Wed, 02 Sep 2009 05:58:07 +0000
MP3 500 'JAZZ'
MP3 500 'JAZZ'
Wed, 02 Sep 2009 05:58:07 +0000 quote
Has anyone replaced their front turn signals with something more stylish or less likely to snap off yet? They look like items that punks just wanna try to snap right off.
Wed, 02 Sep 2009 13:31:30 +0000
Wed, 02 Sep 2009 13:31:30 +0000 quote
Don't park it where Punks will mess with it.
They are designed to break away, so they don't break.
Wayne B
Wed, 02 Sep 2009 13:47:02 +0000
MP3 500 ie
MP3 500 ie
Wed, 02 Sep 2009 13:47:02 +0000 quote
I haven't yet, but i know that you can use Ducati mirror/turn signals are a good fit for the MP3. I know there is a thread on it some where on MV, just got to look.
Wed, 02 Sep 2009 13:55:04 +0000
Red MP3 500 RUBY DRAGON
Wed, 02 Sep 2009 13:55:04 +0000 quote
Cycle gear has several LED ones to choose from.
Wed, 02 Sep 2009 15:59:54 +0000
MP3 500 'JAZZ'
MP3 500 'JAZZ'
Wed, 02 Sep 2009 15:59:54 +0000 quote
I have taught in low income neighborhoods for the past 12 years, so punks come with the territory Also I have dropped my bike a few time on the same side and the front light finally broke off. I have a temporary fix for now, but I would rather have something more secure.
Wed, 02 Sep 2009 16:11:26 +0000
Wed, 02 Sep 2009 16:11:26 +0000 quote
But, I bet it's not broke, as stated they are designed to break away. Take the lens off and you should see what I mean. I haven't done this just heard it described and can't remember how it goes back together.
But everyone on here who thought is was broken, has been able to put it back together.
Wayne B
Wed, 02 Sep 2009 17:40:38 +0000
PX200 GTS300
PX200 GTS300
Wed, 02 Sep 2009 17:40:38 +0000 quote
take off the lens then you will see that the light is held in place by the silver reflector inside the light which slides over the black arm holding it all together
Wed, 02 Sep 2009 23:19:02 +0000
MP3 500 'JAZZ'
MP3 500 'JAZZ'
Wed, 02 Sep 2009 23:19:02 +0000 quote
I can tell you that YES it IS broke! Right where the light unit meets the rubber grommet. Both items have rectangular bases. They connect to each other, but the item that connects the two has broken off, so it is broken. basically they don't snap together anymore If you can correct that, please let me know.
Thu, 03 Sep 2009 00:05:23 +0000
Thu, 03 Sep 2009 00:05:23 +0000 quote
The bits that connect the two are very easily glued if broken.
Thu, 03 Sep 2009 00:26:12 +0000
Thu, 03 Sep 2009 00:26:12 +0000 quote
Not to say you're wrong, but I'd love to see the pic. That spot you mention(between the end of the 'rubber' part and the beginning of the actual light housing IS THE breakaway point. It's where mine "broke" and I felt like you did, absolutely sure that a new one was due. I've got great news for ya though...
1. When I took mine completely off(by removing some panels to make sure I got to it), I found that once disassembled, it was a breakaway point that could be reglued(with epoxy in my case) and simply just needed to be rescrewed together(bit tricky and you need a tiny screwdriver) and this had to be done while the light was on the bike(cos the wiring feeds through).
2. The even better news is that while I was in mourning and hadn't reglued/found out about the breakaway, I discovered that an entire new light assembly costs about $20.
Hope that helps, and trust me, these things repiece back together with very little work.
Thu, 03 Sep 2009 02:56:41 +0000
MP3 500, Honda PCX
MP3 500, Honda PCX
Thu, 03 Sep 2009 02:56:41 +0000 quote
I broke one. It was not a big deal. They cost about $30 and are easy to replace.
Thu, 08 Oct 2009 22:33:56 +0000
MP3 500
MP3 500
Thu, 08 Oct 2009 22:33:56 +0000 quote
How does one replace/re-attach turn signal
Hello! I'm really glad I've found this site. I hope you guys can help me out.
I've only had my MP3 500 for a couple of weeks and I knocked the right side turn signal loose. How do you re-attach it?
Thu, 08 Oct 2009 22:42:40 +0000
Thu, 08 Oct 2009 22:42:40 +0000 quote
Re: How does one replace/re-attach turn signal
As in the post seven above this one - unscrew the lens cover, remove the bits, push the outer black cover back in place, slide the reflector back in to secure it all, screw the lens cover back on. 2 minutes max. Done mine many a time.
Thu, 08 Oct 2009 22:50:23 +0000
Thu, 08 Oct 2009 22:50:23 +0000 quote
ride it to biketoberfest in Daytona and I or someone else will show you.
its easy like jim said but if you need pics let us know and I"ll take some and post them for ya
Thu, 08 Oct 2009 22:57:37 +0000
Thu, 08 Oct 2009 22:57:37 +0000 quote
I think if pics are needed for this then the bike is best taken to a dealer!
Fri, 09 Oct 2009 18:22:47 +0000
MP3 500
MP3 500
Fri, 09 Oct 2009 18:22:47 +0000 quote
Fixed it!!!
JimC you rock!
Old as Dirt, riding to Daytona is on my wish list.
I'm so glad I found this forum. Google is my friend, but you guys are MP3-500 family!
Sat, 10 Oct 2009 01:30:06 +0000
MP3 500 'JAZZ'
MP3 500 'JAZZ'
Sat, 10 Oct 2009 01:30:06 +0000 quote
I just picked up a wonderful walmart x-large motorcycle cover, and after I removed it I noticed today that my glued turned signal is no longer glued
So much for pathos.... John Cleese
Sat, 10 Oct 2009 20:22:56 +0000
fuoco 500
fuoco 500
Sat, 10 Oct 2009 20:22:56 +0000 quote
fitted these a while ago
they dont stick out as much as the others
and are loads brighter
Sat, 10 Oct 2009 21:48:53 +0000
Sat, 10 Oct 2009 21:48:53 +0000 quote
buddyphil nice lookin scoot you have there. the turn signals are small and out of the way. can you post a pic of them lit in the daylight and at night. also what breand are they and model number. thanks OAD
Sun, 11 Oct 2009 14:44:02 +0000
Sun, 11 Oct 2009 14:44:02 +0000 quote
Re: Replacement front turn signals anyone?
a friend changed his mirrors with led turnsignals in it thats a option and they are also sold with normale lightbulbs in it
Sun, 11 Oct 2009 22:09:37 +0000
MP3 400LT
MP3 400LT
Sun, 11 Oct 2009 22:09:37 +0000 quote
Hey Buddyphil, where did you buy the rims en what are the partnumbers and price?
thanks.
Robert
[ Time: 0.0454s ][ Queries: 6 (0.0202s) ][ Debug on ][ 277 ][ Thing Two ]
