Fri, 18 Nov 2022 22:20:40 +0000
Fri, 18 Nov 2022 22:20:40 +0000 quote
roland87 wrote:
Thanks John.
Stand is not so good - you can see the jack under exhaust😂 stand was handmade and cracked after few starts of smallframe engine.
Looks like you need some support under swing arm bolt.
Sun, 20 Nov 2022 17:23:07 +0000
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Sun, 20 Nov 2022 17:23:07 +0000 quote
already fixed, thanks
Sun, 20 Nov 2022 19:47:21 +0000
px 125 disc
px 125 disc
Sun, 20 Nov 2022 19:47:21 +0000 quote
I've just fitted a Vmc 177 super g kit to my px 125 and so far I'm very pleased with it.
Spec.
vmc kit just bolted on no mods.
bgm fast flow carb
drilled heart on a standard filter
jetting Ac160, be3, 128 main.
Polini box exhaust
Its running a little rich at the moment but I'll leave it like that while I run it in.
Happy with the power I've got, compared to a px 200 I owned 25 years ago it feels like a 200 but a bit more of everything everywhere.
'On small wheels' supplied the kit and Dave the owner has been very helpful with the installation and setting up the jetting of the carb.
Sun, 20 Nov 2022 20:50:46 +0000
parallelogramerist
parallelogramerist
Sun, 20 Nov 2022 20:50:46 +0000 quote
roland87 wrote:
Thanks for help friends!
Here is first start of VMC Super G on LML reed cases which I built for my friend.
ONE
TWO
THREE
Orange scooter, orange cylinder head, orange hoodie. I fully approve.
Sun, 20 Nov 2022 21:17:22 +0000
Sun, 20 Nov 2022 21:17:22 +0000 quote
Not noticed before you say it This is my friend and he like orange very much. His PK and PX is orange. But this engine is not for him
Wed, 23 Nov 2022 12:00:16 +0000
Wed, 23 Nov 2022 12:00:16 +0000 quote
ONE
TWO
THREE
What is that exhaust? The tailpipe is huge!
Wed, 23 Nov 2022 18:43:43 +0000
Vespa PX200
Vespa PX200
Wed, 23 Nov 2022 18:43:43 +0000 quote
Looks to me like that's a SIP Road 1.0 that got cut open and a 3-cm pipe inserted. Amirite?
Those Kyiv backyard sheds look a heck of a lot like the sheds in Belgrade btw.
Thu, 24 Nov 2022 19:51:21 +0000
Thu, 24 Nov 2022 19:51:21 +0000 quote
That engine sounds great and should be a solid runner. No reason you shouldn't get 18 or 19 HP out of it without too much effort of the port timings are good and the exhaust is up to the job.
Fri, 25 Nov 2022 13:12:15 +0000
Fri, 25 Nov 2022 13:12:15 +0000 quote
This is my old SIP Road 2. I used it with long chromed decorative pipe, but it was bad idea - tailpipe was cracked and I losed it on the road. I went to my welder and he have on hand only 27mm pipe and I had no time to wait or search for smaller pipe. So he weld this big pipe.
At the end there is Polini Box on this engine. I put my SIP only for test.
I'm very excited too about how this engine will run on the scooter. But it owner now in the frontline defend our country from russian invasion. So only after our victory.
It is not a backyard. It is so called "garage cooperative" - big guarded territory with a lot of garages(can vary from 20 to 500)
Fri, 25 Nov 2022 13:59:42 +0000
Fri, 25 Nov 2022 13:59:42 +0000 quote
Polini will be good for power and fit, but will run out of RPM's before the cylinder, I think. Others on here can say better than I. The VMC+Polini Box is a proven combination around here.
Slava Ukraini! I hope your friend is home soon in good health to take it for a victory lap!
Fri, 25 Nov 2022 14:22:13 +0000
Vespa PX200
Vespa PX200
Fri, 25 Nov 2022 14:22:13 +0000 quote
OK, yeah, not a backyard per se, but kind of the same thing. The scale here isn't the same as what I'd seen in Ukraine many years ago, in Kherson -- there was this 20-acre patch of single-car garages, probably like 500+ units in there, where I had to go find this mechanic. It was big enough to get lost in there. Anyhoo the overall look is the same!
I hope he'll be really happy with the results when he gets back. I can't speak for the VMC but I'm finding that my Polinibox + Malossi Sport runs out of steam around 7500. FMP notes that the Polini isn't as restrictive on revs as some people say -- he's got some videos of some setups pulling strong till over 8000.
Fri, 25 Nov 2022 19:52:20 +0000
2005 Star Dlx - VMC 187ccm
Fri, 25 Nov 2022 19:52:20 +0000 quote
Time to jetting.
VMC Crono
Side by Side Crono vs Super G
On
Im going to use a Crankshaft by Polini for PX200. Already machined the inside lip
Everything together
Fri, 25 Nov 2022 19:57:38 +0000
Fri, 25 Nov 2022 19:57:38 +0000 quote
So lip machined to fit 125/150 cases? Rotary intake?
Fri, 25 Nov 2022 20:20:11 +0000
Fri, 25 Nov 2022 20:20:11 +0000 quote
MRP intake, RD350 reed block.
Fri, 25 Nov 2022 23:35:05 +0000
Fri, 25 Nov 2022 23:35:05 +0000 quote
In that case, you should have gone with a bell crank and hogged out the intake for maximum flow.
Sat, 26 Nov 2022 16:41:30 +0000
Sat, 26 Nov 2022 16:41:30 +0000 quote
Yes, But the only bellshaped crank that i found where i bouth the Crono was de Uncle Tom one. At the moment of the purchase my pockets were not deep enough hehehe. Maybe later i will try to move to those cranks.
Sat, 26 Nov 2022 18:20:51 +0000
Sat, 26 Nov 2022 18:20:51 +0000 quote
Mazzucelli make one for the P200 that you can use with a base spacer. Fits the LML with no modifications other than needing the conversion little end bearing. I've run that setup for two cranks and several top ends on my LML's now.
Tue, 29 Nov 2022 15:55:48 +0000
Tue, 29 Nov 2022 15:55:48 +0000 quote
Nice. I will look for it. It worths the change to a bell shaped one? Does it feel more power? Gains? Im running in this crono yet. Maybe for a hundred km's more and then i will do the test for GSF Dyno. With the stelvio i was on 20-21PS (GSF Dyno)
Tue, 29 Nov 2022 16:06:59 +0000
Tue, 29 Nov 2022 16:06:59 +0000 quote
I can't say for sure it's worth the change, but it changes the overall geometry a little bit, plus is supposed to increase the low end power. I know that I get 27 HP on GSF Dyno with my build, which is a BGM177, but allegedly pretty similar performance.
Wed, 30 Nov 2022 14:39:18 +0000
Wed, 30 Nov 2022 14:39:18 +0000 quote
Hi guys. How do You see this spark?
Under city ride. Idle 45, 1.5 turns, JJM 1st Clip, Main 142.
Normal City ride. Idle 45, 1.5 turns, JJN 2nd Clip, Main 142
Wed, 30 Nov 2022 15:21:21 +0000
Wed, 30 Nov 2022 15:21:21 +0000 quote
That JJN looks like it's at risk of a seize. The JJM doesn't look bad, though.
Wed, 30 Nov 2022 18:01:58 +0000
Wed, 30 Nov 2022 18:01:58 +0000 quote
Ok, i will ride a couple of day with JJM. I dont understand why , with JJN 2nd clip, the negative is light chocolate and the spark edge just black. Im using RN2C Spark , relative to B9ES which is the one recommended by VMC. Ambient temp is 28*C. Maybe try B8 ?
Mon, 19 Dec 2022 21:43:00 +0000
Mon, 19 Dec 2022 21:43:00 +0000 quote
Sorry for offtop but maybe someone can help with advice.
I have Super G kit and want use temp gauge. Is it good idea to drill hole for sensor in one of marked places?
Sensor is 14mm length
I'm also interested will this sensor works properly as it marked like water sensor?
But on the other side I saw very similar sensor whi similar sensor which Scooter Center recommends for their BGM cylinder head.
This is what I have
Mon, 19 Dec 2022 21:58:49 +0000
Mon, 19 Dec 2022 21:58:49 +0000 quote
I'm also interested will this sensor works properly as it marked like water sensor.
This is what I have
I'm pretty sure FridayMatinee and Charlieman22 have both installed a temp gauge into that spot. I'll let them speak up for sure. If your kit takes a long thread spark plug, then you should be fine.
When you install it, you want to keep it shallow enough that the tip of the sensor can bottom out onto the head. It needs that contact to get fast and accurate readings.
Mon, 19 Dec 2022 22:05:04 +0000
Mon, 19 Dec 2022 22:05:04 +0000 quote
Cool thanks! Sorry for my misunderstanding and bad english but you mean that tip of sensor must touch the body of cylinder head?
And yes it its for long thread spark plug.
Mon, 19 Dec 2022 22:06:10 +0000
Mon, 19 Dec 2022 22:06:10 +0000 quote
Yes, that sensor tip must touch the head. And I'm sure your English is better than my Ukrainian.
Mon, 19 Dec 2022 22:08:56 +0000
Mon, 19 Dec 2022 22:08:56 +0000 quote
I'm cheating and use google translate
Mon, 19 Dec 2022 22:51:57 +0000
Mon, 19 Dec 2022 22:51:57 +0000 quote
Sensor at the lower position is preferred
Mon, 19 Dec 2022 23:35:14 +0000
Mon, 19 Dec 2022 23:35:14 +0000 quote
Google translate has come a long way since I was using it to read Russian Bluetooth forums chasing intellectual property leaks and trade secret theft.
Tue, 20 Dec 2022 02:16:04 +0000
Nedminder
Nedminder
Tue, 20 Dec 2022 02:16:04 +0000 quote
Hi Roland!
Love your work.
Here is what I did: Vintage vespa with sidecar (**Now In Technicolor ! **) (Page 78)
page 78... of my Shevchenko novel.
I love the sensor in the head.
By far my preference.
Three things to watch out for.
1. Place the hole so that you can tighten the sensor with a socket wrench. careful not to place it where you can't tighten it.
2. Don't over tighten the sensor when you put it in. a drop of loc time is a good idea
3. Your measured temperatures will be 50 degrees F hotter than under the plug. 300°F under the spark plug is 350°F with the sensor screwed into the head.
Tue, 20 Dec 2022 20:38:30 +0000
Tue, 20 Dec 2022 20:38:30 +0000 quote
charlieman22 wrote:
Thanks for great advice!
But now I'm really confused about how to screw in and tight the sensor? With socket? But there is wire and connector on the way...
Only what I see is the nose pliers
Tue, 20 Dec 2022 20:40:23 +0000
Tue, 20 Dec 2022 20:40:23 +0000 quote
I use a deep 3/8" drive socket with the wire fed out the top. You can get it hand tight enough with that to hold it in place.
Tue, 20 Dec 2022 21:26:32 +0000
Tue, 20 Dec 2022 21:26:32 +0000 quote
I did indeed try to run my sensor that way. But I wasn't successful. I was using the SIP probe which is maybe 4.5mm I think. It broke off when finger tightening it. So I have parts of 2 sensors in my cylinder head. I do plan on using the much more robust 10-12mm type eventually, I really dislike the under the plug ring. I can't get it to not leak there.
Tue, 20 Dec 2022 21:28:00 +0000
px 125 disc
px 125 disc
Tue, 20 Dec 2022 21:28:00 +0000 quote
And the sockets I've got you can get a spanner on them for just such an occasion.
Tue, 20 Dec 2022 21:28:42 +0000
Tue, 20 Dec 2022 21:28:42 +0000 quote
The Koso uses an M10x1.0 sensor. much better option.
Tue, 20 Dec 2022 21:30:12 +0000
Tue, 20 Dec 2022 21:30:12 +0000 quote
I've learned that lol. Now I just gotta order a new power box for the speedo. Then if that works I'll get that Koso one and redo it.
I'm in an abusive relationship with that damn speedo
Tue, 20 Dec 2022 21:37:44 +0000
Nedminder
Nedminder
Tue, 20 Dec 2022 21:37:44 +0000 quote
Roland - the answers above covered it.
I think I let the wire poke out the top of the socket and put a vice grips on the socket itself.
I was more worried about having to remove or replace it down the road, and not being able to get a tool on it.
The tip of the sensor needs to poke the bottom of the hole and make good contact, but it doesn't need a great deal of tightness and you don't want to strip your nicely threaded hole!
I'm sure you will handle it no problem.
I do suggest: go ahead and put a second sensor under the spark plug temporarily. Get the scooter hood and hot, and then unplug the spark plug sensor and plug in the head sensor.
You will see a great deal of difference. Takes some getting used to the new range of "safe".
Tue, 20 Dec 2022 21:52:44 +0000
Tue, 20 Dec 2022 21:52:44 +0000 quote
charlieman22 wrote:
Perfect! I do it as I also have spark sensor too.
Thank you all guys for such clear help!
Thu, 22 Dec 2022 15:05:27 +0000
Thu, 22 Dec 2022 15:05:27 +0000 quote
hi guys, i have a question, it is possible that the crono use similar Main Jet used on stelvio. With the stelvio a was on MJ132. I did some test with 3 MJs. 138, 148 and one drilled with a 1.5mm bit. The best i get was with 138. I will try a smaller MJ to see if that gets better.
Thu, 22 Dec 2022 15:45:07 +0000
Thu, 22 Dec 2022 15:45:07 +0000 quote
Are you monitoring cylinder Temperature?
Did it actually run with a 148 main jet?
[ Time: 0.1336s ][ Queries: 6 (0.1078s) ][ Debug on ][ 286 ][ Thing Two ]
