Fri, 19 Feb 2010 05:21:28 +0000
GTS300 Super 2015 Blue, GTS300 Super 2023 Beige
Fri, 19 Feb 2010 05:21:28 +0000 quote
If you look inside your GTS air filter, you will see that the air passes through the filter, then negotiates its way through a U-shaped aperture in a central diaphragm, and finally works its way into the end of the induction pipe, which extends quite far into the filter box. Not very conducive to good breathing!
Being the inveterate fiddler that I am, I atacked the aperture in the diaphragm, opening the curved part of the U by 1/4 inch, then cutting away the corners to make a round-bottomed V shape, more-or-less doubling the size of the aperture.
I did not touch the induction pipe, as the length of this pipe is critical for tuning the engine's torque curve. But it is tempting to remove 1/2". In 15", how much difference can 1/2" make?
Anyway, the result of my fiddling is better acceleration right across the speed range, and my scooter now holds 105-110kph up a nearby steep hill where it was dropping to 95kph!
On the downside, the scooter is a bit more noisy at low speeds - up to about 60kph. Beyond that I don't notice it, and if I had an aftermarket pipe I would not notice it at all. Anyway, a lot of members here like a bit of noise. But under hard acceleration from a low speed, it sounds a bit like a two-stroke, and twice I have tried to change gear when accelerating!
I have discussed this mod with Paul of PM Tuning, and he has offered to try it on the dyno if I send him pictures and measurements. It would be nice to have my seat-of-pants evaluatioon verified by him. watch this space ...
Mike
Fri, 19 Feb 2010 16:38:49 +0000
P2, Leather covered '56 Douglas 42l2, vespa/lamby hybrid chop, GTS 250, Lambretta GP, The mighty Bajaj "bad korma"
Fri, 19 Feb 2010 16:38:49 +0000 quote
re
Mike,
I was nosing at a thread on one of the OZ forums the other day about the guy who mounted a polini filter onder thae panel. looked interesting but i would be dubious about waterproofing etc. this sounds more like it, keep us posted.
Fri, 19 Feb 2010 16:40:37 +0000
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
Fri, 19 Feb 2010 16:40:37 +0000 quote
Pictures would be great!
Fri, 19 Feb 2010 18:06:48 +0000
Fri, 19 Feb 2010 18:06:48 +0000 quote
Re: re
glover wrote:
Mike,
do you have a link to the oz forum???? ta
Fri, 19 Feb 2010 19:32:13 +0000
Vespa 300 super noir [of course]
Fri, 19 Feb 2010 19:32:13 +0000 quote
very, very interested in this, both altering original box and running different filter....
Fri, 19 Feb 2010 22:33:56 +0000
Fri, 19 Feb 2010 22:33:56 +0000 quote
I tried a Malossi filter, but didn't like the noise it made. I see Bunnybash has revived the K & N filter topic, but that one is also very noisy. Beauty of my mod is that it keeps the original Piaggio filter, and air intake is from below the box, and not from the heated air around the engine. Also, it costs nothing.
Admittedly, my idea needs a lot more research. I did one cut-and-try, and liked the results. One could cut a lot more, and maybe get a bit more with a lot more noise. Then one could atttack the end of the induction pipe - a half-inch off there would help gas flow a lot, and half an inch in a length of 15 inches shouldn't make that much difference to the induction tuning, should it?
Will post some pics and dimensions of my mod tomorrow. Busy day today!
Mike
Fri, 19 Feb 2010 22:46:03 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 19 Feb 2010 22:46:03 +0000 quote
I'm sure there will be a lot of interest in this. 8)
I have my hacksaw at the ready.
Sat, 20 Feb 2010 13:15:11 +0000
Sat, 20 Feb 2010 13:15:11 +0000 quote
Re: re
xmanhoe wrote:
glover wrote:
Mike,
http://scootercommunity.com.au/forums/t/12927.aspx
Sat, 20 Feb 2010 23:44:43 +0000
Sat, 20 Feb 2010 23:44:43 +0000 quote
Air Filter Mod - with picture and measurements
This picture shows the cut-away in the airfilter. I have high-lighted it in white. I didn't measure the original U-shaped aperture, but it is now 10cm wide and 5 cm deep.
I have mixed feelings about the extra noise at low speed. Mostly I like it, but sometimes I prefer my scoot quieter. Under hard acceleration from a standstill, it sounds a bit like a two-stroke. I know that would appeal to some of you. But twice I have tried to change gear when pulling off!! Old reflexes still there!
I do hope one (or several) of you will try this mod, and tell me that I am not dreaming! It is dead easy to do - just remove the filter cover and attack with some tin-snips or shears or even a pocket knife.
Just a reminder - this is a backyard mechanic job, I just hacked and tried it out. Maybe less cut away would reduce the noise but still give the benefits, maybe there are much bigger benefits lurking with a bigger cut.
Mike
Sun, 21 Feb 2010 00:09:10 +0000
Sun, 21 Feb 2010 00:09:10 +0000 quote
re
might have to give this a go,
mike, did you reset the ecu afterwards?
Sun, 21 Feb 2010 01:39:11 +0000
Sun, 21 Feb 2010 01:39:11 +0000 quote
No, I didn't. Been thinking about it.
Mike
Sun, 21 Feb 2010 02:24:41 +0000
Sun, 21 Feb 2010 02:24:41 +0000 quote
Puzzled - what now stops air getting past the foam filter, which can 'blow in the wind'?
Sun, 21 Feb 2010 03:06:18 +0000
Sun, 21 Feb 2010 03:06:18 +0000 quote
Jim, air coming up that narrow pipe from underneath the air filter box can only go through the filter. There is no other way. The outer cover of the box also has a central diaphragm which meets up with the one I cut, and which separates the filter area at the back from the manifold area at the front.
Mike
Sun, 21 Feb 2010 04:05:19 +0000
Sun, 21 Feb 2010 04:05:19 +0000 quote
I'll take your word for it.
Personally I'd not fiddle too much with the breathing or the exhaust - I'd not want to muddle the ECU. I'd far rather meddle with the transmission, where real measureable gains can be made.
Hmm - too many 'ddle words there. My Dad would call them 'hole' words.
Fid-hole
Mud-hole
Med-hole.
Hmm..
Sun, 21 Feb 2010 04:10:45 +0000
Sun, 21 Feb 2010 04:10:45 +0000 quote
Maybe when the Malossi V4 head becomes available, you will change your mind!
I understand that the ECU is very versatile, and it would take an awful lot of fiddling to muddle it.
I already have a Polini variator and Malossi clutch springs. Plan to experiment some more with sliders in the Polini, and a Fuzzy washer.
Inveterate fiddler Mike.
Sat, 27 Feb 2010 06:20:34 +0000
Sat, 27 Feb 2010 06:20:34 +0000 quote
I will have to re-evaluate the noise from my mod. I have just discovered that my exhaust is leaking where the two pipes join.
No, this is not the 2007 exhaust recall problem, although my scoot is a 2007 model. This is a result of faulty workmanship when I had a new rear tyre fitted last June. The mechanic tightened the clamp just behind where the slots are in the outer pipe, instead of over the slots.
My scooter was very noisy, and backfiring whenever I throttled down. When I got home today I found some plastic melted off a set of cables near the exhaust. I have moved the clamp to where it should be, and tied the cables up out of the way, so my scoot should be alright for tomorrow's Vespa club ride, but I shall be going back to the dealer for a new gasket on Monday.
Mike
Sat, 27 Feb 2010 15:06:49 +0000
2009 GTV 250
2009 GTV 250
Sat, 27 Feb 2010 15:06:49 +0000 quote
Airbox
Very interesting. Going to take a look at my airbox. Was wondering like JimC, if some air doesn't by-pass the filter.
Sun, 28 Feb 2010 04:54:44 +0000
Sun, 28 Feb 2010 04:54:44 +0000 quote
I've got to take the cover off my airbox to see and understand what you are describing. Right now I tend to side with JimC regarding bypassing air, but I don't know what I'm talking about.
I always tend to believe that the engineers who designed this marvel know what they do, and if it were so easy to get more oomph out of it, they would have done it.
That said, how much air does this little piston breathe anyway? If I had a balloon, I'd inflate it with my exhaust to see.
Sun, 28 Feb 2010 06:07:18 +0000
Sun, 28 Feb 2010 06:07:18 +0000 quote
Please do take the cover off your air filter. Then you will see that the air enters through a narrow pipe from underneath, then passes through the filter to enter the main chamber. There is no other passage.
Then take note of the circuitous route the air has to take to pass through the small U-shaped aperature to get from the rear half of the box to the front half, and how it then it has to work its way around to the end of the induction pipe.
Once you have seen this for yourself, you will share my dismay at the possibility of ever getting a smooth flow of air into the engine. You might also want to start cutting away at the obstacles.
Mike
Sun, 28 Feb 2010 19:24:21 +0000
2009 GTV 250
2009 GTV 250
Sun, 28 Feb 2010 19:24:21 +0000 quote
GTS Air Box
I did take the airbox apart and Mike you're right.....there is no way the air can get by the filter, when modified . Had to really look at it a while, because it's a bit confusing (when apart) how the air moves through the box & filter.
Sun, 28 Feb 2010 21:55:41 +0000
Sun, 28 Feb 2010 21:55:41 +0000 quote
And you put it back together without doing anything about it?
MIke
Sun, 28 Feb 2010 22:43:25 +0000
2009 GTV 250
2009 GTV 250
Sun, 28 Feb 2010 22:43:25 +0000 quote
Air Box
MIke
...........I'm thinking........I'm thinking about it..........and probably will after we get back from Bike Week in Daytona.
Mon, 01 Mar 2010 03:40:37 +0000
Scarabeo 250ie, BV 250ie
Mon, 01 Mar 2010 03:40:37 +0000 quote
haha i was the guy doing the pod filter work here in australia... i think you will find that the noise isn't as bad as you think... it's more like adding an aftermarket pipe...
Mon, 01 Mar 2010 04:23:52 +0000
GTS 250
GTS 250
Mon, 01 Mar 2010 04:23:52 +0000 quote
Ok all this sounds good but what are the gains.. I'm confused... I don't thinking that little bit of a cut away will make any kind of performance gains.. In my opinion probably will just mess with air fuel mixer and give u problems.. Just my opinion
Fri, 05 Mar 2010 16:45:07 +0000
Fri, 05 Mar 2010 16:45:07 +0000 quote
There is certainly some unfiltered air passing through. I understand your reasoning behind cutting the wall that separates the halves of the airbox, but the same lip/wall that travels around the perimeter of the filter element is what holds it in place, and also seals its edges. The location of your cut would allow the filter to dip inward from the vacuum pressure, allowing air to slip by on the other side, where the outer cover would meet your cut area.
If you want to cut that area down, leave at least a cm (probably two) of the material at the top edge to retain the filter, and cut a hole rather than a slice.
Something more like this:
(orange lines indicate edges)
Fri, 05 Mar 2010 18:06:30 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 18:06:30 +0000 quote
Mike, I had my air filter out yesterday to clean it, so I thought I'd get the Stanley knife out.
I didn't cut out as much as you have, it does seem to pull a bit better.
While I had the knife in my hand I thought I would see if there was anything else that needed some attention.
Aha, whats this I've found?
(I'll post pic's in bit, can't find my card adapter.)
Fri, 05 Mar 2010 18:32:50 +0000
Fri, 05 Mar 2010 18:32:50 +0000 quote
re
Tease
Fri, 05 Mar 2010 19:07:37 +0000
White GTS 300
White GTS 300
Fri, 05 Mar 2010 19:07:37 +0000 quote
Conform copy of the gts300 spare parts manual pdf's.
There is a différene with the 250's one ? That's it ?
The hole is a native intention for the 300.
Fri, 05 Mar 2010 19:14:59 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 19:14:59 +0000 quote
Sussed it.
(Sorry for the wait glover.)
Don't cut too low or you risk water getting in.
Fri, 05 Mar 2010 19:17:05 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 19:17:05 +0000 quote
They look the same to me.
Fri, 05 Mar 2010 19:22:06 +0000
White GTS 300
White GTS 300
Fri, 05 Mar 2010 19:22:06 +0000 quote
There is this hole in the 250 ?
Fri, 05 Mar 2010 19:25:18 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 19:25:18 +0000 quote
The 1st bit I cut.
Fri, 05 Mar 2010 20:36:52 +0000
White GTS 300
White GTS 300
Fri, 05 Mar 2010 20:36:52 +0000 quote
Where does the tube, wich is under the air box on the image that i sent, fit in the air box.
I didn't see it in my air box. Normal ?
Fri, 05 Mar 2010 20:53:21 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 20:53:21 +0000 quote
That's the tube in the middle, it's the one that goes to the throttle body.
Fri, 05 Mar 2010 21:13:39 +0000
White GTS 300
White GTS 300
Fri, 05 Mar 2010 21:13:39 +0000 quote
The tube in the middle of you photo is this one in yellow, isn't it ?.
Is the other (in green) inside your air box ??
Fri, 05 Mar 2010 21:21:58 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 21:21:58 +0000 quote
Yeah, you're right it is the yellow one.
It looks like the one that your talking about slots into the piece that we've cut out, which would reduce the air flow even more.
Fri, 05 Mar 2010 21:36:29 +0000
White GTS 300
White GTS 300
Fri, 05 Mar 2010 21:36:29 +0000 quote
big-7-baz wrote:
It would reduce the air flow even more.
Exactly. I do not remember having seeing it (The green) in my air box. Did you have one in your's ?
Anyway, i do not see how to fit it starting to the hole that we were speaking about...
Fri, 05 Mar 2010 21:49:49 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Fri, 05 Mar 2010 21:49:49 +0000 quote
Mine didn't have one, but if you look closely at the pic. the bit on the end is slotted so that it can be slide into position, then when you put on the outer cover it would be held in place.
Fri, 05 Mar 2010 22:25:06 +0000
Fri, 05 Mar 2010 22:25:06 +0000 quote
I can't imagine what that worm-shaped thing in the middle is. Never seen one!
It is certainly designed to slot into the U cutaway, but then what? The inlet manifold prortudes too far into the box for that thing to bend around and fit on the end of it. Chop 3 inches off the manifold and that might work.
The mystery deepens!
In answer to Drewteague's concern, my filter fits snugly into the cover, and when I have opened the box there has been no sign of it having been sucked out leaving a gap. Anyway, that partition that I cut lines up with the corresponding partition in the cover, so it would play no part in holding the filter in position. I am quite happy that no air bypasses the filter.
Having replaced my exhaust bush, I now find that there is no extra noise associated with my mod, just a slight change in tone at low speed. So how much benefit does this mod give? I think that there is an improvement in acceleration, but it would be nice if PM Tuning could fit it into their schedule and come up with some figures. My feeling has always been that anything which promotes smooth flow can only be good.
Mike
Sat, 06 Mar 2010 08:32:21 +0000
AUTO. & TRAD.
AUTO. & TRAD.
Sat, 06 Mar 2010 08:32:21 +0000 quote
A smooth flow of air/fuel is definitely the way to go.
[ Time: 0.0613s ][ Queries: 6 (0.0345s) ][ Debug on ][ 286 ][ Thing Two ]
