Wed, 23 Nov 2022 21:13:09 +0000
Wed, 23 Nov 2022 21:13:09 +0000 quote
Hi, I've been using Conti K62 white wall TL (rated J I guess) tires on my splitted rims (avatar vespa). Looking for new classic look same size, black.
SIP has the Heidenau K38 59M TL reinforced, is it fine with my splitted rims? They also have the cheaper SIP brand but the Heidenaus look better and are "made in Germany"… if that means anything nowadays. Other options among SIP offer? (To use 10% out on Black Friday + 30€ voucher). Thanks
Wed, 23 Nov 2022 22:21:47 +0000
Wed, 23 Nov 2022 22:21:47 +0000 quote
Both are fine for 10" or 8" wheels and are TT/TL. The SIP's are made in Vietnam, no idea of the manufacturer. I've bought them for both 10" and 8" rims.
Thu, 24 Nov 2022 08:55:04 +0000
Thu, 24 Nov 2022 08:55:04 +0000 quote
Still in doubt about their brand SIP tires, they have all the specs including speed up to 130 km/h
And much cheaper than Heidenau (116€ vs 161€ for 3 tires). Anyone who have used both and can compare? TIA
Regards
Thu, 24 Nov 2022 19:44:56 +0000
64 V90 survivor '65 Allstate survivor. '75 V90 SOLD. '77 P200 SOLD
Thu, 24 Nov 2022 19:44:56 +0000 quote
Put 10x3.0 K 38s on my smallie in the spring and really like them so far. Using 8x3.5 ones on my Allstate project. You won't be disappointed.
Smallie tires
Waiting for spring
Fri, 25 Nov 2022 09:08:41 +0000
Fri, 25 Nov 2022 09:08:41 +0000 quote
Thanks exmayor. They do look good.
What I notice in the K38's design compared to the SIP is the design/blocks of the edge which look much more trusty on cornering, as if it was from a bigger tire. The SIP edge is round and extends to the side of the tire to a point where its absolutely unnecessary ... just for looks?
Fri, 25 Nov 2022 15:14:30 +0000
parallelogramerist
parallelogramerist
Fri, 25 Nov 2022 15:14:30 +0000 quote
Those are side biter traction knobbies for riding through muddy ruts!
Fri, 25 Nov 2022 16:04:32 +0000
Fri, 25 Nov 2022 16:04:32 +0000 quote
Ikes! 3 inches is a lot of mud for a Vespa
Fri, 25 Nov 2022 18:50:58 +0000
Fri, 25 Nov 2022 18:50:58 +0000 quote
One of the things that keeps me going back to the S83 is the profile and edge. I tend to push the limits in the corners and S83 allows for a good contact patch up to a 45° lean.
Always felt the K38 didn't allow for that much lean. Also find Heidenau tires to be really heavy.
[ Time: 0.0312s ][ Queries: 6 (0.0044s) ][ Debug on ][ 276 ][ Thing Two ]
