NOTE: This topic has a wiki article associated with it. You may view it
here.
Thu, 05 Jun 2008 19:01:32 +0000
0:7 And counting
Joined: Wed, 12 Oct 2005 05:12:11 +0000 Posts: 34099 Location: Bay Area, California
0:7 And counting
quote
Created article FAQ: Is it normal for a GT/GTS to "wobble"?
Thu, 29 Jul 2010 17:15:28 +0000
Joined: Fri, 12 Jan 2007 02:38:46 +0000 Posts: 8443 Location: San Francisco
quote
1 of 17 variables
One cause of the wobble seems to be a squared off rear tire.
I have a 2007 GT200 with the GTS24 rear and GTS23 front tires, 4069 miles. Over the past 500 miles the wobble has gotten much worse and the rear tire was into the wear bars. Front tire has some wear at the sides, not much in the middle.
After replacing the rear tire with a Zippy 1 the wobble has all but vanished.
One source of wobble may be that when the rear tire is squared off you get a misalignment of the front and rear tires at very small lean angles as the contact point shifts to the corner of the flat.
Sat, 22 Feb 2014 00:54:39 +0000
2016 Vespa GTV300 with ABS, 2015 GSX-r600, 2015 CB300F
quote
I have owned 3 GTS300s..2010, 2012 (super), and my new one, a 2014. Unfortunately, I have the wobble. Starts at 30 mph, then slowly seems to fade past 45. It is less noticeable when accelerating fast. Neither of my other 2 GTS300s had a wobble, but they both had the Michelin City Grips front and rear. The new scoot has Sawa tires, so my experience is just the opposite of what some have reported, namely that Sawa tires have fewer wobbles. So far all I've tried is different tire pressure with no improvement. I may just switch over to City Grips and see if that helps.
here.
