Mon, 21 Nov 2022 00:31:14 +0000
quote
So close. Thanks for all the help here over the rebuilding of this box of parts.
Positive
Mon, 21 Nov 2022 00:35:06 +0000
1968 VBB150
Posts: 674 Location: OC |
Mon, 21 Nov 2022 00:50:26 +0000
quote
That's not the top speed attempt, just after. I've got miles of flat straight lightly used roads at my disposal.
![]() 1960 Allstate VNA, 1962 VNB
Posts: 242 Location: Cambria, CA |
Posts: 2305 Location: northern New York |
Mon, 21 Nov 2022 01:45:14 +0000
1968 VBB150
quote
little more air pressure for less rolling resistance? Warmer day, colder day? Plug gap change?
You are soooooooo close. |
![]() VNB VSC 09C VMA VSX - vbc vmb
Posts: 7280 Location: Hustletown, TX |
Mon, 21 Nov 2022 02:27:53 +0000
quote
Tuck.
Lean out the main 2 points for one ping (one run). *Sean Connery Voice* "One ping only". Tail Wind. Bobs your uncle. |
Mon, 21 Nov 2022 03:17:18 +0000
quote
60 degrees
Wind less than 3 mph 197' elevation Pinasco 177 iron Vape static a/c 18 degrees Mazz cut crank Fast flow tap Road v1 exhaust Case matched to modified 24/24 carb AC 160 BE3 116 main 55-160 idle 25psi front 32psi rear |
Posts: 3884 Location: Florence, OR |
Mon, 21 Nov 2022 03:44:19 +0000
quote
Grumpnut wrote: 60 degrees Wind less than 3 mph 197' elevation Pinasco 177 iron Vape static a/c 18 degrees Mazz cut crank Fast flow tap Road v1 exhaust Case matched to modified 24/24 carb AC 160 BE3 116 main 55-160 idle 25psi front 32psi rear I ended up with 120AC/BE4/128 and 55/160. Flat carb slide. Temps stay under 300f at WOT, and 65 mph tucked on flat road, downhill a little faster. 60/8s is close for you. Just don't seize like I did because I wasn't running a temp gauge... |
Mon, 21 Nov 2022 04:09:32 +0000
quote
No temp gauge. Really don't want one. Have more brass coming this week to get it dialed in.
Positive
![]() Tue, 22 Nov 2022 02:33:29 +0000
Posts: 8377 Location: Nashville |
quote
You could bump the clutch from 21 to 22 teeth. That'd give you the extra 2 1/2 mph with no other tuning changes.
Otherwise, you're going to need to eke more to end RPM's out of your motor, which may require more changes than just jetting. Probably intake and port timing changes. Or you could wait for a good tail wind for your next attempt. |
Tue, 22 Nov 2022 03:07:59 +0000
parallelogramerist
Posts: 4643 |
quote
Possibly wait for a cold morning where it's closer to the mid-30 degrees outside? It might give you 1 extra mph. Wearing a spandex body suit could give you another 1mph. Now we just need to figure out where to get that last .5mph! Perhaps skip Thanksgiving dinner this week?...no, that's not realistic. We gotta think of a different plan.
Positive
![]() Tue, 22 Nov 2022 10:53:09 +0000
Posts: 3504 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
whodatschrome wrote: Possibly wait for a cold morning where it's closer to the mid-30 degrees outside? It might give you 1 extra mph. Wearing a spandex body suit could give you another 1mph. Now we just need to figure out where to get that last .5mph! Perhaps skip Thanksgiving dinner this week?...no, that's not realistic. We gotta think of a different plan. |
![]() Tue, 22 Nov 2022 11:52:02 +0000
Posts: 4575 Location: Australa, Mate |
![]() 1997 Italjet Formula 125, 2 matching N.Z. '69 VBC Super, 177cc Racer, VespaCross Bodge, Puch SRA150, Piaggio Zip 100! & others
quote
Christopher_55934 wrote: Draft behind someone in a van? Just hoped he didn't drive over a Roadkill Kangaroo! Scary as all whqt not! Would NEVER recommend it, nor do it EVER again! Ohh, amd I had the keys for the backup van in my pocket!, so they were all stuck waiting for me to somehow get back to them, oops.
Positive
various, but less than I used to have
Posts: 167 Location: San Anselmo |
Wed, 23 Nov 2022 16:58:48 +0000
quote
Thanks all.
Qascooter I'll replicate your jet stack and give it a go. Stay tuned |
![]() 1964 Allstate Cruisaire, 1966 Allstate Blue Badge Small Frame, 2022 Husqvarna Vitpilen 401
Posts: 902 Location: York, PA (the intellectual center of the universe) |
Wed, 23 Nov 2022 22:08:10 +0000
parallelogramerist
Posts: 4643 |
quote
SubEtherBASS wrote: I once (ONCE that is) drafted a B-Double Truck down the highway for many many kms, on a PX200, it was going 110km/h+ (70mph)... found that you need to keep within about 5m of it, else you get buffeted and near-on blown off scooter... it sure was fuel economical, & I would pop out every now & then, so driver could see me in his mirrors. Just hoped he didn't drive over a Roadkill Kangaroo! Scary as all whqt not! Would NEVER recommend it, nor do it EVER again! Ohh, amd I had the keys for the backup van in my pocket!, so they were all stuck waiting for me to somehow get back to them, oops. |
![]() 2022 Liberty 150S-"Meg"
Posts: 1090 Location: Texas |
LXS 150
Posts: 1201 Location: The OTHER South Bay, CA |
Fri, 25 Nov 2022 23:02:31 +0000
quote
Or Craig Vetter it by adding a tail cone of sorts to the seat behind the rider.
My 150S ('09, LXS) gains 3-5MPH (60MPH -> 65MPH) out of having a flyscreen, tailbag, and a bag on the seat behind the rider to close up the gap between my backside and the tailbag. The idea is to divert airflow around the rider's arms (flyscreen) and extend/disperse the pocket of low-pressure air behind the rider, to reduce drag. My earlier version had the tailbag on the seat (on a small wedge-shaped platform, since the S seat slopes aft behind the rider's position), and was similarly effective. |
![]() Sat, 26 Nov 2022 00:51:21 +0000
Posts: 8729 Location: San Francisco |
![]() 3:5
quote
Honestly that run was so close with zero tuck that just tucking in would likely get you there.
Full tuck is my nitrous.
Positive
