Mon, 21 Nov 2022 00:31:14 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Mon, 21 Nov 2022 00:31:14 +0000 quote
So close. Thanks for all the help here over the rebuilding of this box of parts.
Mon, 21 Nov 2022 00:35:06 +0000
1968 VBB150
1968 VBB150
Mon, 21 Nov 2022 00:35:06 +0000 quote
TUCK.
Also, longer runway, easy 2.5mph.
Mon, 21 Nov 2022 00:50:26 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Mon, 21 Nov 2022 00:50:26 +0000 quote
That's not the top speed attempt, just after. I've got miles of flat straight lightly used roads at my disposal.
Mon, 21 Nov 2022 00:57:46 +0000
1960 Allstate VNA, 1962 VNB
Mon, 21 Nov 2022 00:57:46 +0000 quote
Awesome. You'll get there.
Nice looking scoot. 👍
Mon, 21 Nov 2022 01:26:31 +0000
Mon, 21 Nov 2022 01:26:31 +0000 quote
It looked impressive though.
Mon, 21 Nov 2022 01:45:14 +0000
1968 VBB150
1968 VBB150
Mon, 21 Nov 2022 01:45:14 +0000 quote
little more air pressure for less rolling resistance? Warmer day, colder day? Plug gap change?
You are soooooooo close.
Mon, 21 Nov 2022 02:27:53 +0000
VNB VSC o9c VMA vbc vmb VSX
Mon, 21 Nov 2022 02:27:53 +0000 quote
Tuck.
Lean out the main 2 points for one ping (one run). *Sean Connery Voice* "One ping only".
Tail Wind.
Bobs your uncle.
Mon, 21 Nov 2022 03:17:18 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Mon, 21 Nov 2022 03:17:18 +0000 quote
60 degrees
Wind less than 3 mph
197' elevation
Pinasco 177 iron
Vape static a/c
18 degrees
Mazz cut crank
Fast flow tap
Road v1 exhaust
Case matched to modified 24/24 carb
AC 160
BE3
116 main
55-160 idle
25psi front
32psi rear
Mon, 21 Nov 2022 03:44:19 +0000
Mon, 21 Nov 2022 03:44:19 +0000 quote
Grumpnut wrote:
60 degrees
197' elevation
Pinasco 177 iron
Vape static a/c
18 degrees
Mazz cut crank
Fast flow tap
Road v1 exhaust
AC 160
BE3
116 main
55-160 idle
25psi front
32psi rear
Are you running a CHT gauge? Reason I ask is I couldn't keep the temp below 300f at WOT with that setup. And I'm running the Pinasco 2-port 177 and vape AC, at 20 degrees, 57mm Mazz crank and Ffftap, road 1 also!
I ended up with 120AC/BE4/128 and 55/160. Flat carb slide. Temps stay under 300f at WOT, and 65 mph tucked on flat road, downhill a little faster.
60/8s is close for you. Just don't seize like I did because I wasn't running a temp gauge...
Mon, 21 Nov 2022 04:09:32 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Mon, 21 Nov 2022 04:09:32 +0000 quote
No temp gauge. Really don't want one. Have more brass coming this week to get it dialed in.
Tue, 22 Nov 2022 02:33:29 +0000
Tue, 22 Nov 2022 02:33:29 +0000 quote
You could bump the clutch from 21 to 22 teeth. That'd give you the extra 2 1/2 mph with no other tuning changes.
Otherwise, you're going to need to eke more to end RPM's out of your motor, which may require more changes than just jetting. Probably intake and port timing changes.
Or you could wait for a good tail wind for your next attempt.
Tue, 22 Nov 2022 03:07:59 +0000
parallelogramerist
parallelogramerist
Tue, 22 Nov 2022 03:07:59 +0000 quote
Possibly wait for a cold morning where it's closer to the mid-30 degrees outside? It might give you 1 extra mph. Wearing a spandex body suit could give you another 1mph. Now we just need to figure out where to get that last .5mph! Perhaps skip Thanksgiving dinner this week?...no, that's not realistic. We gotta think of a different plan.
Tue, 22 Nov 2022 10:53:09 +0000
Tue, 22 Nov 2022 10:53:09 +0000 quote
Draft behind someone in a van?
Tue, 22 Nov 2022 11:52:02 +0000
Tue, 22 Nov 2022 11:52:02 +0000 quote
I once (ONCE that is) drafted a B-Double Truck down the highway for many many kms, on a PX200, it was going 110km/h+ (70mph)... found that you need to keep within about 5m of it, else you get buffeted and near-on blown off scooter... it sure was fuel economical, & I would pop out every now & then, so driver could see me in his mirrors.
Just hoped he didn't drive over a Roadkill Kangaroo! Scary as all whqt not! Would NEVER recommend it, nor do it EVER again!
Ohh, amd I had the keys for the backup van in my pocket!, so they were all stuck waiting for me to somehow get back to them, oops.
Tue, 22 Nov 2022 16:54:39 +0000
various, but less than I used to have
Tue, 22 Nov 2022 16:54:39 +0000 quote
Doesn't look half bad at speed. Nice job!
Wed, 23 Nov 2022 16:58:48 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Wed, 23 Nov 2022 16:58:48 +0000 quote
Thanks all.
Qascooter I'll replicate your jet stack and give it a go.
Stay tuned
Wed, 23 Nov 2022 21:53:16 +0000
Wed, 23 Nov 2022 21:53:16 +0000 quote
Which tracking app are you using?
Wed, 23 Nov 2022 21:58:32 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Wed, 23 Nov 2022 21:58:32 +0000 quote
This one
https://apps.apple.com/us/app/speedometer-simple/id939507215
Wed, 23 Nov 2022 22:08:10 +0000
parallelogramerist
parallelogramerist
Wed, 23 Nov 2022 22:08:10 +0000 quote
I did that once many years ago. Yes, it was scary! I was riding back home on Sunday after dark from a rally in Seattle, back home to Oregon. I tucked in right behind a semi hauling liquid nitrogen. Cruising Southbound on i-5 I stayed about 10' off his tail...keeping it at about 62mph for the next 90+ miles. I was sitting bolt upright with a vacuum draft that was sucking me closer. I also got 90 mpg the whole time! My guardian angel must have been working overtime to keep me alive that night. I'd prefer not to attempt that stunt again.
Wed, 23 Nov 2022 22:44:47 +0000
None, But Looking.
None, But Looking.
Wed, 23 Nov 2022 22:44:47 +0000 quote
You could always Rollie Free it...
Fri, 25 Nov 2022 23:02:31 +0000
LXS 150
LXS 150
Fri, 25 Nov 2022 23:02:31 +0000 quote
Or Craig Vetter it by adding a tail cone of sorts to the seat behind the rider.
My 150S ('09, LXS) gains 3-5MPH (60MPH -> 65MPH) out of having a flyscreen, tailbag, and a bag on the seat behind the rider to close up the gap between my backside and the tailbag. The idea is to divert airflow around the rider's arms (flyscreen) and extend/disperse the pocket of low-pressure air behind the rider, to reduce drag.
My earlier version had the tailbag on the seat (on a small wedge-shaped platform, since the S seat slopes aft behind the rider's position), and was similarly effective.
Sat, 26 Nov 2022 00:51:21 +0000
Sat, 26 Nov 2022 00:51:21 +0000 quote
Honestly that run was so close with zero tuck that just tucking in would likely get you there.
Full tuck is my nitrous.
[ Time: 0.0288s ][ Queries: 6 (0.0027s) ][ Debug on ][ 276 ][ Thing Two ]
