Actually restoring a VBA , I was wondering where to mount a hidden switch in order to avoid someone to kick and start the vespa ?
I could take the kick lever with me but not very practical
![]() Wed, 16 Nov 2022 17:36:37 +0000
VBA1T
Posts: 93 Location: Belgium |
quote
I could take the kick lever with me but not very practical |
![]() 1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Posts: 1671 Location: Grand Rapids, MI |
Wed, 16 Nov 2022 18:07:27 +0000
quote
But think how cool you'd look walking around the shops with a kick lever hanging from your belt. Add a mohawk and some safety pins on your leather jacket and you'd be the talk of the town.
Seriously, there aren't a whole lot of places on a VBA for hidden switches. Unless you want to install a glovebox. But don't do that. |
Wed, 16 Nov 2022 18:11:33 +0000
1968 VBB150
Posts: 653 Location: OC |
quote
I would maybe repurpose an existing switch. Maybe in the tank area you could put a bluetooth type kill switch, so that it disconnects the power wire to the coil or grounds the kill wire? You would of course have to replace the battery once and awhile.
I also want a solution for this. |
![]() Wed, 16 Nov 2022 19:39:49 +0000
VBA1T
quote
dsnyder586 wrote: I would maybe repurpose an existing switch. Maybe in the tank area you could put a bluetooth type kill switch, so that it disconnects the power wire to the coil or grounds the kill wire? You would of course have to replace the battery once and awhile. I also want a solution for this. I was thinking about an on/off switch under the left side panel for example, close to the regulator. Is there a wire from/to the regulator that could work ? |
Wed, 16 Nov 2022 20:35:15 +0000
quote
ColinBelgium wrote: Mine has no battery ! I was thinking about an on/off switch under the left side panel for example, close to the regulator. Is there a wire from/to the regulator that could work ? You "could" run a single wire under the tank to a switch inside the left cowl. Switch connected to chassis ground and wire connected to the kill wire in your junction box. |
![]() Wed, 16 Nov 2022 20:42:07 +0000
VBA1T
quote
Ray8 wrote: No steering lock? You "could" run a single wire under the tank to a switch inside the left cowl. Switch connected to chassis ground and wire connected to the kill wire in your junction box. Good idea with the kill wire, I think I'm going to do so |
Wed, 16 Nov 2022 22:21:25 +0000
1968 VBB150
quote
https://www.amazon.com/DSD-TECH-Channels-Bluetooth-Compatible/dp/B07CZGCX9W/ref=sr_1_36?crid=1BRB59M7U4U8I&keywords=stand+alone+bluetooth+relay&qid=1668637195&sprefix=stand+alone+bluetooth+relay%2Caps%2C138&sr=8-36
This is kind of what I was referring to. You could power it with a standalone battery (small) and control it with your phone. |
Thu, 17 Nov 2022 00:51:11 +0000
Posts: 2311 Location: Siam |
quote
I'm not sure what country you're in, but in the UK or the US, the thieves just wheel motorbikes into a van or throw them in the back of a truck. Here in Thailand, motorbikes are often wheeled away quietly at night. Starting the engine happens later, back at the thieves' den.
A switch is just a very light deterrent for a thief. A heavy lock and chain is better. Last edited by nomadinsiam on Thu, 17 Nov 2022 06:10:16 +0000; edited 1 time
Positive
![]() '58 VBA '79CT90
Posts: 233 Location: Chico CA |
Thu, 17 Nov 2022 01:30:19 +0000
quote
I had toyed with the idea of hooking a switch up under the seat in the air intake with a simple bracket using the seat bolts but haven't.
![]() Thu, 17 Nov 2022 02:58:36 +0000
1959 VBA ,166, original 8's. 2005 Stella 177
Posts: 209 Location: Winder GA |
![]() 1959 VBA ,166, original 8's. 2005 Stella 177
quote
Ray8 wrote: No steering lock? You "could" run a single wire under the tank to a switch inside the left cowl. Switch connected to chassis ground and wire connected to the kill wire in your junction box. |
![]() Fri, 18 Nov 2022 11:09:41 +0000
Posts: 4474 Location: That bushfire place |
![]() 2 matching N.Z. '69 VBC Super, 177cc Racer, VespaCross Bodge, Puch SRA150, Piaggio Zip 100! & others
quote
Yours starts?
Speedy just sits there, not much chance anyone else would be able to get it started, and if they did, generally when they TRY to ride it, people fall off pretty quickly! |
