Wed, 19 Apr 2023 20:18:57 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Wed, 19 Apr 2023 20:18:57 +0000 quote
I installed a new latch recently but the seat never locked,,,,until now, It is stuck shut and no amount of pushing the button or pulling the lever in the glove box will budge it. Fuel is getting low. Any suggestions will be greatly appreciated.
thanks
Tony
Yes, I read the wiki and the FAQ
Wed, 19 Apr 2023 20:26:08 +0000
ET 50 GTS250ie Sprint 150
Wed, 19 Apr 2023 20:26:08 +0000 quote
I think this happen to me once on a GT200. I think I had get it from the back remove the rack if your bike even has one and get at the latch and move it with a screwdriver or something.
Wed, 19 Apr 2023 20:42:30 +0000
2020 GTS 300
2020 GTS 300
Wed, 19 Apr 2023 20:42:30 +0000 quote
You might try to grab a coat hanger and see if you can get it up between the Airbox and the frame, if you can hit the pivot point, you may be able to pull/push it just enough to release the connector. It is spring loaded so it does not take much.
Also if you are hearing a noise when you push the button, you may want to try pushing down on the seat at the same time. i could just be high enough to block it from opening.
Wed, 19 Apr 2023 21:28:08 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Wed, 19 Apr 2023 21:28:08 +0000 quote
When I push the button, I can hear the latch moving.I did try pushing down on the seat, nada, I'll remove the rear rack and report back
Removed the rear rack and exposed 2 small holes, again nada.
Thu, 20 Apr 2023 00:44:17 +0000
GS160 GL150 GT200
GS160 GL150 GT200
Thu, 20 Apr 2023 00:44:17 +0000 quote
Try gently pulling up on the rear of the seat as you push the button.
Thu, 20 Apr 2023 11:06:33 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Thu, 20 Apr 2023 11:06:33 +0000 quote
Tried that also, no joy. what's left? I am thinking I could use my 4" hole saw and drill in from the top rear, that may be my only option?
Thu, 20 Apr 2023 12:49:09 +0000
Thu, 20 Apr 2023 12:49:09 +0000 quote
I know you tried pushing down on the seat but you may try sitting on it to put even more downward pressure on it.
Thu, 20 Apr 2023 12:51:15 +0000
Thu, 20 Apr 2023 12:51:15 +0000 quote
Are you hearing the latch move or just the solenoid actuating? It may be the solenoid and the issue may be the cable between the solenoid and latch.
Thu, 20 Apr 2023 12:58:43 +0000
Thu, 20 Apr 2023 12:58:43 +0000 quote
Just went out to my GTS250 and I was able to wiggle my arm and hand up to feel the cable coming out from the solenoid, right next to solenoid. I pushed the release button and felt cable going to latch move, so I confirmed what I thought I was feeling. Familiar with the set up as I have had to replace both latch cables.
I did not remove the lower plastic piece but you should be able to reach up with some needlenose pliers and pull on the cable to the latch.
Disclaimer: I am a slim build so my arms are slim.
Thu, 20 Apr 2023 13:02:36 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Thu, 20 Apr 2023 13:02:36 +0000 quote
Are you hearing the latch move or just the solenoid actuating? It is hard to tell the difference but I am sure the sound is coming from the latch area.
Yes, I tried sitting on it and hitting the button and pulling on the cable, the cable does not move when I grab it with vise grips and give it a good pull.
Thanks for your advice.
PS It is unfortunate that the lock can malfunction and you will not be able to add any gas
Thu, 20 Apr 2023 13:03:14 +0000
Thu, 20 Apr 2023 13:03:14 +0000 quote
Whoa! When the hole saw comes out, it's time to take a pause!
Thu, 20 Apr 2023 13:58:39 +0000
Thu, 20 Apr 2023 13:58:39 +0000 quote
Which cable are you grabbing on? The one from the legshield to the solenoid or the one from the solenoid to the latch?
Thu, 20 Apr 2023 14:10:36 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Thu, 20 Apr 2023 14:10:36 +0000 quote
I'm grabbing the cable where it comes out on the back side of the glove box. I'll pull as hard as I can and nothing happens at all. When I hit the power button I can hear the latch clicking but of course the seat does not release. Thanks for all who are trying to to help
Thu, 20 Apr 2023 15:12:51 +0000
Thu, 20 Apr 2023 15:12:51 +0000 quote
I think you might be hearing the solenoid actuating. You need to grab the cable on the other side of the solenoid by reaching up under as I noted in a previous post. That cable may have disconnected at the solenoid.
Thu, 20 Apr 2023 16:16:56 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Thu, 20 Apr 2023 16:16:56 +0000 quote
I had to remove the lower piece of trim to get my paw up in there. I grabbed the cable and yanked on it. But can't get it to move. Then the spring fell out
Thu, 20 Apr 2023 19:06:07 +0000
Vespa GT200
Vespa GT200
Thu, 20 Apr 2023 19:06:07 +0000 quote
Oh oh. This has happened to be a couple of times. I've been able to lift the seat to open it but I wonder if I have worse thing coming😱
Thu, 20 Apr 2023 19:06:27 +0000
Vespa GT200
Vespa GT200
Thu, 20 Apr 2023 19:06:27 +0000 quote
Oh oh. This has happened to be a couple of times. I assumed from over stuffing . I've been able to lift the seat to open it but I wonder if I have a worse thing coming😱
āš ļø Last edited by Nancy80 on Thu, 20 Apr 2023 20:30:04 +0000; edited 1 time
Thu, 20 Apr 2023 19:14:23 +0000
Thu, 20 Apr 2023 19:14:23 +0000 quote
The most likely place for the cable to disconnect is right at the latch.
I've seen both causes - the red clip coming away, and the cable cover end coming away from its securing slot, hence the zip-tie retaining it in place.
It is possible to open the seat from the outside - you need a right-angled pick and a lever to push the seat up by 1/2" so you can insert the pick though an existing slot.
Note the zip-tie retaining the cable in place.
This is available at Harbor Freight, one of a set of four for $1.99
You can just see the tip of the pick against the latch opening lever
Thu, 20 Apr 2023 19:32:52 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Thu, 20 Apr 2023 19:32:52 +0000 quote
I like this idea, much better than the 4-in hole saw. .
Fri, 21 Apr 2023 21:57:11 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Fri, 21 Apr 2023 21:57:11 +0000 quote
I bought the pick tools and poked blindly for a while, could not hook anything that would open it. This morning I cut a small hole in the rear of the seat which allowed me to see the latch. After getting it open, I promptly removed the latch
No more problems with a locking seat for me!
Now, if anyone has a decent seat cover they wish to sell, I'm interested!
Fri, 21 Apr 2023 22:20:31 +0000
Fri, 21 Apr 2023 22:20:31 +0000 quote
Be aware, if ever you tow the scooter on a trailer, the seat will fly open and you lose the pet carrier. That's happened to people on MV before, when the seat hasn't been latched down.
Best would be to repair whatever went amiss in the first place...
Fri, 21 Apr 2023 23:05:08 +0000
09 250 Super
09 250 Super
Fri, 21 Apr 2023 23:05:08 +0000 quote
When it did open what did you find as the culprit. Broken release spring or cable pinch clamp ? I'm curious to what caused this debacle. Its a shame you had to booger up the seat to fix it. Similar problem : I've had to do that as well while on a road trip several hundred miles from home, it involved the keys being left in a helmet that hastily got put in the locking trunk when it started to rain. Mistakes were made and lessons were learned.
Fri, 21 Apr 2023 23:23:07 +0000
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Fri, 21 Apr 2023 23:23:07 +0000 quote
Honestly, I did not look for the culprit. I was relieved to finally get it open and removed it immediately. Then I went to putting my scoot back together. Before this, the lock rarely worked properly anyway, I had installed a new latch a few weeks ago and it would not lock at all, until this happened.
Now, back to the regularly scheduled programming.
Fri, 21 Apr 2023 23:37:55 +0000
2015 Sprint 150, 2018 GTS 300
Fri, 21 Apr 2023 23:37:55 +0000 quote
Man's gotta due what a man's gotta do
Sat, 22 Apr 2023 00:01:00 +0000
2018 Vespa GTS300
2018 Vespa GTS300
Sat, 22 Apr 2023 00:01:00 +0000 quote
I've heard cheekyseats is good. https://www.cheekyseats.net/collections/vespa-gts-seat-covers
Sat, 22 Apr 2023 02:46:29 +0000
Sat, 22 Apr 2023 02:46:29 +0000 quote
bungie cord
[ Time: 0.0298s ][ Queries: 4 (0.0078s) ][ Debug on ][ 297 ][ Thing Two ]
