Fri, 06 Jun 2008 18:52:12 +0000
0:7 And counting
0:7 And counting
Fri, 06 Jun 2008 18:52:12 +0000 linkquote
Created article 2006 Vespa GTS
Fri, 06 Jun 2008 18:54:03 +0000
0:7 And counting
0:7 And counting
Fri, 06 Jun 2008 18:54:03 +0000 linkquote
With this, I'm hoping to start fleshing out a template for what a model-year-specific page should look like.
Sun, 08 Jun 2008 20:06:44 +0000
0:7 And counting
0:7 And counting
Sun, 08 Jun 2008 20:06:44 +0000 linkquote
Attaching a few images for use in the article.
Sun, 08 Jun 2008 21:42:17 +0000
0:7 And counting
0:7 And counting
Sun, 08 Jun 2008 21:42:17 +0000 linkquote
Been fleshing this one out a bit. I've added the color lineup for each model year, and some comparison to the GT200. Still need to add comprehensive specs and flesh out the overview a bit.
Sun, 08 Jun 2008 22:49:27 +0000
Sun, 08 Jun 2008 22:49:27 +0000 linkquote
I've added the specifications as per Vespa USA. I hope that's OK with you.
Sun, 08 Jun 2008 23:32:33 +0000
0:7 And counting
0:7 And counting
Sun, 08 Jun 2008 23:32:33 +0000 linkquote
Totally!
Makes me think we really need support for tables, though.
Sun, 08 Jun 2008 23:37:11 +0000
Sun, 08 Jun 2008 23:37:11 +0000 linkquote
Yes, that would probably be a good idea, especially for things such as specs.
Mon, 09 Jun 2008 00:03:06 +0000
0:7 And counting
0:7 And counting
Mon, 09 Jun 2008 00:03:06 +0000 linkquote
I list-ified the specs. Long term, you've definitely got me thinking about tables.
Mon, 09 Jun 2008 00:06:14 +0000
Mon, 09 Jun 2008 00:06:14 +0000 linkquote
Huge improvement with your list, that is much easier to read now. Looking at how you did it now too, I have much to learn about this bulletin board stuff. I didn't know that there was that much "code" that one could use to make stuff look good. I guess I shouldn't be surprised.
Mon, 09 Jun 2008 00:31:47 +0000
0:7 And counting
0:7 And counting
Mon, 09 Jun 2008 00:31:47 +0000 linkquote
Well, to be fair, some of it has only existed for a few days...
Mon, 09 Jun 2008 01:04:29 +0000
0:7 And counting
0:7 And counting
Mon, 09 Jun 2008 01:04:29 +0000 linkquote
Victory is mine. Screw long term, I've got tables now.
Mon, 09 Jun 2008 01:30:58 +0000
0:7 And counting
0:7 And counting
Mon, 09 Jun 2008 01:30:58 +0000 linkquote
Added a section on the notorious exhaust issue.
Mon, 09 Jun 2008 10:48:23 +0000
Mon, 09 Jun 2008 10:48:23 +0000 linkquote
That table is elegant in its simplicity. What determines the column width, is it just the largest entry?
Mon, 09 Jun 2008 13:25:48 +0000
0:7 And counting
0:7 And counting
Mon, 09 Jun 2008 13:25:48 +0000 linkquote
Yep. I had to put a line break in the bit about the QUASAR engine so that it wouldn't make the table huge.
Mon, 09 Jun 2008 13:34:39 +0000
Mon, 09 Jun 2008 13:34:39 +0000 linkquote
Ah OK, so by just hitting return it gives you that line break and keeps it tidy and makes that entry two line instead of one. Very elegant, it is very useful to be able to hit edit and see how things have been done.
Wed, 11 Jun 2008 19:31:36 +0000
0:7 And counting
0:7 And counting
Wed, 11 Jun 2008 19:31:36 +0000 linkquote
Note to self, or future editor: it would probably be reasonable to break out the exhaust problem section of this article into a dedicated article of its own, and expand that new article with pictures of the various exhausts, the clamps, and burned-out gaskets, and so on. The GTS exhaust issue is a pretty big issue, and we could easily dedicate an exhaustive page to the subject. We could then summarize briefly the exhaust problem in this GTS model article, and point to the dedicated page.
Sun, 20 Oct 2013 15:25:17 +0000
'07 GTS-250ie - sold and gone
Sun, 20 Oct 2013 15:25:17 +0000 linkquote
Added link to head bearing adjustment post from Project Reports forum.
[ Time: 0.0233s ][ Queries: 4 (0.0026s) ][ Debug on ][ 237 ][ Thing One ]
