Sun, 11 Apr 2010 16:14:58 +0000
Sun, 11 Apr 2010 16:14:58 +0000 quote
Created article Standard Roller Weights
Sun, 11 Apr 2010 16:56:04 +0000
Sun, 11 Apr 2010 16:56:04 +0000 quote
I linked this in on the Mantainance Procedures page under see also. not sure where else to link it.
was also playing with resorting the info to group models that use the same roller. That would allow including after market as well. was thinking of sorting it by width, then diameter, then weight.
Sun, 11 Apr 2010 20:03:34 +0000
Sun, 11 Apr 2010 20:03:34 +0000 quote
That's extremely helpful Patrick, thumbs up. Maintenance procedures seems to be the most logical place to link it from.
Sun, 11 Apr 2010 22:38:20 +0000
0:7 And counting
0:7 And counting
Sun, 11 Apr 2010 22:38:20 +0000 quote
Do we have a "reference" page? Seems like there are a few pages that could be linked from a central reference page if we had one.
Mon, 12 Apr 2010 11:30:42 +0000
Mon, 12 Apr 2010 11:30:42 +0000 quote
Done, added to the Reference section.
Mon, 12 Apr 2010 18:07:56 +0000
BV500 - GTS250
BV500 - GTS250
Mon, 12 Apr 2010 18:07:56 +0000 quote
We should add a column for minimum diameters. On the BV 500 it is 24.5mm
Tue, 11 May 2010 15:55:41 +0000
Tue, 11 May 2010 15:55:41 +0000 quote
Re: Standard Roller Weights
Just pulled a set of new stock LX 50 rollers out the bag:- 19x15.5 8g
Perhaps you can add this to your wiki list ?
Tue, 11 May 2010 16:16:35 +0000
Tue, 11 May 2010 16:16:35 +0000 quote
Just did. Thanks.
Mon, 21 Jun 2010 15:43:29 +0000
GTV125 & GT60
Location: England, somewhere down in the bottom left bit...
GTV125 & GT60
Mon, 21 Jun 2010 15:43:29 +0000 quote
Another one to add - Beedpseed advise standard roller spec for my GTV125 is 19mm x 17mm x 7.4g.
Edited to add... I guess the GTS125 is ditto.
Best,
Mark
⚠️ Last edited by MarkTheBlue on Mon, 28 Jun 2010 20:44:51 +0000; edited 1 time
Tue, 22 Jun 2010 03:44:36 +0000
Tue, 22 Jun 2010 03:44:36 +0000 quote
Added, with thanks.
⬆️    About 4y elapsed between posts    ⬇️
Sat, 13 Sep 2014 12:29:48 +0000
Scooter Pimp
Scooter Pimp
Sat, 13 Sep 2014 12:29:48 +0000 quote
Added stock roller info for Piaggio 100 4T
Fri, 28 Oct 2016 10:37:03 +0000
GTS 125 2010 - Midnight Blue LB10 VDE - (Stolen)
Fri, 28 Oct 2016 10:37:03 +0000 quote
Best,
Mark
The first time I changed my rollers on my GTS 125 2010 (Bought pre owned) i used the stock weights listed above. What is real funny is since then it revs so much higher then it used to... almost too much and my fuel economy went down by about 10-15% (I didn't pay attention to the ones I removed stupidly). I since replaced them (at the following normal service interval) with 8.5g weights and it felt much more balanced with a lower rpm while cruising at 40-50mph.
Have you had, or heard of any such experiences that stock weights are too light? (I apologise if I sound like a complete idiot, haha I probably am)
Sat, 29 Oct 2016 11:44:42 +0000
Scooter Pimp
Scooter Pimp
Sat, 29 Oct 2016 11:44:42 +0000 quote
Perhaps to do with rider weight/riding style maybe?
[ Time: 0.0342s ][ Queries: 3 (0.0120s) ][ Debug on ][ 299 ][ Thing Two ]
