. The carpet has to match it the drapes when it comes to license plates on ALL my old vehicles (both 2 and 4 wheels)! As far as i'm concerned, a period correct license plate is the pièce de résistance.
The used brake light strobe i found in my shop.
Epoxied into place
The module will make the LED flash 3x then stay on solid for another 3 seconds. It will repeat that cycle for as long as the brake is activated.
my new 1986 plate! The plate is a little beat up, but then again so is the scooter.
Mon, 03 Apr 2023 02:55:53 +0000
parallelogramerist
parallelogramerist
Mon, 03 Apr 2023 02:55:53 +0000 quote
While i've been waiting for a few parts to show up for my rusty VB1 project, i FINALLY got around to finishing up the wiring on my PK. The scooter started out life as AC so i had to do a bit of wire swapping in order for it to work with my DC system. The accessories that i have on the scooter are-
-22 watt main LED headlight
-26 watt LED legshield spotlight
-40 watt grip heaters
-3 watt? LED taillight
-30 watt? horn
-incandescent turn signal lights
The horn and turn signals are rarely used, so those won't use up that many watts.
I used two different 20 amp micro relays in my harness. One relay sends power to the headlight, taillight, signals, horn. The other relay sends power to the legshield spotlight and the grip heaters.
It looks like a spaghetti mess in the pic, but in person it look a tad bit cleaner.
note the stainless steel ground stud that i welded in. It's located kinda behind the turn signal flasher.
Mon, 03 Apr 2023 03:08:13 +0000
parallelogramerist
parallelogramerist
Mon, 03 Apr 2023 03:08:13 +0000 quote
I like to use multiple frame grounds on all of my vehicle harnesses. So on the PK, i used no less than 3 welded in stainless steel studs welded to the frame...plus another redundant ground at both the CDI box and a ground attaching up to the lower headset. Greasy headset bearings are NOT good grounds!
a stud is welded to the frame at the regulator. Note that the ground rings are also attached to it.
another welded in ground stud at the lower portion of the steering column.
The stock CDI has a poor frame ground design, so with the VAPE CDI, i added one ground to the engine block, and another ground that terminals up at the regulator ground.
Mon, 03 Apr 2023 03:32:40 +0000
parallelogramerist
parallelogramerist
Mon, 03 Apr 2023 03:32:40 +0000 quote
It took a little bit of thinking, but i finally figured out how to completely rewire the stock PK's AC headlight switch to exactly how i wanted it to be.
What i wanted was to be able to turn off both my main headlight, taillight, and speedo light on and off separately from the spot light (and located on the left side of the handlebar. When the lights are turned on, the green low beam light illuminates. The legshield spotlight switch is located on the right side of the bar. I bought a brand new 2005 US market turn signal switch because it also has a separate red rocket switch that is an ignition kill switch. Anyhow i repurposed that kill switch as my spotlight switch. When the spotlight is turned on, the blue high beam indicator light illuminates. The spotlight and main lights can be used independently of each other.
The 3 position portion of the main headlight switch got repurposed into the grip heater controller (LOW/OFF/HIGH). All the wires are completely installed for the heaters, but i haven't bought them just yet. It's not a priority for me right now, but when the time comes, i'll probably install the stick on Symtec grip heaters.
green low beam light is illuminated when the main headlight/taillight is turned on.
just the blue high beam indicator light is illuminated when the legshield light is turned on.
Both green and blue indicator lights are on when both headlight and spotlight are turned on.
Mon, 03 Apr 2023 03:43:19 +0000
Mon, 03 Apr 2023 03:43:19 +0000 quote
That's badass man! Very cool, separate controls on the same switch.
Mon, 03 Apr 2023 03:59:27 +0000
parallelogramerist
parallelogramerist
Mon, 03 Apr 2023 03:59:27 +0000 quote
I have to cut an aluminum 1" spacer tube at an angle in order to use it as an adjustable mounting spacer on the legshield. The other half of the angled spacer is located on the inside of the legshield.
The LED headlight is a Baja Designs 22 watt S2 Pro Wide cornering lens . The legshield has a BD Squadron 26 watt Sport with an amber spot lens. I have a handful of other lenses on the shelf, so i might play around with whatever gives me the best beam pattern. The single 22 watt LED headlight provides plenty enough light at 55+ mph at night when the roads are wet (pavement turns a darker black when wet, and when that happens, it absorbs quite a bit of the lumens from a headlight. In the flip side, dry pavement and snow reflect the light, so a headlight will appear to be MUCH brighter).
a poor pic of the angled aluminum spacer
a small notch in the horncast for the pigtail
Mon, 03 Apr 2023 04:06:48 +0000
parallelogramerist
parallelogramerist
Mon, 03 Apr 2023 04:06:48 +0000 quote
It sure keeps it sanitary without extra auxiliary switches on the scooter. I've done this exact same setup on 3 other scooters. Each time it's a smidge bit different, but overall the exact same results. Back when they were still available, i bought 3 new 2005 US market PK150 turn signal switches just so that i could use that red rocker switch as a light switch. And yes, i do unsolder the tiny diameter stock wires and resolder back in high quality made in the USA 16 gauge TXL automotive wire in any switch that i repurpose.
Wed, 12 Apr 2023 04:54:29 +0000
parallelogramerist
parallelogramerist
Wed, 12 Apr 2023 04:54:29 +0000 quote
It's been a pinch over 3 years, and i FINALLY have the rear tire bolted back up to the hub! It finally seems like i might just be able to ride it around this coming summer. The wire harness is 99.9% competed. Now i'm just trying to decide if i want to run a 12 volt USB or SAE plug inside the glovebox (for charging a phone or GPS).
The Egig Superbanana Touring got installed this evening. I got a 180 degree elbow on top of the carb so that the throttle cable is now pointing at a great angle. The clutch and gear cables are hooked back up. The Trailtech TTO tach is now wrapped around the spark plug wire (and heat shrink over the top of it). I placed an order with SIP for a bunch of random jets, choke linkage bits, and an air filter for my Dellorto phbl 25. Maybe my order will arrive before the weekend?...
I still need to sort out the choke linkage
And this is what the Egig looks like installed. It's definitely not a pretty pipe, but if it works, then i'll be pleased
The tire and exhaust bolted back up. I haven't seen this view in a looooong time.
Thu, 04 May 2023 06:02:18 +0000
parallelogramerist
parallelogramerist
Thu, 04 May 2023 06:02:18 +0000 quote
I figured out an idea for a choke. Turns out that it will be just about impossible to fit both an air filter and the fuel tap rod at the same time. After staring at the scooter long enough i decided to relocate both the fuel tap rod AND the choke pull. As far as i can tell, this is my only option if i want to have any sort of chance to fit an air filter.
Using a knockout tool to punch the two holes through the frame.
The tool leaves a fairly clean hole.
I used a Stage 6 choke pull cable kit. It was already on my shelf, so in it went.
a pic of all the cable mocked up
I'm not to keen on the fuel line routing. It puts a fair amount of side load on the carb. I might try to route the hose a bit differently.
Wed, 10 May 2023 13:03:37 +0000
parallelogramerist
parallelogramerist
Wed, 10 May 2023 13:03:37 +0000 quote
I was hemming and hawing for a bit on this one, but i finally decided to drill an access hole in the frame directly beneath my carb. There are enough dents and dings that are currently on the scooter that the hole mod won't be a big deal to me. What it does do though is that it gives quick easy access to changing the jets!
2-3/4" hole saw made quick work
A supple rubber plug that was already on my shelf, just waiting for a home.
a view from below
Thu, 11 May 2023 05:20:38 +0000
parallelogramerist
parallelogramerist
Thu, 11 May 2023 05:20:38 +0000 quote
It was amateur hour in my shop yesterday...
I went to fire up the scooter for the first time in 3~4 years and i couldn't get the engine to rev up...almost as if there was a rag blocking the intake. And yeah, i found a waded up paper towel waaaay down deep in the intake. A fair amount of the paper got sucked into the combustion chamber as well. Hopefully no damage to the piston or rings! Once i fished out the paper, then engine fired right up!
And then i found an oozy oil leak at the rear hub. After remove the rear brake drum i found that the 3 retaining nuts were less than finger tight! And this is why i hate working on long term multiple projects at the same time. Some things that you ("you" as in myself) plan to tighten up at a later point can get forgotten about a year or so later.
the paper towel wad that was in my intake
the piston ate some of the oil and fuel soaked paper
loose nuts sink scooters
[ Time: 0.0896s ][ Queries: 4 (0.0650s) ][ Debug on ][ 299 ][ Thing Two ]
