@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
I'm converting my 100 sport to EI. Please let me know if I am wiring this correctly. I think the red wire I have coming from the pickup goes to the red plug on the CDI, white ground wire goes to white plug on CDI, and green wire from coil (I have replaced the original with a new wire but this photo still shows original green wire) to green plug on coil/kill switch. Does it matter which green plug on the CDI I connect to?
**Update**('')
I have everything wired correctly. I even replaced all of the old wires on the stator. I am getting no spark. The headlight lights up when I spin the flywheel with my drill. I have a new spark plug and the plug wire has very low miles. I cannot figure out why there is no spark. Bad pickup or CDI? Is there a way to test either of them with my mult-meter? Sorry for all of the questions, this is my first Vespa and it seems so simple yet, I cannot figure it out.
⚠️ Last edited by Gorso on UTC; edited 3 times
@akp avatar
TEAM #68
ET4 & GT160
TEAM #68
@akp avatar
ET4 & GT160
I believe it does. Plug into the first green one, the innermost. The other one is from your switches and operates the kill. This is how my px is set up.
@dcunited4life avatar
No moar Vespas...sold them all
AKP is correct.
@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
So, the kill switch should be wired directly to the cdi on the outside green plug? When I get this working, I'm going to create EI conversion for dummies with photos.
@akp avatar
TEAM #68
ET4 & GT160
TEAM #68
@akp avatar
ET4 & GT160
The outside green plug is wired directly to the kill switch on your headset.
@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
So after checking the continuity on every wire, new spark plug, rewired stator with all new wires still getting no spark. Checked the the pickup and got a reading of 90 ohms. SIP website states if it is not 115 ohms should be replaced. I just bought the pickup! Is it common for these to be bad? Does the 90 ohms reading indicate it is bad? This is so frustrating.
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
I know of one shop that ships crappy parts out of the box.
did you get your pickup from a regular scooter parts shop?
@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
SIP-Scooter. I ordered along with several other things that all seems to be okay.
@ginch avatar
@ginch avatar
Write to them and explain. I've found them pretty good about replacing things.
@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
Thanks Ginch, I will write them.
@brentscheffler avatar
'78, '80 P125X, '80 100 Sport, '74 150 Super
Just out of curiosity, did you replace the ignition coil? I did an EI conversion on my 100 sport and you *must* replace the ignition coil.
This is the one you need:
http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/P-PX-Ignition-LT-Coil/2288
My first attempt at the EI conversion did not include the new ignition coil and I also had no spark.
@gorso avatar
1981 100 Sport
@gorso avatar
1981 100 Sport
Thanks Brent, your thread was one of the most helpful when I was doing the wiring. So, the current ignition coil is not compatible with the cdi? When I bought the scooter I did say I was looking for a project, I guess that is what I got.
The ignition coil for points systems do not work with CDIs - different resistance or something. Swapping out the coil isn't too bad, you just have to go slow and be careful.
There is a good write up on the whole process:
http://autos.groups.yahoo.com/group/vespasmallframes/message/30486?threaded=1&l=1
[ Time: 0.0290s ][ Queries: 4 (0.0098s) ][ Debug on ][ 313 ][ Thing One ]
