Take off 4 bolts holding the handle bars on
Take off plastic shroud, you will see the hole/hollow tube (which is your steering column)
Loosen clamp insert plug, flat side towards bolt on clamp
Tighten the clamp as per specs.
(I believe it is 480 foot lbs of torque, but with this plug you can tighten as tight as you want and it won't hurt the plug, due to the fact that the plug is made out of harden steel)
There is a slight taper on the front of the plug, as seen in picture, to facilitate it going into the tube if the tube is already crushed. It will maintain the structural integrity of the tube.
I am charging $25.00 plus $7.00 US Shipping ($32.00)
Paypal account info: mlafer@sc.rr.com
I hope this answers your questions. If you need any more assistance, please feel free to contact me, 843-245-3954. If you need it longer, let me know.
Sincerely,
Michael Lafer
aka ironmike350
⚠️ Last edited by ironmike350 on UTC; edited 2 times
