Tue, 15 Nov 2022 20:32:01 +0000
Vespa sprint V150
Vespa sprint V150
Tue, 15 Nov 2022 20:32:01 +0000 quote
Hi guys I need some advice cus I'm really confused.
I have a Vespa 150 sprint 1976 with a 125cc engine in it, and it's registered on the log book as a 125cc. But, when I check the engine serial number it shows it as a 150 sprint veloce. Could the original engine have been reduced in cc?
Tue, 15 Nov 2022 20:51:14 +0000
'64 VBB, '74 BMW R75/6 airhead, Bultaco Alpina 250, Lambrettas
Tue, 15 Nov 2022 20:51:14 +0000 quote
Suggest you check for the motor serial number on the swingarm, as per below:
https://www.scooterhelp.com/serial/vespa.serial.locator.html
What are the letters there?
Also it would be helpful if you post up some pics of your bike so we can see what you're contending with.
Tue, 15 Nov 2022 21:00:00 +0000
Vespa sprint V150
Vespa sprint V150
Tue, 15 Nov 2022 21:00:00 +0000 quote
The number I have is on the engine swing arm VLB M with 7 numbers under it. I've checked the number online an it says 1976 150 sprint veloce. Could the cylinder head have been changed to a 125cc one?
Tue, 15 Nov 2022 21:02:10 +0000
Vespa sprint V150
Vespa sprint V150
Tue, 15 Nov 2022 21:02:10 +0000 quote
I think it says VLB 1M
Tue, 15 Nov 2022 21:11:08 +0000
1960 Allstate VNA, 1962 VNB
Tue, 15 Nov 2022 21:11:08 +0000 quote
It would be very easy to put a 125 cylinder, piston and head on the VLB.
To make a 150 again all you would need is the correct 3 port (if it is a Veloce) 150 cylinder, piston and head.
You could even make it a 177 with a kit from VMC or BGM
Tue, 15 Nov 2022 21:16:28 +0000
Vespa sprint V150
Vespa sprint V150
Tue, 15 Nov 2022 21:16:28 +0000 quote
Thanks, that answers my question. I might put it back to a 150. Thanks again for you help.
Tue, 15 Nov 2022 21:17:35 +0000
Tue, 15 Nov 2022 21:17:35 +0000 quote
How do you know it's 125?
Tue, 15 Nov 2022 21:22:01 +0000
Tue, 15 Nov 2022 21:22:01 +0000 quote
How original does the scoot appear to be -- has it been "restored" previously or is it a stock style survivor?
Tue, 15 Nov 2022 22:20:21 +0000
Tue, 15 Nov 2022 22:20:21 +0000 quote
Curious here as well.
Tue, 15 Nov 2022 23:19:32 +0000
Tue, 15 Nov 2022 23:19:32 +0000 quote
see his other posts for photos of the bike. it looks like a questionable "resto" to me.
Wed, 16 Nov 2022 05:56:20 +0000
Vespa sprint V150
Vespa sprint V150
Wed, 16 Nov 2022 05:56:20 +0000 quote
Looks in good condition for its age and it looks like it's had a partial tidied up but not professionally. Few aftermarket bits that can be changed back but seems ok for the purpose
Wed, 16 Nov 2022 11:30:24 +0000
PK50XL, PK100S, ET3
PK50XL, PK100S, ET3
Wed, 16 Nov 2022 11:30:24 +0000 quote
Its UK so has it been re-registered for riding on a learner license?
Wed, 16 Nov 2022 11:51:41 +0000
Vespa sprint V150
Vespa sprint V150
Wed, 16 Nov 2022 11:51:41 +0000 quote
I must admit it thought it may have just been a paper exercise to enable a leaner diver to ride it. When I take the head of how obvious will it be as to being a 125 or still the original 150
Wed, 16 Nov 2022 12:03:23 +0000
Wed, 16 Nov 2022 12:03:23 +0000 quote
it won't, you'll need to measure it.
52.5~53.1=125
57.8~58.4=150
Wed, 16 Nov 2022 12:06:09 +0000
Wed, 16 Nov 2022 12:06:09 +0000 quote
The size may also be stamped on the piston.
Wed, 16 Nov 2022 13:43:20 +0000
Vespa sprint V150
Vespa sprint V150
Wed, 16 Nov 2022 13:43:20 +0000 quote
Great, thanks for your help
Mon, 21 Nov 2022 05:59:57 +0000
Vespa sprint V150
Vespa sprint V150
Mon, 21 Nov 2022 05:59:57 +0000 quote
Anyone know the difference between a VBL and a VBB. They appear very similar when ordering parts.
Mon, 21 Nov 2022 06:15:26 +0000
Mon, 21 Nov 2022 06:15:26 +0000 quote
I assume you mean VLB, otherwise if your numbers start VBL that's a whole different can of fish.
there are several parts that are similar, there are several that interchange. not everything does and there are minor differences. details are important here.
if you don't know what you're doing or precisely what you need you may very well end up with the wrong parts or parts that won't work.
the best way to avoid this is to order from a known entity that you can whittle down the choices to items that only pertain to your specific model-- like SIP or scooter-center.
or ask somebody knowledgeable. but be specific, broad and vague questions get many responses and that easily makes the water murky.
Mon, 21 Nov 2022 08:25:40 +0000
Vespa sprint V150
Vespa sprint V150
Mon, 21 Nov 2022 08:25:40 +0000 quote
Sorry yes VLB.
Mon, 21 Nov 2022 23:49:56 +0000
Mon, 21 Nov 2022 23:49:56 +0000 quote
To save all the guesswork, please put up a photo!
Tue, 22 Nov 2022 00:31:34 +0000
Tue, 22 Nov 2022 00:31:34 +0000 quote
specifically the MOTOR and the engine numbers stamped on the case. that should erase a bit of confusion. or cause more. could go either way, really.
Tue, 22 Nov 2022 01:55:16 +0000
Tue, 22 Nov 2022 01:55:16 +0000 quote
True... here are his other posts, with a few pics of bits of the motor.
As it doesn't appear to be the ORIGINAL MOTOR (ie. wiring patched trice, cut once etc) who knows .
Piaggeo Vespa Sprint V 150
Throttle problem.
I've got Speedy's TWIN, which was from SAME N.Z. Factory, likely opin SAME MONTH of production (engine numbers about as close as you will ever find), but Speedy was a factory VBC150 & BRO was a factory VBC125.
As mentioned, it was only the cyl kit that differed.
An Original Super Resto?
The motor... at a guess it was promptly chopped out of some other scoot... nice to see the FINS appear to ALL be still in place (which kinda reduces the S.E.A Alert Radar)
Sun, 27 Nov 2022 18:01:46 +0000
Vespa sprint V150
Vespa sprint V150
Sun, 27 Nov 2022 18:01:46 +0000 quote
It appears to have had a 12v stator plate fitted but no indication as to having a electronic ignition fitted. I was planning on fitting a BGM Ducati stator plate kit to give me voltage and better starting, but now a bit stuck as which direction to go. Do I go for a full BGM Ducati kit, or is it possible to just add a CDI to what I have and would it need a regulator.
I will be putting in a new 12v wiring harness, but as I'm new to this I need the best and clearest way forward.
Everything else is going well with the restoration, just need a plan for the electrical side of things.
I have also attached a picture of the number stamp.
Thanks in advance
Mon, 28 Nov 2022 12:38:08 +0000
Mon, 28 Nov 2022 12:38:08 +0000 quote
If it's been registered as a 125 in uk downgraded from 150 the paperwork from mechanics would have been sent to dvla or even dvsa for checks. Upgraded they ain't bothered but downgrading they check. That being said now it's registered as 125 just stick a 166 or something on it as the 150 is pointless with no distinguishable performance gain. Really a waste of time. Nobody will ever check your barrel capacity. It's best left registered as 125 as easier to sell to learner licences but stick a bolt on kit on it if you want better power and this will make it safer on road to keep up with traffic and reduce the moron tailgaters .
Mon, 28 Nov 2022 13:02:17 +0000
Vespa sprint V150
Vespa sprint V150
Mon, 28 Nov 2022 13:02:17 +0000 quote
Sound like a plan, thanks for the advice
Mon, 28 Nov 2022 13:07:30 +0000
Mon, 28 Nov 2022 13:07:30 +0000 quote
woah, looks like Giuseppe had a little too much red before stamping the numbers that day!
Mon, 28 Nov 2022 14:17:11 +0000
PX 200
PX 200
Mon, 28 Nov 2022 14:17:11 +0000 quote
A re-stamp? Or are they really like that?
Mon, 28 Nov 2022 19:14:44 +0000
Mon, 28 Nov 2022 19:14:44 +0000 quote
All the ones stamped after lunchtime, anyway
Mon, 28 Nov 2022 20:09:43 +0000
Mon, 28 Nov 2022 20:09:43 +0000 quote
125 cc are popular in many countries where you can ride without a motorcycle license on it.
I've heard German (?) Cops carry a Dyno to check speed/output for scooters!
Mon, 28 Nov 2022 20:12:54 +0000
Mon, 28 Nov 2022 20:12:54 +0000 quote
I will be putting in a new 12v wiring harness.
So, you are going to the effort of a new harness, but cannot work out if you want to bodge the electrics or not?
Does it have POINTS?
My logic is that IF it has points, it's "manual ignition", if NO points, then its "electric ignition" & therefore 12v already.
Save your $$ for something more fun.
However, yip, adding that little box thingee that suits the blue (Ducati?) coil should work. Just get it going, then work out ignition system, as likely it already does something... just get a 2nd hand one (or borrow one)
unless you really intend to & can justify the upgrade to full BGM.
[ Time: 0.0413s ][ Queries: 6 (0.0159s) ][ Debug on ][ 276 ][ Thing Two ]
