Fri Jun 06, 2008 10:52 am
Fri Jun 06, 2008 10:52 am linkquote
Created article 2006 Vespa GTS
Fri Jun 06, 2008 10:54 am
Fri Jun 06, 2008 10:54 am linkquote
With this, I'm hoping to start fleshing out a template for what a model-year-specific page should look like.
Sun Jun 08, 2008 12:06 pm
Sun Jun 08, 2008 12:06 pm linkquote
Attaching a few images for use in the article.
Sun Jun 08, 2008 1:42 pm
Sun Jun 08, 2008 1:42 pm linkquote
Been fleshing this one out a bit. I've added the color lineup for each model year, and some comparison to the GT200. Still need to add comprehensive specs and flesh out the overview a bit.
Sun Jun 08, 2008 2:49 pm
Sun Jun 08, 2008 2:49 pm linkquote
I've added the specifications as per Vespa USA. I hope that's OK with you.
Sun Jun 08, 2008 3:32 pm
Sun Jun 08, 2008 3:32 pm linkquote
Totally!
Makes me think we really need support for tables, though.
Sun Jun 08, 2008 3:37 pm
Sun Jun 08, 2008 3:37 pm linkquote
Yes, that would probably be a good idea, especially for things such as specs.
Sun Jun 08, 2008 4:03 pm
Sun Jun 08, 2008 4:03 pm linkquote
I list-ified the specs. Long term, you've definitely got me thinking about tables.
Sun Jun 08, 2008 4:06 pm
Sun Jun 08, 2008 4:06 pm linkquote
Huge improvement with your list, that is much easier to read now. Looking at how you did it now too, I have much to learn about this bulletin board stuff. I didn't know that there was that much "code" that one could use to make stuff look good. I guess I shouldn't be surprised.
Sun Jun 08, 2008 4:31 pm
Sun Jun 08, 2008 4:31 pm linkquote
Well, to be fair, some of it has only existed for a few days...
Sun Jun 08, 2008 5:04 pm
Sun Jun 08, 2008 5:04 pm linkquote
Victory is mine. Screw long term, I've got tables now.
Sun Jun 08, 2008 5:30 pm
Sun Jun 08, 2008 5:30 pm linkquote
Added a section on the notorious exhaust issue.
Mon Jun 09, 2008 2:48 am
Mon Jun 09, 2008 2:48 am linkquote
That table is elegant in its simplicity. What determines the column width, is it just the largest entry?
Mon Jun 09, 2008 5:25 am
Mon Jun 09, 2008 5:25 am linkquote
Yep. I had to put a line break in the bit about the QUASAR engine so that it wouldn't make the table huge.
Mon Jun 09, 2008 5:34 am
Mon Jun 09, 2008 5:34 am linkquote
Ah OK, so by just hitting return it gives you that line break and keeps it tidy and makes that entry two line instead of one. Very elegant, it is very useful to be able to hit edit and see how things have been done.
Wed Jun 11, 2008 11:31 am
Wed Jun 11, 2008 11:31 am linkquote
Note to self, or future editor: it would probably be reasonable to break out the exhaust problem section of this article into a dedicated article of its own, and expand that new article with pictures of the various exhausts, the clamps, and burned-out gaskets, and so on. The GTS exhaust issue is a pretty big issue, and we could easily dedicate an exhaustive page to the subject. We could then summarize briefly the exhaust problem in this GTS model article, and point to the dedicated page.
⬆️    About 5 years elapsed between posts    ⬇️
Sun Oct 20, 2013 7:25 am
'07 GTS-250ie - sold and gone
Sun Oct 20, 2013 7:25 am linkquote
Added link to head bearing adjustment post from Project Reports forum.
[ Time: 0.0308s ][ Queries: 5 (0.0069s) ][ Debug on ][ 211 ][ Thing One ]
