Wed, 16 Nov 2022 17:36:37 +0000
VBA1T
VBA1T
Wed, 16 Nov 2022 17:36:37 +0000 quote
Actually restoring a VBA , I was wondering where to mount a hidden switch in order to avoid someone to kick and start the vespa ?
I could take the kick lever with me but not very practical
Wed, 16 Nov 2022 18:07:27 +0000
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Wed, 16 Nov 2022 18:07:27 +0000 quote
But think how cool you'd look walking around the shops with a kick lever hanging from your belt. Add a mohawk and some safety pins on your leather jacket and you'd be the talk of the town.
Seriously, there aren't a whole lot of places on a VBA for hidden switches. Unless you want to install a glovebox. But don't do that.
Wed, 16 Nov 2022 18:11:33 +0000
1968 VBB150
1968 VBB150
Wed, 16 Nov 2022 18:11:33 +0000 quote
I would maybe repurpose an existing switch. Maybe in the tank area you could put a bluetooth type kill switch, so that it disconnects the power wire to the coil or grounds the kill wire? You would of course have to replace the battery once and awhile.
I also want a solution for this.
Wed, 16 Nov 2022 19:39:49 +0000
VBA1T
VBA1T
Wed, 16 Nov 2022 19:39:49 +0000 quote
Mine has no battery !
I was thinking about an on/off switch under the left side panel for example, close to the regulator. Is there a wire from/to the regulator that could work ?
Wed, 16 Nov 2022 20:35:15 +0000
Wed, 16 Nov 2022 20:35:15 +0000 quote
No steering lock?
You "could" run a single wire under the tank to a switch inside the left cowl.
Switch connected to chassis ground and wire connected to the kill wire in your junction box.
Wed, 16 Nov 2022 20:42:07 +0000
VBA1T
VBA1T
Wed, 16 Nov 2022 20:42:07 +0000 quote
Ray8 wrote:
No steering lock?
Steering lock is not enough, some stupid could kick start the engine and do whatever damn thing.
Good idea with the kill wire, I think I'm going to do so
Wed, 16 Nov 2022 22:21:25 +0000
1968 VBB150
1968 VBB150
Wed, 16 Nov 2022 22:21:25 +0000 quote
https://www.amazon.com/DSD-TECH-Channels-Bluetooth-Compatible/dp/B07CZGCX9W/ref=sr_1_36?crid=1BRB59M7U4U8I&keywords=stand+alone+bluetooth+relay&qid=1668637195&sprefix=stand+alone+bluetooth+relay%2Caps%2C138&sr=8-36
This is kind of what I was referring to. You could power it with a standalone battery (small) and control it with your phone.
Thu, 17 Nov 2022 00:51:11 +0000
Thu, 17 Nov 2022 00:51:11 +0000 quote
I'm not sure what country you're in, but in the UK or the US, the thieves just wheel motorbikes into a van or throw them in the back of a truck. Here in Thailand, motorbikes are often wheeled away quietly at night. Starting the engine happens later, back at the thieves' den.
A switch is just a very light deterrent for a thief. A heavy lock and chain is better.
Thu, 17 Nov 2022 01:30:19 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Thu, 17 Nov 2022 01:30:19 +0000 quote
I had toyed with the idea of hooking a switch up under the seat in the air intake with a simple bracket using the seat bolts but haven't.
Thu, 17 Nov 2022 02:58:36 +0000
1959 VBA ,166, original 8's. 2005 Stella 177
Thu, 17 Nov 2022 02:58:36 +0000 quote
Ray8 wrote:
No steering lock?
This. It's how the PO did it in my VBA.
Fri, 18 Nov 2022 11:09:41 +0000
Fri, 18 Nov 2022 11:09:41 +0000 quote
Yours starts?
Speedy just sits there, not much chance anyone else would be able to get it started, and if they did, generally when they TRY to ride it, people fall off pretty quickly!
[ Time: 0.0347s ][ Queries: 4 (0.0050s) ][ Debug on ][ 276 ][ Thing Two ]
