Thu, 09 Nov 2006 19:22:53 +0000
El Macho
El Macho
Thu, 09 Nov 2006 19:22:53 +0000 quote
This is how to install leds into your top box.
First of all take off the lenses with a Philips screwdriver from behind. Make a template using some sort of masking tape. The measurements I used were 19mm between vertical LEDs and 10 mm between the two uprights. Mark dots on the tape. Stick the tape in the appropriate place avoiding the contours and screw hole.
Next, use a very small pilot drill to make small holes or indentations through your template.
Then widen the pilot holes using a 5mm drill.
Push the LEDs in from behind.
and it will look like this from the front:
Now, MOST importantly remove the LEDS and replace the lens as there is not enough room behind the lens to have the LEDs protruding. Once you have replaced the lens, superglue the LEDs in place. I have used 5mm 12v superbright LEDs with 180mcd luminescence. It makes sense to check the LEDs across a nine volt battery before glueing them in place.
When you glue the LEDs in place make sure that you have the cathode which is the shorter terminal on the LED in the centre of both rows as LEDs are current flow dependent and this makes it easier to wire. You can just see if you look very carefully that one terminal is longer than the other:
Next, bend the shorter terminals (cathodes) and the anodes outwards and loop and connect all the anodes together and all the cathodes together like this:
You can clearly follow the centre wire making contact with all the cathodes and the loop wire round the outside tied around the anodes.
You now want to solder the wire rail to the LED terminals and connect both LED sides to a supply wire. Make sure you connect the anodes on one side to the anodes on the other.
Carefully tape the soldered connections down using duck tape as shown here:
Now all there is left to do is to drill a hole in an appropriate place in the base of the top box and connect the wires to your brake light supply. The finished powered up item looks like this.
Thu, 09 Nov 2006 20:33:36 +0000
Thu, 09 Nov 2006 20:33:36 +0000 quote
That looks great! Are they going to be always-on, or are you going to link them with the brake lights?
Does the duct tape really match the inside of the case that well? Or is that a trick of the lighting?
Thu, 09 Nov 2006 21:05:34 +0000
gt200
gt200
Thu, 09 Nov 2006 21:05:34 +0000 quote
Man that is pimp!!! Very, very cool. And very well organized. You've got to make a little mov when your done, kind of like Jess did.
X
Thu, 09 Nov 2006 21:11:17 +0000
El Macho
El Macho
Thu, 09 Nov 2006 21:11:17 +0000 quote
Will be linked with the brake lights. The duck tape really does match the inside of the case that well!
Jess... how about a sticky?
Thu, 09 Nov 2006 22:04:50 +0000
GTS 250ie
GTS 250ie
Thu, 09 Nov 2006 22:04:50 +0000 quote
Looks really great!
I assume it would work on the GTS top box as well.
One question: Will the superglue seal well enough to keep water out, or does the lens do that?
Bill
Thu, 09 Nov 2006 22:17:08 +0000
0:7 And counting
0:7 And counting
Thu, 09 Nov 2006 22:17:08 +0000 quote
I can put it in the Project Reports area for you...
Thu, 09 Nov 2006 22:38:03 +0000
None! I sold it :(
None! I sold it :(
Thu, 09 Nov 2006 22:38:03 +0000 quote
Very nice job! Looks killa, Beale.
Thu, 09 Nov 2006 23:16:39 +0000
Piaggio BV 250
Piaggio BV 250
Thu, 09 Nov 2006 23:16:39 +0000 quote
Well thought out and well documented!
Bravo!!
Thu, 09 Nov 2006 23:18:17 +0000
El Macho
El Macho
Thu, 09 Nov 2006 23:18:17 +0000 quote
Thanks Jess, that would be good...
And thanks for all your comments!
I'll try and get a movie of it flashing with the comagination brake flasher!
If it leaks because the superglue doesn't create a tight enough seal, then out will come some clear silicone. I doubt much water will get in the lens offers quite a bit of protection.
Thu, 16 Nov 2006 22:28:19 +0000
Thu, 16 Nov 2006 22:28:19 +0000 quote
Thumbs up mate!
Sun, 26 Nov 2006 02:55:47 +0000
White Gts 300
White Gts 300
Sun, 26 Nov 2006 02:55:47 +0000 quote
Super nice job!!!
Maybe one day on mine... 8)
Can you tell us (picture?) what does it look like in daylight?
[ Time: 0.0276s ][ Queries: 4 (0.0023s) ][ Debug on ][ 276 ][ Thing Two ]
