![]() Tue, 15 Nov 2022 11:51:28 +0000
VBA1T
Posts: 94 Location: Belgium |
![]() Parmakit Primavera -74, Polini Primavera -68, Stock 150 Touring -59, VMC 177 Bajaj Chetak 125 -95
Posts: 504 Location: Finland |
![]() '58 VBA '79CT90
Posts: 234 Location: Chico CA |
Sat, 19 Nov 2022 04:10:00 +0000
Posts: 2313 Location: Siam |
quote
Having a cable trunnion on the throttle cable on that end is weird. I've never seen that before.
Sat, 19 Nov 2022 04:23:43 +0000
quote
"Having a cable trunnion on the throttle cable on that end is weird. I've never seen that before."
https://www.scootermercato.com/Scooter-Parts/Cable-Bits/TH-PB |
Sat, 19 Nov 2022 07:08:33 +0000
quote
nomadinsiam wrote: Having a cable trunnion on the throttle cable on that end is weird. I've never seen that before. I feel it's the easiest to adjust and get the exact length and tension you want. |
Sat, 19 Nov 2022 07:10:19 +0000
quote
Wouldn't that go at the carb end and not in the hole of the throttle pulley? I've always only seen a round cast head with the cable end embedded in it.
Sat, 19 Nov 2022 07:26:25 +0000
quote
nomadinsiam wrote: Wouldn't that go at the carb end and not in the hole of the throttle pulley? I've always only seen a round cast head with the cable end embedded in it. With the cast cable, you can't cut to length (well you can, but it's a bit of work…) With the cable in your image, the inner and outer are fixed pretty much. With the trunnion, some folks solder the cable too for extra strength. |
Sat, 19 Nov 2022 07:40:03 +0000
quote
Interesting. On my small frame, I use a gear cable with a small trunnion at the carb. The cast end goes in the pulley hole in the headset.
The GS/SS are fixed length inner and outer with a larger cast end for the pulley and a small cast end for the carb end. |
![]() Sat, 19 Nov 2022 23:07:52 +0000
Posts: 7158 Location: Nashville |
quote
I use a pinch nut in the same basic setup, but with a larger pulley on both my smallie and my GL. You need the larger radius to get enough throw for the big carbs, and as others noted, it's the only way to get any meaningful adjustment.
Also, on the largeframe, it's an extra-long throttle cable so it'll reach. |
Mon, 21 Nov 2022 22:34:54 +0000
quote
I just prefer to use the cables that have a cast small nipple on the carb side. On a smallie SHB it's ok to use big clamp nipple, but on "real" carbs there is no room for it.
But boy oh boy. Goodies are finally here Crank and something to mount on both ends. ![]()
Positive
Thu, 24 Nov 2022 20:57:42 +0000
quote
Meanwhile on the budget 200 side. Got the Polinibox to replace the stock one.
![]() Is it just me and my old Malossi that has the exhaust stub slightly angled more towards outside or is it a common thing? ![]() Even pushing by hand is not enough to line up the mounting holes. ![]() Introduced the exhaust to my angle grinder and took a wedge out to get the box high enough. Now it's just matter of welding it back together. ![]() I'll likely have to also fit a slimmer spring for the cemter stand return... |
Fri, 25 Nov 2022 20:36:42 +0000
quote
Spring is not the only problem. The support of center stand is also fouling on the exhaust. Maybe it's just time to order that side stand.
![]() Put on couple tacks, removed and laid some bead to fill the cut. Threw the box back in and checked that there is no tension before tightening the clamp. ![]()
Positive
Fri, 25 Nov 2022 21:35:06 +0000
quote
FINYoshi wrote: Spring is not the only problem. The support of center stand is also fouling on the exhaust. Maybe it's just time to order that side stand. ![]() Included a side stand on mine. ![]() ![]()
Positive
![]() Fri, 25 Nov 2022 23:38:29 +0000
quote
Ray8 wrote: You could move the center stand to forward of that rib with an MRP bracket (SIP) or make your own. More stable with the stand at that position as well. |
Sat, 26 Nov 2022 02:46:26 +0000
quote
Sat, 26 Nov 2022 17:23:12 +0000
quote
108 wrote: What's the top bracket attach to on the frame? |
Sat, 26 Nov 2022 21:49:07 +0000
parallelogramerist
Posts: 4156 |
quote
FINYoshi wrote: Project 61 Allstate 200 (now 208) with 2020 updates (Page 4) |
Sun, 27 Nov 2022 21:58:34 +0000
quote
whodatschrome wrote: I went the easy route and simply bought the MRP bracket for my Allstate. You can scroll to page 4 to see it in the thread below... Project 61 Allstate 200 (now 208) with 2020 updates (Page 4) |
Sun, 27 Nov 2022 23:35:12 +0000
parallelogramerist
Posts: 4156 |
quote
FINYoshi wrote: Nice! Did you drill extra holes for the mount? |
Mon, 28 Nov 2022 07:56:20 +0000
quote
Ray8 wrote: It doesn't attach to the frame there. The original center stand bolts hold the bracket. Stand and spring to bracket only. |
Mon, 28 Nov 2022 16:39:22 +0000
quote
whodatschrome wrote: For the little stainless "exhaust spring hanger" bracket? No, both the MRP plate and the SIP bracket both had multiple holes predrilled in them. I did have to oval out a hole a little bit so that they would line up though. |
Mon, 28 Nov 2022 16:45:26 +0000
parallelogramerist
Posts: 4156 |
quote
FINYoshi wrote: In the frame. The plate mounts up on original stand holes, but are there new holes needed on the other side of the rib? |
Mon, 28 Nov 2022 16:49:22 +0000
quote
That's just the thing I had in my mind. It's kinda bad place to just float around since sand will get between plate and the frame. Along vibration it will rub off the paint and recipe for rust is ready.
Center stand is essential for looks but I think I'm starting to lean towards a side stand. Pun intended |
Sat, 31 Dec 2022 07:58:50 +0000
quote
Since the ready re-location plates seem to be kind of half-ready products, I found the motivation to fab my own. Found a nice little profile plate from my scrap metal pin that originates from a CT device cabinet where it was used to mount an UPS.
Measure, cut, punch and drill couple holes ![]() Dry-fit, rinse and repeat ![]() Nice room for captive nuts. ![]()
Positive
