![]() Vespa T5 classic 1994 and 1980 Vespa p200e
Posts: 51 Location: Burnham on sea, Somerset England |
Tue, 22 Nov 2022 14:56:47 +0000
quote
I've just finished rebuilding a Vespa p200e 1980 engine and I would like to know how to find out what size thrust washer i need. It's the washer what goes behind the crank.
Tue, 22 Nov 2022 15:04:00 +0000
quote
This is the clutch I'm fitting what I got off BeepSpeed. Vespa Clutch Unit P200, Rally 23 Tooth 7 Spring
Product Code: BD02130 ![]() |
Tue, 22 Nov 2022 15:51:23 +0000
parallelogramerist
Posts: 4154 |
quote
If it's just a stock height clutch basket, then i would use a washer spacer that's the same thickness as the oil pump gear that would normally reside behind the clutch on an auto-mix P200.
Thu, 29 Dec 2022 18:15:55 +0000
quote
I got one 3,7 and installed it yesterday but the clutch isnt working. no clutch when in gear when pulling the clutch lever.
Thu, 05 Jan 2023 07:07:20 +0000
quote
Did you get this issue sorted, and if so what was the outcome?
Thu, 05 Jan 2023 09:43:38 +0000
quote
I didn't work so I have opened up the clutch and found plants stuck together. I have soked the clutch in oil and will install the clutch tomorrow. Just waiting on my new torque wrench to come my other is broken.
![]() Fri, 06 Jan 2023 11:14:28 +0000
Posts: 4474 Location: That bushfire place |
![]() 2 matching N.Z. '69 VBC Super, 177cc Racer, VespaCross Bodge, Puch SRA150, Piaggio Zip 100! & others
quote
I've used numerous thickness washers over the years.
Did you put all the plates in the same way around? They are concave/convex, depending on which side you are looking at, but as long as they are all the same, all should be good |
Fri, 06 Jan 2023 12:25:49 +0000
quote
I contacted BeepSpeed and they advised me to use a 2.8 spacer washer. That was before I taken apart the clutch and found discs stuck together and abit of rust. It cleaned up ok and I soaked the plants and resembled it. I mailed BeepSpeed about the rust and they ask if I soaked the clutch before installing. I've got people saying to use the 3.7 not the 2.8 because that's the size of the cog for autolub p200e they are the same size.
Sat, 07 Jan 2023 14:48:11 +0000
quote
Update. The clutch is working now with the 3.7 spacer washer. Thrust washer on it. Not been out on it yet though
![]() Sat, 07 Jan 2023 14:49:47 +0000
Posts: 3236 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
shepys wrote: Update. The clutch is working now with the 3.7 spacer washer. Thrust washer on it. Not been out on it yet though |
Sat, 07 Jan 2023 16:12:11 +0000
quote
Metal disc stuck to the cork disc. There wasn't much rust really it cleaner up ok. Next time I buy a new clutch I will take it apart and soke the discs.
Posts: 5497 Location: Tega Cay, SC |
Sat, 07 Jan 2023 16:43:42 +0000
quote
Always need to soak the corks. Put them in a sandwich bag, one by one while dressing in some oil and let it sit for a spell.
Posts: 6632 Location: So Cal |
Sat, 07 Jan 2023 21:37:19 +0000
quote
Tierney wrote: Always need to soak the corks. |
Sat, 07 Jan 2023 22:11:42 +0000
quote
SoCalGuy wrote: Are you saying he should be a corksoaker? ![]() |
